Z-13/8 and SD-8
MikeDunlop
PostPosted: Wed Jul 16, 2014 1:12 pm    Post subject: Z-13/8 and SD-8 Reply with quote
A little clarification required on the Z-13/8 schematic. I'm building this into a Long-Ez and have the SD-8 with all the bits from B&C.
The Z-13/8 schematic shows something that is marked as W10 that appears to be between the Dynamo and the Regulator! This does NOT appear on the schematic from B&C.
Any info on this would be appreciated.
MikeD (UK)
johnbright
PostPosted: Sun Jan 01, 2017 10:26 pm    Post subject: Re: Z-13/8 and SD-8 Reply with quote
See Note 25 as well as Z-25.
Makes the SD-8 work with no battery.
PostPosted: Mon Jan 02, 2017 6:00 am    Post subject: Re: Z-13/8 and SD-8 Reply with quote
It would be interesting to read about why the two diodes and resistor work and why the SD-8 will not work without them (unless a battery is connected).
Joe Gores
PostPosted: Tue Jan 03, 2017 10:27 am    Post subject: Z-13/8 and SD-8 Reply with quote
Joe Gores
Here's a close approximation of the Ducati product used by Rotax. This
illustrates the general architecture of most rectifier/regulators over
the past 20 years or so . . .
[img]cid:.0[/img]
If you noodle through fuctionality of the circuit, you find a bridge
rectifier consisting of two diodes with cathodes tied to the output
terminal(s) . . . two silicon rectifiers with anodes connected to
ground. Control electronics for the SCRs gets power through the
"C" terminal.
With no source of power at "C" and "B" . . . the control electronics
are dark. With no control electronics, the SCRs are dormant. The
AC output from a rotating dynamo is unavailable for use.
[img]cid:.1[/img]
Adding a battery . . . even a badly discharged battery of under 10 volts
will wake up the control electronics which in turn flogs the SCRs into
action and the Dynamo/R-R system wakes up.
Adding a couple of diodes external to the R-R along with a
current limiting resistor creates the equivalent 'leaky SCRs'
where rectification through the R-R is never zero. Small but
never zero.
In the absence of a load on the usual capacitor across the
R-R output terminals, this small energy source will charge the
capacitor to a voltage that will wake-up the control electronics
and bring the system on line.
This works only if there are no loads on the system's output
that over-taxes the weak, wake-up source.
www.avast.com
 Filesize:  103.42 KB
 Viewed:  7687 Time(s)
 Filesize:  161.21 KB
johnbright
PostPosted: Tue Jan 03, 2017 9:02 pm    Post subject: Re: Z-13/8 and SD-8 Reply with quote
To what voltage should the SD-8's PMR1C-14 regulator be set for Z-13/8?
I see for Z-12 the SD-60 and SD-20 (to use their old names) regulators are set at 14.2 and 13 volts respectively.
PostPosted: Wed Jan 04, 2017 8:42 am    Post subject: Re: Z-13/8 and SD-8 Reply with quote
Bob, thanks for that explanation.
Joe Gores
