raymondj(at)frontiernet.n Guest
Posted: Tue Jun 17, 2014 11:36 am Post subject: LED Ghosting |
How about a brighter led, so it's dimmed level will be equal to the others.
Raymond Julian
Kettle River, MN
The things we admire in men, kindness and generosity, openness, honesty,
understanding and feeling are the concomitants of failure in our system.
And those traits we detest, sharpness, greed, acquisitiveness, meanness,
egotism and self-interest are the traits of success. And while men
admire the quality of the first they love the produce of the second.
-John Steinbeck, novelist, Nobel laureate (1902-1968)
On 06/17/2014 02:06 PM, donjohnston wrote:
user9253 wrote:
> I suggest that you put a 1.5k resistor across the LED per the engine analyzer people. Then replace the 390 ohm series resistor with a 330 ohm resistor. Or experiment with different values (all less than 390) to get the desired brightness.
> Or put a pot in series with the dim LED and turn the pot until the current though the dim LED is equal to the current through one of the other LEDs. Then substitute a fixed resistor for the pot.
> 40 years ago I could have calculated the resistor value. Now trial and error is easier.
> Joe
I tried that. I ended up with no series resistor and it was still dimmer than the others.
http://forums.matronics.com/viewtopic.php?p=425032#425032
lyleapgmc
donjohnston
Posted: Tue Jun 17, 2014 1:43 pm Post subject: Re: LED Ghosting |
| nuckolls.bob(at)aeroelect wrote: |
Ooops, two LED's in series . . . should have asked about
that. Okay, I suggest we pay homage to our teachers one
of whom once opined: ". . . when you can measure what you are
speaking about, and express it in numbers, you know something
about it; but when you cannot measure it, when you cannot
express it in numbers, your knowledge is of a meagre and
unsatisfactory kind; it may be the beginning of knowledge,
but you have scarcely in your thoughts advanced to the state
of Science . . ." -Lord Kelvin-
Consider the array of sketches at:
http://tinyurl.com/oxrwae7
I suggest we pay homage to our teachers one of whom once replied: "Dammit Bob, I'm a doctor, not a engineer" -Dr. Leonard McCoy-
Unfortunately, this is a bit beyond my skillset. While the squiggly lines are not quite hieroglyphics to me, I'm not exactly sure what to do with them.
| Quote: | | How about a brighter led, so it's dimmed level will be equal to the others. |
That's a good idea. Except the LEDs that I'm using were the brightest that I could find. So I don't think I'll be able to find any that are brighter and have the same footprint.
| Quote: | | I don't believe you will get satisfactory results with any combination of resistors. I think the only solution is a driver circuit between the output and the LED. A single transistor and a couple of resistors should do it. It may need a separate power source. |
That sounds reasonable. Is this different than the MOSFET solution posted earlier?
Joined: 28 Mar 2008 Posts: 1948 Location: Riley TWP Michigan
Posted: Tue Jun 17, 2014 3:28 pm Post subject: Re: LED Ghosting |
OK, here is another idea. Put a diode (1N4148 ?) in series with each of the bright LEDs. If you are lucky, the voltage drop across the 1N4148 will equal the voltage drop across the oil pressure solid state switch.
Joe
_________________ Joe Gores |
eschlanser
Posted: Wed Jun 18, 2014 5:27 am Post subject: Re: LED Ghosting |
| donjohnston wrote: |
"The engine analyzer people said it was designed for incandescent... " |
Here's a simple solution. Use an incandescent bulb such as this: http://tinyurl.com/kw8usxc
Dennis Johnson
Posted: Wed Jun 18, 2014 5:52 am Post subject: LED Ghosting |
I don't remember specifically which of your instruments has the ghosting problem. I'll tell you my story, which may or may not be relevant, but it may help others with a similar situation as mine.
When I first powered up my instrument panel, the red warning light for my Grand Rapids EIS engine monitor glowed very dimly when the panel was powered up but the engine monitor was turned off. Ghosting went away when I turned the engine monitor on. Like you, I had replaced an incandescent light with an LED. On the bench, the ghosting seemed like a problem.
However, I focused on other, bigger, problems and never got around to fixing the ghosting problem. By the time I completed my flight test phase, I understood that the ghosting was not a problem at all and maybe even a benefit.
I turn the engine monitor on before engine start and leave it on until after engine shutdown. Since ghosting only occurs when the master switch is on and the engine monitor is off, I never see ghosting because the engine monitor is normally on whenever the master switch is on. I now consider ghosting, if I ever see it, to be a warning that I've forgotten to turn the engine monitor on. "It's not a bug, it's a feature."
Good luck,
Dennis
sprocket(at)vx-aviation.c Guest
Posted: Wed Jun 18, 2014 5:56 am Post subject: LED Ghosting |
....so the relay option is looking pretty good right about now. As I mentioned, there is the simple brute force relay method, then the more complicated 'elegant' method.... Elegance is elusive.
