Flanging tool
LHusky(at)aol.com
PostPosted: Wed Jul 05, 2006 6:55 pm    Post subject: Flanging tool Reply with quote
I believe I have found someone to make my die's.  They will be rather expensive, but I need them and do not have the resource's to make them.  I tried the plywood ones, but all I have is a small band saw.  I would need a compass to make the circle and could not find one in this small "Little house on the Prarie town".  I should have my dies in about a month I am told.  I guess it is time to go work on an engine now.  I will pick up all the core parts from a Corvair guy next week.  I can have it cleaned locally, but everything else I will send out.
I just wanted you guys to know that my dies will be available to any future builder at no charge except shipping.  That is after I have all my holes done!!
Larry Husky
Lakeview, OR
In limbo for now:)
n4546v(at)mindspring.com
PostPosted: Wed Jul 05, 2006 7:28 pm    Post subject: Flanging tool Reply with quote
I bought the steel and machined the dies per the 701 plans, just because I could.  the sizes are 65, 95 & 115 mm.  Does the 601 use the same size dies?  I don't think so.  This is very old hat for experienced listers, but for the new guys, if you wish to see these dies in action, please email and I will forward a picture of them being used in my gravity powered lightning hole press.  I would be happy to loan these out for reasonable periods; months, not years.  They are not lightweight.
Randy L. Thwing, Las Vegas  do not archive
Larry Husky
Lakeview, OR
In limbo for now:)
admin(at)arachnidrobotics
PostPosted: Wed Jul 05, 2006 9:34 pm    Post subject: Flanging tool Reply with quote
    Hey Larry, sorry for putting you on hold for so long.  My schedule has been nuts lately.  I'm spending all tomorrow evening on the punch and brake to finish the last parts of the fuse (sheet metal at least).  I finished the Nylon Pedal Bearings for us.  They actually look pretty darn good.  The Nylon is a dark blue (they call it black in the catalog), which looks a lot better than the neon green from Zenith.
    I knocked out a pair of flanging dies yesterday that actually did a really good job too.  I had to use a rubber mallet and tap around the perimeter to get a crisp edge, but it's not too hard to do.  If you've already ordered yours, let me know what the cost is and I'll split it with you if you want.  (I've kept you waiting long enough it's the least I can do!).  If not, you're more than welcome to the ones I did last night, and the steel ones are due back on the 17th.
    Two of the parts I'm punching and forming tomorrow are parts that you already have.  I screwed up (don't tell anybody you ever heard me say that!)  Part #s 6-W-4-1 and 6-W-4-2 turned out perfect, except for the fact that the large flanged hole is too far towards the top of the parts.  I programmed it 85 mm from the top of the part, rather than the holes above it.  No problem, except a control rod passes through it, and the hole interferes with the 1/4" spar cap as well.  $#%(at).  Anyway, they'll be done tomorrow.
    I finished the spacers (6-W-4-5) for the center wing spar.  I just cut them from aluminum rod and drilled a hole in them.  We'll need to finish the edges a bit, but the thickness turned is good within .010".
    So how goes everything else in the hanger?  Have you got your firewall rivited yet (except for the parts your waiting for!)
Larry Husky
Lakeview, OR
In limbo for now:)
Ok, that last one was meant for Larry.  Sorry list.  (Seems like a lot of us are doing that lately.  lol)
Larry Husky
Lakeview, OR
In limbo for now:)
ch601xl(at)gmail.com
PostPosted: Wed Jul 05, 2006 10:50 pm    Post subject: Flanging tool Reply with quote
Randy, I would like the pictures. Thanks
On 7/5/06, Randy L. Thwing <n4546v(at)mindspring.com (n4546v(at)mindspring.com)> wrote:
Larry Husky
Lakeview, OR
In limbo for now:)
Christopher W. E. Smith
fly1m1
http://ch-601xl.com
Gbrac80(at)aol.com
PostPosted: Thu Jul 06, 2006 1:19 am    Post subject: Flanging tool Reply with quote
Larry,
Hole flanging die:  Make sure that the die has a generous radius where the metal is formed around, or the parts WILL come out cracked.
I use a simple, wooden, 2x4 frame and a hydraulic bottle jack with my die set.  Perfection each and every time.
I apply lots of force (easy to do with hydraulics) to ensure complete forming of the flange.  Too little force and the part distorts from incomplete forming.  I doubt too much force is possible, as the metal first properly forms in the die, then resists further forces in simple compression.  The part comes out with a perfectly formed flanged hole and is otherwise absolutely flat.
Rgds,
Mike.
randy(at)shadycreekoutlaw
PostPosted: Thu Jul 06, 2006 4:58 am    Post subject: Flanging tool Reply with quote
My cousin made a set of flanging dies for he and I to use.  He made a "T Handle" to squeeze the 2 halves together...  These work very well too.  Attached are 2 pics of my dies.
Randy
XL Wings - Plans Only
http://www.n344rb.com
 Filesize:  60.18 KB
 Viewed:  421 Time(s)
 Filesize:  48.09 KB
 Viewed:  398 Time(s)
ggower_99(at)yahoo.com
PostPosted: Thu Jul 06, 2006 9:10 am    Post subject: Flanging tool Reply with quote
Hello Tom,
This is great,  not only that the list is full of help and advise betwen us,  but also that there is some team work, sorry that some of us are international,  customs laws sometimes makes sharing parts or materials  expensive and impractical.
Keep the good work and share it will all of us.
Saludos
Gary Gower
Flying from Chapala, Mexico  (701)
Building a 601 XL.
Larry Husky
Lakeview, OR
In limbo for now:)
Want to be your own boss? Learn how on [url=http://us.rd.yahoo.com/evt=41244/*http://smallbusiness.yahoo.com/r-index] Yahoo! Small Business.[/url]
paulrod36(at)msn.com
PostPosted: Sun Jul 09, 2006 7:13 am    Post subject: Flanging tool Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> COMPASSS? We don' need no esteenkin' compass!  You might try this: Drive a small brad at your selected center point. The loop a piece of thin wire around it, measure out the desired distance, and then wrap the wire around the tip of a pencil. As the French say, viiiola. Perfect circle. Give it a try, you may save a few bucks.
Paul Rodriguez
601XL/Corvair
Working on the canopy
grs-pms(at)comcast.net
PostPosted: Sun Jul 09, 2006 8:41 am    Post subject: Flanging tool Reply with quote
Or space a couple of #40 holes at the desired radius in a strip of scrap aluminum.  Pin in one, pencil in the other and rotate.  Works every time.
George
daberti(at)sbcglobal.net
PostPosted: Sun Jul 09, 2006 9:19 am    Post subject: Flanging tool Reply with quote
Easier yet use a scrap piece of aluminum with 2 holes at the spacing you need place a rivet (not pulled) at the center and put the pencil or marker (better) in the other then swing your arc.  Mark it's size and save for later use!
Dave
