What flap setting do you use for takeoff
amekler
PostPosted: Fri Dec 09, 2016 4:27 pm    Post subject: What flap setting do you use for takeoff Reply with quote
I have been using no flaps for my 5000 ft home runway and partial flaps for short runways. What do other people use?
Alan
N668G
400 hrs
cooprv7(at)yahoo.com
PostPosted: Fri Dec 09, 2016 4:55 pm    Post subject: What flap setting do you use for takeoff Reply with quote
I use partial flaps for all takeoffs, about 20%. Most times I’m sure it’s not necessary, but keeping as many things the same seems like a good habit and I can’t think of a reason not to use them.
Marcus
800 hrs
Alan
N668G
400 hrs
carl.froehlich(at)verizon
PostPosted: Fri Dec 09, 2016 5:05 pm    Post subject: What flap setting do you use for takeoff Reply with quote
Same as you.
Carl
Alan
N668G
400 hrs
dmaib@me.com
PostPosted: Fri Dec 09, 2016 5:35 pm    Post subject: What flap setting do you use for takeoff Reply with quote
Same as you. Alex DeDominices demonstrated to me that flaps fully retracted resulted in a shorter takeoff,during transition training. I tried a few different combinations and techniques during phase 1 and came to the same conclusion. I do use partial flaps on rough/sod runways just to get the load off the gear asap.
David Maib
Alan
N668G
400 hrs
David Maib
RV-10 #40559
New Smyrna Beach, FL
Mauledriver(at)nc.rr.com
PostPosted: Fri Dec 09, 2016 6:34 pm    Post subject: What flap setting do you use for takeoff Reply with quote
Okay, that's what I do; fully retracted (no reflex) for normal takeoffs,
partial flaps on rough/sod runways like my home strip. So roughly half
my takeoffs are with partial.
But I can't make sense out of retracted flaps resulting in a shorter
takeoff. Seems possible yet unlikely but I have nothing to back that
up. Comments? Technique?
Bill "knowing I should just go out and get some numbers" Watson
David Maib
> Alan
> N668G
> 400 hrs
Kelly McMullen
PostPosted: Fri Dec 09, 2016 7:33 pm    Post subject: What flap setting do you use for takeoff Reply with quote
I use 15 degrees for most takeoffs, unless I have a passenger that isn't ready for the acceleration and climb rate. Definitely shorter ground run than with 0 degrees. I haven't focused on actual numbers, suppose I could. More lift, lower lift-off speed are good for less wear and tear on landing gear. More altitude, quicker minimizes time in danger zone of low speed and altitude.
-sent from the I-droid implanted in my forearm
On Fri, Dec 9, 2016 at 7:34 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
--> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
Okay, that's what I do; fully retracted (no reflex) for normal takeoffs, partial flaps on rough/sod runways like my home strip.  So roughly half my takeoffs are with partial.
But I can't make sense out of retracted flaps resulting in a shorter takeoff.  Seems possible yet unlikely but I have nothing to back that up.  Comments? Technique?
--> RV10-List message posted by: David Maib <dmaib(at)me.com (dmaib(at)me.com)>
David Maib
On Dec 9, 2016, at 7:26 PM, Alan Mekler MD <amekler(at)metrocast.net (amekler(at)metrocast.net)> wrote:
--> RV10-List message posted by: Alan Mekler MD <amekler(at)metrocast.net (amekler(at)metrocast.net)>
Alan
N668G
400 hrs
br> fts!)
r> > /www.aeroelectric.com" rel="noreferrer" target="_blank">www.aeroelectric.com
w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com
e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
" rel="noreferrer" target="_blank">www.mrrace.com
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
flying-nut(at)cfl.rr.com
PostPosted: Sun Dec 11, 2016 5:41 am    Post subject: What flap setting do you use for takeoff Reply with quote
I'm going to guess that the added drag of the flaps being down lengthens the takeoff roll.  The takeoff roll is pretty short with the flaps up.  Just a SWAG on my part ..... I'm still painting.