Vern
Sent from my iThing. It is responsible for all gramma and typo terrors.
rnjcurtis(at)charter.net Guest
Posted: Wed Jun 18, 2014 6:30 am Post subject: LED Ghosting |
I submitted this a couple of days ago and it seemed to be ignored. Does anyone know why this very simple method would not work??
Perhaps you could use a zener with a voltage just slitely
higher than the open circuit off voltage output. Put that in
series with the LED, to block the small output, and reduce
the series resistor to bring the brightness up.
Roger
Posted: Wed Jun 18, 2014 6:51 am Post subject: LED Ghosting |
At 09:29 AM 6/18/2014, you wrote:
| Quote: | I submitted this a couple of days ago and it seemed to be ignored. Does anyone know why this very simple method would not work??
the series resistor to bring the brightness up. |
Not sure what you're suggesting . . . can
you offer a schematic along with some
description of where the voltage drops are
expected and of what magnitude?
Bob . . . [quote][b]
Posted: Wed Jun 18, 2014 7:02 am Post subject: LED Ghosting |
Dimming wouldn't work very well with an in series zener.
Vern
====================================================Sent from my iThing. It is responsible for all gramma and typo terrors.
On Jun 18, 2014, at 7:29 AM, "Roger & Jean" <rnjcurtis(at)charter.net (rnjcurtis(at)charter.net)> wrote:
[quote] I submitted this a couple of days ago and it seemed to be ignored. Does anyone know why this very simple method would not work??
Roger
Posted: Wed Jun 18, 2014 7:18 am Post subject: LED Ghosting |
| Quote: | Perhaps you could use a zener with a voltage just slitely
I am not familiar with the device outputing the
signal to the LED. Perhaps I am all wet in
assuming these outputs, See attached.
Roger
 Download |
| Filename: |
File1.pdf |
50.9 KB |
| Downloaded: |
649 Time(s) |
Posted: Wed Jun 18, 2014 7:51 am Post subject: LED Ghosting |
It was a legacy practice in aviation annunciator
lamp outputs to offer some way that an annunciator
can tell the pilot that the system driving that
annunciator is OFF. Using the normally closed
contacts of a relay ALWAYS works but if they
can be replaced at less cost, the solid state option is
preferred.
The output circuit depicted in the adaptation of
LED's to the B&C LR series regulators
http://tinyurl.com/cgnwr5k
is an exemplar approach to the task for incandescent
annunciators common to the time. The resistor between
the collector and base of the lamp driver causes
a 'powered down' LR3 to drive an annunciator lamp
into partial conduction . . .
In later years we added a remote sense lead to the
ov/lv detection system which causes the lv warn
to come alive when the bus becomes hot but before
the engine is started and irrespective of the
position of the alternator field switch. This
change of architecture eliminated the value of
'powered down' conduction of the annunciator
sorta went away.
The 'problem' can be eliminated by snipping out
the one-time-useful resistor. I think I'll
suggest that B&C eliminate that resistor in
future production and modify any regulators
that come back for other reasons.
It CAN be eliminated . . . with a massaging of
performance facts . . .
. . . it may have been just that under
alternative design goals. Without benefit of
documentation or conversation with the original
designer . . . its a WAG.
Posted: Wed Jun 18, 2014 8:10 am Post subject: LED Ghosting |
Not sure how to answer this . . . analysis and
resolution of some problems simply does not
move forward without good data.
Putting a resistor across the lamp/resistor
string SHOULD have fixed your problem. But the
narrative of your observed behavior left
me scratching my head . . . too much is
not yet known . . .
[img]cid:.0[/img]
25.35 KB |
18919 Time(s) |
donjohnston
Posted: Wed Jun 18, 2014 11:53 am Post subject: Re: LED Ghosting |
[quote="nuckolls.bob(at)aeroelect"] | Quote: |
not yet known . . .
Bob . . . |
Technically the resistor did fix the problem (ghosting). But it created a new problem (dim LED). So now I'm working on the second problem while not re-introducing the first problem.
donjohnston
Posted: Wed Jun 18, 2014 12:03 pm Post subject: Re: LED Ghosting |
| eschlanser wrote: | | donjohnston wrote: |
Here's a simple solution. Use an incandescent bulb such as this: http://tinyurl.com/kw8usxc |
You are right, it is a solution. Just not very simple. Since I would have to scrap the circuit board that the LEDs are mounted to and design a new one. And since this is a incandescent bulb, it would have to be socketed. Which means redesigning the warning panel assembly to be deep enough to accept the new light bulb. Not sure how I would handle replacing the bulb when it burns out though.
Or I could just scrap the whole warning panel altogether. Then I'd have to fill in that rectangular hole in the panel, drill holes for the 8 warning lights. Come up with the circuit design for the new warning lights. etc., etc., etc.,
Posted: Wed Jun 18, 2014 3:10 pm Post subject: LED Ghosting |
That's the fact that does not make sense. The barefoot
string of two LEDS and a resistor function with a
current level on the order of 15 to 20 milliamps.
(First sketch in the document I published). This
is much lower than the typical incandescent lamp
at 80+ milliamps. Adding the resistor (second sketch)
adds another 12 to 14 milliamps for a total of
27 to 34 milliamps . . . much LOWER than the incandescent
lamp being replaced.
