Classic cowls, with XS oil & water radiators? Buy new co
ward.t(at)xtra.co.nz
PostPosted: Thu Dec 15, 2016 9:17 am    Post subject: Classic cowls, with XS oil & water radiators? Buy new co Reply with quote
David,
If you were supplied with a Europa XS engine frame then no it is not feasible.
The engine frame extends the cowls two inches forward. The XS cowls also have a different cooling system which allows for your oil and water radiators sent by Europa.
Would like to buy the Classic cowls however delivery to NZ would too expensive.
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
On 16/12/2016, at 5:39 AM, G-ODTW <dave(at)robotas.co.uk> wrote:
I have kit 215, a Classic Tri Gear, with a Rotax 912ULS. It has the Classic cowls ( I actually have 2 sets of them), but the Europa supplied firewall forward kit requires XS cowls.
Folk tell me I must order a set of XS cowls. But is it feasible to mod the Classic ones?
Having been totally absorbed running an engineering business for the last 30 years, building my 'plane came last in the priorities. Finally I have more time and am making good progress, but I do have a few dumb questions that others asked 15+ years back.
David Walters
01474 816817
dave(at)robotas.com
http://forums.matronics.com/viewtopic.php?p=463942#463942
MJKTuck(at)cs.com
PostPosted: Thu Dec 15, 2016 9:57 am    Post subject: Classic cowls, with XS oil & water radiators? Buy new co Reply with quote
The XS engine mount is different allowing the engine to sit higher for more prop clearance. The oil and water radiators are located below the engine. I think you would need the XS style cowlings.
Martin Tuck
N152MT (Older Europa with XS cowls).
David Walters
01474 816817
dave(at)robotas.com
G-ODTW
PostPosted: Thu Dec 15, 2016 10:28 am    Post subject: Re: Classic cowls, with XS oil & water radiators? Reply with quote
Thank Tim & Martin.
I have now put my Classic top cowl in place, and it is a lot shorter.
Decision made!
The improved prop clearance will be welcome too.
Does anyone need Classic cowls?
Does anyone have a set of XS cowls?
 Filesize:  74.47 KB
 Viewed:  6125 Time(s)
David Walters
01474 816817
dave@robotas.com
JonathanMilbank
PostPosted: Thu Dec 15, 2016 11:02 am    Post subject: Re: Classic cowls, with XS oil & water radiators? Buy ne Reply with quote
David, please PM me. I'm doing something similar.
Rgds, Jonathan
spcialeffects
PostPosted: Thu Dec 15, 2016 11:32 am    Post subject: Re: Classic cowls, with XS oil & water radiators? Buy ne Reply with quote
Good to see you are making progress Dave. The XS engine frame makes the engine sit 1" further forward and 2" higher and will not work with the "classic" cowls........I'v already researched this as you know i too have the classic.If you have to buy new cowlings try Neville Eyre's as they have bigger air in takes and baffles to direct and slow down the air.
