amekler
Posted: Fri Dec 09, 2016 4:27 pm Post subject: What flap setting do you use for takeoff |
I have been using no flaps for my 5000 ft home runway and partial flaps for short runways. What do other people use?
Alan
N668G
400 hrs
cooprv7(at)yahoo.com Guest
Posted: Fri Dec 09, 2016 4:55 pm Post subject: What flap setting do you use for takeoff |
I use partial flaps for all takeoffs, about 20%. Most times I’m sure it’s not necessary, but keeping as many things the same seems like a good habit and I can’t think of a reason not to use them.
Marcus
800 hrs
Alan
N668G
400 hrs
Posted: Fri Dec 09, 2016 5:05 pm Post subject: What flap setting do you use for takeoff |
Same as you.
Carl
| Quote: | On Dec 9, 2016, at 7:26 PM, Alan Mekler MD <amekler(at)metrocast.net> wrote:
Alan
N668G
400 hrs
dmaib@me.com
Posted: Fri Dec 09, 2016 5:35 pm Post subject: What flap setting do you use for takeoff |
Same as you. Alex DeDominices demonstrated to me that flaps fully retracted resulted in a shorter takeoff,during transition training. I tried a few different combinations and techniques during phase 1 and came to the same conclusion. I do use partial flaps on rough/sod runways just to get the load off the gear asap.
David Maib
Alan
N668G
400 hrs
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Posted: Fri Dec 09, 2016 6:34 pm Post subject: What flap setting do you use for takeoff |
Okay, that's what I do; fully retracted (no reflex) for normal takeoffs,
partial flaps on rough/sod runways like my home strip. So roughly half
my takeoffs are with partial.
But I can't make sense out of retracted flaps resulting in a shorter
takeoff. Seems possible yet unlikely but I have nothing to back that
up. Comments? Technique?
Bill "knowing I should just go out and get some numbers" Watson
On 12/9/2016 8:34 PM, David Maib wrote:
David Maib
> Alan
> N668G
> 400 hrs
Kelly McMullen
Posted: Fri Dec 09, 2016 7:33 pm Post subject: What flap setting do you use for takeoff |
I use 15 degrees for most takeoffs, unless I have a passenger that isn't ready for the acceleration and climb rate. Definitely shorter ground run than with 0 degrees. I haven't focused on actual numbers, suppose I could. More lift, lower lift-off speed are good for less wear and tear on landing gear. More altitude, quicker minimizes time in danger zone of low speed and altitude.
-sent from the I-droid implanted in my forearm
On Fri, Dec 9, 2016 at 7:34 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
| Quote: | --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
Okay, that's what I do; fully retracted (no reflex) for normal takeoffs, partial flaps on rough/sod runways like my home strip. So roughly half my takeoffs are with partial.
But I can't make sense out of retracted flaps resulting in a shorter takeoff. Seems possible yet unlikely but I have nothing to back that up. Comments? Technique?
| Quote: | --> RV10-List message posted by: David Maib <dmaib(at)me.com (dmaib(at)me.com)>
David Maib
| Quote: | On Dec 9, 2016, at 7:26 PM, Alan Mekler MD <amekler(at)metrocast.net (amekler(at)metrocast.net)> wrote:
--> RV10-List message posted by: Alan Mekler MD <amekler(at)metrocast.net (amekler(at)metrocast.net)>
Alan
N668G
400 hrs
br> fts!)
r> > /www.aeroelectric.com" rel="noreferrer" target="_blank">www.aeroelectric.com
w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com
e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
" rel="noreferrer" target="_blank">www.mrrace.com
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Sun Dec 11, 2016 5:41 am Post subject: What flap setting do you use for takeoff |
I'm going to guess that the added drag of the flaps being down lengthens the takeoff roll. The takeoff roll is pretty short with the flaps up. Just a SWAG on my part ..... I'm still painting.
Sent from Samsung tablet cruising on the Navigator Of The Seas.
-------- Original message --------
From Bill Watson <Mauledriver(at)nc.rr.com>
Date: 12/09/2016 9:34 PM (GMT-05:00)
To rv10-list(at)matronics.com
Subject Re: RV10-List: What flap setting do you use for takeoff
--> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com>
| Quote: | --> RV10-List message posted by: David Maib <dmaib(at)me.com>
David Maib
> --> RV10-List message posted by: Alan Mekler MD <amekler(at)metrocast.net>
> Alan
> N668G
> 400 hrs
_-============================================================
_-=
_-= -- Please Support Your Lists This Month --
_-= (And Get Some AWESOME FREE Gifts!)
_-=
_-= November is the Annual List Fund Raiser. Click on
_-= the Contribution link below to find out more about
_-= this year's Terrific Free Incentive Gifts provided
_-= by:
_-=
_-= * AeroElectric www.aeroelectric.com
_-= * The Builder's Bookstore www.buildersbooks.com
_-= * HomebuiltHELP www.homebuilthelp.com
_-= * My Pilot Store www.mypilotstore.com
_-= * Race Consulting www.mrrace.com
_-=
_-= List Contribution Web Site:
_-=
_-= --> http://www.matronics.com/contribution
_-=
_-= Thank you for your generous support!
_-=
_-= -Matt Dralle, List Admin.
_-=
_-= - The RV10-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?RV10-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-= --> http://wiki.matronics.com
_-= - List Contribution Web Site -
Lenny Iszak
Posted: Sun Dec 11, 2016 10:43 am Post subject: Re: What flap setting do you use for takeoff |
Lynn,
It's the other way around. Much shorter ground run with 10 degrees of flaps on takeoff, and way too long with flaps in the reflex (-3) position.
Lenny
| flying-nut(at)cfl.rr.com wrote: | I'm going to guess that the added drag of the flaps being down lengthens the takeoff roll. �The takeoff roll is pretty short with the flaps up. �Just a SWAG on my part ..... I'm still painting.
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
Mike Whisky
Posted: Tue Dec 13, 2016 10:33 am Post subject: Re: What flap setting do you use for takeoff |
Attached my Vx / Vy measurements during Phase I it was done with flaps 0 degrees. Would be interesting to see what it would be with 10 or 15 degrees.
159.37 KB |
15623 Time(s) |
_________________ RV-10 builder (flying)
#511 |
glastar(at)gmx.net Guest
Mike Whisky
Posted: Tue Dec 13, 2016 12:07 pm Post subject: Re: What flap setting do you use for takeoff |
Great idea if I ever find the time but an even better suggestion you do it during your Phase 1, just get the -10 done quickly 😉
1.59 MB |
15613 Time(s) |
#511 |