We can continue to flog this topic with all
manner of cut, paste, try, suppose, wish and
propose . . . with poor prospects for fixing
it and poorer prospects for understanding
root cause for the symptoms you've observed.
The second sketch 'fix' should have NO effect
on lamp intensity . . . the fact that it does
have an effect says we don't know squat about
what we're doing . . . yet.
Hence, the 'dim LED' is a mystery that
cannot be resolved without knowing the reason
for what appears to be a reduction of available
voltage. The experiments I asked you to conduct
went toward resolving the mystery.
Posted: Thu Jun 19, 2014 9:47 am Post subject: Re: LED Ghosting |
Resistors can make the oil pressure LED the same brightness as the others under one set of conditions. But when the conditions change (reduced dimmer voltage) the brightness of all LEDs will no longer be the same.
The only way for all LEDs to have the same brightness under all conditions is if each circuit has the same components. A relay can be used to switch the oil pressure LED to make that circuit the same as the other LEDs that use mechanical contacts. Here are possible relays to use: http://tinyurl.com/pt9yd6v or http://tinyurl.com/o3g77dc or http://tinyurl.com/q28mku6
Another option is to modify the other LED circuits to match the oil pressure circuit. Adding a diode to those other circuits might do the trick. The only way to find out is to try it.
The relay is a sure thing but costs more and is harder to install and is less reliable then a solid state solution. Diodes may or may not work but are very inexpensive and easy to install.
Posted: Thu Jun 19, 2014 11:02 am Post subject: LED Ghosting |
Quite true. Stings of led's driven in parallel from a common dimmer
will vistually track each other only when all the strings are
identical. From a pure physics perspective, LED light output is
proportional to the current in the device . . . for values at or
below the device's rated operating point.
The quest for intensity tracking between the various
indicators is purely a matter of average current through the
devices. Suppose the annunciator panel featured in the
start of this thread had two LEDs in some slots, and
single LEDs in others. It's entirely possible that they
could be made to appear identical at some level of illumination
by juggling their series resistors . . . but a bit
of pencil whipping of the numbers will show that as
supply voltage is reduced, the current through a series
string of 2 LEDs will fall off faster than for a single
LED.
The use of a relay to energize an LED string to
emulate the performance of an oil pressure
switch isn't the issue. For all practical
purposes, hard contacts and transistors produce
the same behavior when turned ON for any given
level of 'balanced' illumination. The variances
of configuration don't come into play until the
illumination is adjusted to some new value.
This is why duty cycle switched dimming works so well
for mixed configurations of LED illumination. When you duty-cycle
switch the LED, peak light output remains constant while
the eye integrates a reduced average energy into a perceived
level of brightness that will be more uniform across mixed
configurations.
I wrote the spec for a mix illumination dimmer control
for the Gates Piaggio GP-180 program where the design
goal was to dim 5v incandescent, 28v incandescent and
and 115vac electro-luminescent from a single knob.
Nobody stood up and offered a proposal for that
spec (about 1985). With micro-controllers and lookup
table driven power supplies, it could be done today
but not easily back then.
Joe is right, unless the constellation of illumination
sources have the same configuration, they will not
track each other well with simple adjustment of applied
voltage.
FisherPaulA(at)johndeere. Guest
Posted: Thu Jun 19, 2014 12:16 pm Post subject: LED Ghosting |
I'm confused by this thread. Back to the original issue - why is it important that all of the LEDs in the annunciator panel have the same brightness? Don't you just need to know if any particular one is on or off? Aren't they used to indicate a problem? I would hope that during most flights they would all be off. And if more than one of them was on, I certainly wouldn't be worried about one being brighter or dimmer than another - I'd be busy looking for a place to land!
I do appreciate the electronics discussion about the physics of getting them to the same brightness. I just don't understand why that is important in this use case.
Paul A. Fisher
RV7A N18PF
donjohnston
Posted: Thu Jun 19, 2014 4:49 pm Post subject: Re: LED Ghosting |
| FisherPaulA(at)johndeere. wrote: | I'm confused by this thread. Back to the original issue - why is it important that all of the LEDs in the annunciator panel have the same brightness? Don't you just need to know if any particular one is on or off? Aren't they used to indicate a problem? I would hope that during most flights they would all be off. And if more than one of them was on, I certainly wouldn't be worried about one being brighter or dimmer than another - I'd be busy looking for a place to land!
Paul A. Fisher
RV7A N18PF
Valid question.
The master warning panel (I should probably refer to it as an annunicator panel) also has indicators for when the fuel pump is on and pitot heat is on (those indicators are amber where the low oil pressure, door unsafe, etc. are red).
So you're flying along at night and you have the pitot heat or fuel pump on. The LEDs are rather bright so you dim the indicators. Once you dim those LEDs to a comfortable brightness, that low oil pressure LED will not illuminate at all.
Hopefully tomorrow I will be able to get the voltage readings requested. I also got the MOSFET today so I'll give that a go as well.
