USB Charger
speedy11(at)aol.com
PostPosted: Sat Apr 11, 2015 7:37 pm    Post subject: USB Charger Reply with quote
Interesting to hear the squelch issues with cig lighter outlet USB chargers. I have two that I have used from Daytona Beach to Reno and back without any squelch issues. It is the Energizer model #PC-1CA. I use one for iPad and one for Stratus.
Stan Sutterfield
Reno Race 84
PostPosted: Sun Apr 12, 2015 6:28 am    Post subject: USB Charger Reply with quote
Stan Sutterfield
Reno Race 84
There are chargers . . . then there are CHARGERS.
Small variances in their design and construction
can influence where any antagonistic
behaviors are noted. Unless the device is
designed to suppress the full spectrum of
input frequencies used by potential victims,
it can emit antagonistic energies in little
pockets located anywhere on the spectrum.
So it's entirely possible to find devices that
don't bother YOUR radios on the frequencies
you use . . .while still being a nuisance
to somebody else.
When qualifying to DO160, and depending on
the criticality level of that qualification,
a device is allowed produce greater, potentially
annoying energies outside the spectrum of 'aviation
interests'. As you can see below, the limit lines
for allowed emissions are reduced over frequency
ranges where important airplane business takes place, and
relaxed elsewhere.
[img]cid:.0[/img]
Given that no, commercial off the shelf USB power
adapter will have been so critically evaluated, its
possible to have one that throws tomatoes at ATC
but not Ground Control . . . etc. etc. Even
multiple examples of the same product may demonstrate
different behaviors.
 Filesize:  64.79 KB
 Viewed:  16230 Time(s)
jan_de_jong(at)casema.nl
PostPosted: Sun Apr 12, 2015 10:31 am    Post subject: USB Charger Reply with quote
There's this:
http://www.charge4.co.uk/
Not quite for free though.
Jan de Jong
JOHN TIPTON
PostPosted: Sun Apr 12, 2015 11:38 am    Post subject: USB Charger Reply with quote
Yes: nice quality items, but for us this side of the pond expensive, starting at £99.00 that's about $150.00
----x--O--x----
On 12 Apr 2015, at 07:30 pm, Jan de Jong <jan_de_jong(at)casema.nl> wrote:
There's this:
Jan de Jong
handainc(at)madisoncounty
PostPosted: Mon Apr 13, 2015 7:19 am    Post subject: USB Charger Reply with quote
And none of the panel mounts are in stock.
M. Haught
On Apr 12, 2015, at 2:32 PM, John Tipton <jmtipton(at)btopenworld.com> wrote:
----x--O--x----
> There's this:
> Jan de Jong
b432291
PostPosted: Mon Apr 27, 2015 6:40 am    Post subject: Re: USB Charger Reply with quote
They now have the 4 port ~$190 US Dollars (delivered), and I ordered one of these.
Why you ask would I spend $200 on something I can get for $10 at Walmart?
Noise, noise, and noise.
I've spent thousands of dollars to have quality Comm, and the damn cig lighter chargers wipe all that out with ease. Even kills the FM radio reception.
We'll see if the unit is RF quiet like the guy claims on the website - if it is then it's money well spent.
PostPosted: Mon Apr 27, 2015 6:51 am    Post subject: USB Charger Reply with quote
one of these.
radio reception.
Looking forward to your report sir. Thanks
for sharing.
JCurtis
PostPosted: Thu Jun 18, 2015 8:56 am    Post subject: Re: USB Charger Reply with quote
Hi,
I am the designer and maker of the Charge2 and Charge4 USB chargers mentioned in this tread. A customer let me know about the forum and suggested I register, so I have.
If anyone has questions over the units, please get in touch, I will answer the best I can.
Designer and maker of Charge2 & Charge4
PostPosted: Thu Jun 18, 2015 9:18 am    Post subject: USB Charger Reply with quote
So….you are in the UK? I
M. Haught
On Jun 18, 2015, at 11:56 AM, JCurtis <jeremy.curtis(at)harkwood.co.uk> wrote:
Hi,
Designer and maker of <a href="http://www.charge4.co.uk/" target="_blank">Charge2 &amp; Charge4</a>
http://forums.matronics.com/viewtopic.php?p=443757#443757
JCurtis
PostPosted: Thu Jun 18, 2015 9:23 am    Post subject: Re: USB Charger Reply with quote
handainc(at)madisoncounty wrote:
So�.you are in the UK? I
M. Haught
Yes, based in Cambridge, UK.
So given the time difference, there could be delays in replies.
JohnInReno
PostPosted: Sun Jun 21, 2015 12:21 pm    Post subject: USB Charger Reply with quote
Wow! The "designer and maker" of the product makes himself available to
the list and the subject goes dead. Did I miss something?
john
On 6/18/2015 9:56 AM, JCurtis wrote:
Hi,
John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale
JCurtis
PostPosted: Sun Jun 21, 2015 12:49 pm    Post subject: Re: USB Charger Reply with quote
JohnInReno wrote:
Wow! The "designer and maker" of the product makes himself available to the list and the subject goes dead. Did I miss something?
john
Well, I do try and put information up on the website, but still happy to answer questions via the forum or via e-mail (address on the website).
Jeremy.
JOHN TIPTON
PostPosted: Sun Jun 21, 2015 1:04 pm    Post subject: USB Charger Reply with quote
I think it's indicative of this list that there is a lot of fancy talk, people go on about design criteria, a lot of theorising etc etc, then someone comes along with positive advice from a professional - which puts everyone out on a limb because they know nothing
----x--O--x----
john
> Hi,
bbradburry(at)verizon.net
PostPosted: Sun Jun 21, 2015 2:53 pm    Post subject: USB Charger Reply with quote
Gee Whiz, John!
I have a bad day from time to time as well, and it sometimes results in a
post I wish I had kept to myself. Don't worry about it.
yellowduckduo(at)gmail.co
PostPosted: Sun Jun 21, 2015 3:02 pm    Post subject: USB Charger Reply with quote
That is a very different impression than mine from being on this list
for many years.
Some of us use the shared knowledge and ideas here, make our own
hardware, learn something in the process, and share the result freely
when it seems appropriate...
I never know whose comment might spark a useful thought or lead to a
solution!
Ken