Sent from Samsung tablet cruising on the Navigator Of The Seas.
-------- Original message --------
From Bill Watson <Mauledriver(at)nc.rr.com>
Date: 12/09/2016 9:34 PM (GMT-05:00)
To rv10-list(at)matronics.com
Subject Re: RV10-List: What flap setting do you use for takeoff
--> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com>
--> RV10-List message posted by: David Maib <dmaib(at)me.com>
David Maib
> --> RV10-List message posted by: Alan Mekler MD <amekler(at)metrocast.net>
> Alan
> N668G
> 400 hrs
_-============================================================
_-=
_-=       -- Please Support Your Lists This Month --
_-=           (And Get Some AWESOME FREE Gifts!)
_-=
_-=   November is the Annual List Fund Raiser.  Click on
_-=   the Contribution link below to find out more about
_-=   this year's Terrific Free Incentive Gifts provided
_-=   by:
_-=
_-=     * AeroElectric www.aeroelectric.com
_-=     * The Builder's Bookstore www.buildersbooks.com
_-=     * HomebuiltHELP www.homebuilthelp.com
_-=     * My Pilot Store www.mypilotstore.com
_-=     * Race Consulting www.mrrace.com
_-=
_-=   List Contribution Web Site:
_-=
_-=   --> http://www.matronics.com/contribution
_-=
_-=   Thank you for your generous support!
_-=
_-=                              -Matt Dralle, List Admin.
_-=
_-=          - The RV10-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-=   --> http://www.matronics.com/Navigator?RV10-List
_-=
_-=               - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-=   --> http://forums.matronics.com
_-=
_-=              - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-=   --> http://wiki.matronics.com
_-=             - List Contribution Web Site -
Lenny Iszak
PostPosted: Sun Dec 11, 2016 10:43 am    Post subject: Re: What flap setting do you use for takeoff Reply with quote
Lynn,
It's the other way around. Much shorter ground run with 10 degrees of flaps on takeoff, and way too long with flaps in the reflex (-3) position.
Lenny
flying-nut(at)cfl.rr.com wrote:
I'm going to guess that the added drag of the flaps being down lengthens the takeoff roll. �The takeoff roll is pretty short with the flaps up. �Just a SWAG on my part ..... I'm still painting.
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs
Mike Whisky
PostPosted: Tue Dec 13, 2016 10:33 am    Post subject: Re: What flap setting do you use for takeoff Reply with quote
Attached my Vx / Vy measurements during Phase I it was done with flaps 0 degrees. Would be interesting to see what it would be with 10 or 15 degrees.
 Filesize:  159.37 KB
 Viewed:  15650 Time(s)
RV-10 builder (flying)
#511
glastar(at)gmx.net
PostPosted: Tue Dec 13, 2016 11:50 am    Post subject: What flap setting do you use for takeoff Reply with quote
Mike, just redo your testflights and send the data to Andre Smile and then
you will know.
Cheers Werner
#511
Mike Whisky
PostPosted: Tue Dec 13, 2016 12:07 pm    Post subject: Re: What flap setting do you use for takeoff Reply with quote
Great idea if I ever find the time but an even better suggestion you do it during your Phase 1, just get the -10 done quickly 😉
Saanen LSGK 🇨🇭
 Filesize:  1.59 MB
 Viewed:  15640 Time(s)
#511
glastar(at)gmx.net
PostPosted: Tue Dec 13, 2016 12:34 pm    Post subject: What flap setting do you use for takeoff Reply with quote
I would do that for you but might need help for finishing the remaining
90% Smile
But wait, there is Gordon he should be close Wink
Cheers
Werner
#511
http://forums.matronics.com/viewtopic.php?p=463891#463891
http://forums.matronics.com//files/img_0293_511.jpg
