Broken louvre ring support rid
wdjester(at)cox.net
PostPosted: Sat Jun 14, 2014 4:16 pm    Post subject: Broken louvre ring support rid Reply with quote
All: I came back from a flight and found a cooling louver ring support Rod broken. Looking to see if anyone knows where I can get a replacement. Is the lower rod that supports the hook and wire that holds the lower calendar up when the cowling is open. Pictures attached.
<pre><b><font size=3D2 color="#000000" face=3D"courier new,courier">
 Filesize:  512.21 KB
 Viewed:  11085 Time(s)
 Filesize:  491.53 KB
wdjester(at)cox.net
PostPosted: Sat Jun 14, 2014 4:22 pm    Post subject: Broken louvre ring support rid Reply with quote
Make that cowling not calendar...gotta love auto correct.
<image.jpeg>
<image.jpeg>
</b></font></pre>
wdjester(at)cox.net
PostPosted: Sat Jun 14, 2014 4:23 pm    Post subject: Broken louvre ring support rid Reply with quote
And rod not ring.
<image.jpeg>
<image.jpeg>
</b></font></pre>
wdjester(at)cox.net
PostPosted: Sat Jun 14, 2014 5:27 pm    Post subject: Broken louvre ring support rid Reply with quote
Thanks Doug...need the one that hold up the hook and wire on the lower cowling. See photo and thanks again...
On Jun 14, 2014, at 7:55 PM, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
Dave,
In stock, back in the office on monday. On Jun 14, 2014 5:23 PM, "David Jester" <wdjester(at)cox.net (wdjester(at)cox.net)> wrote:
All: I came back from a flight and found a cooling louver ring support Rod broken. Looking to see if anyone knows where I can get a replacement. Is the lower rod that supports the hook and wire that holds the lower calendar up when the cowling is open. Â Pictures attached.
com/Navigator?Yak-List" target="_blank">http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List</a>
RUMS -
cs.com" target="_blank">http://forums.matronics.com">http://forums.matronics.com</a>
ite -
com/contribution" target="_blank">http://www.matronics.com/contribution">http://www.matronics.com/contribution</a>
</b></font></pre></body></html>
ist"">http://www.matronics.com/Navigator?Yak-List
javiercarrascob
PostPosted: Sat Jun 14, 2014 6:47 pm    Post subject: Broken louvre ring support rid Reply with quote
Hi David,
My Yak needs them repair every now and then, I had one rebuild by the local AP when that happens.
Javier
To: yak-list <yak-list(at)matronics.com>
Sent: Saturday, June 14, 2014 8:15 PM
Subject: Broken louvre ring support rid
<pre><b><font size=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
_://www.matronics.com/Navigator?Yak-List" target="_blank">http://www.matronics.com/Navigator?Yak-List">http:=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
_-=3D - MATRONICS WEB FORtronics.com/" target="_blank">http://forums.matronics.com">http://www.matronics.com/contribution">http://www.matronics.com/contribution</a>
_-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
Viperdoc
PostPosted: Sat Jun 14, 2014 8:03 pm    Post subject: Broken louvre ring support rid Reply with quote
The CJ rods fit the YAK. Call doug Sapp.
Doc
> <image.jpeg>
> <image.jpeg>
> </b></font></pre>
Viperdoc
Viperdoc
PostPosted: Sat Jun 14, 2014 8:05 pm    Post subject: Broken louvre ring support rid Reply with quote
Call Doig. A lot cheaper than machining another one
Doc
On Jun 14, 2014, at 9:47 PM, Javier Carrasco <javiercarrascob(at)yahoo.com (javiercarrascob(at)yahoo.com)> wrote:
Hi David,
Javier
From: David Jester <wdjester(at)cox.net (wdjester(at)cox.net)>
To: yak-list <yak-list(at)matronics.com (yak-list(at)matronics.com)>
_://www.matronics.com/Navigator?Yak-List" target="_blank">http://www.matronics.com/Navigator?Yak-List">http:=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3; - MATRONICS WEB FORtronics.com/" target="_blank">http://forums.matronics.com">http://www.matronics.com/contribution">http://www.matronics.com/contribution
[/b]
[/quote]
Viperdoc
dsavarese0812(at)bellsout
PostPosted: Sun Jun 15, 2014 5:08 am    Post subject: Broken louvre ring support rid Reply with quote
Unless I am mistaken, the CJ rods are the same as the ones on the Yak 50, but not exactly the same as the 52's. The difference is the 52's rods have a slotted, countersunk end at the louver ring outside end (which makes them fit flush to the ring) and the CJ's are simply a flattened rod.
Dave Jester, take a look at the end of the rods around the outside of the ring on your 52 and then go look at the rods on your neighbor's CJ's ring.
Dennis
From: Roger Kemp <f16viperdoc(at)me.com> To: "yak-list(at)matronics.com" <yak-list(at)matronics.com> Sent: Saturday, June 14, 2014 11:02 PM Subject: Re: Broken louvre ring support rid
--> Yak-List message posted by: Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)>The CJ rods fit the YAK. Call doug Sapp.DocSent from my iPad> On Jun 14, 2014, at 7:22 PM, Dave Jester <wdjester(at)cox.net (wdjester(at)cox.net)> wrote:> > --> Yak-List message posted by: Dave Jester <wdjester(at)cox.net (wdjester(at)cox.net)>> > Make that cowling not calendar...gotta love auto correct.> > Sent from my iPad> >> On Jun 14, 2014, at 7:15 PM, David Jester <wdjester(at)cox.net (wdjester(at)cox.net)> wrote:>> >> All: I came back from a flight and found a cooling louver ring support Rod broken. Looking to see if anyone knows where I can get a replacement. Is the lower rod that supports the hook and wire that holds the lower calendar up when the cowling is open. Pictures attached.>> <image.jpeg>>> >> >> <image.jpeg>>> >> >> <pre><b><font size=3D2 color="#000000" face=3D"courier new,courier">>> >> >> </b></font></pre>> > > > > http://www.matronics.com/Navigator?Yak-List
wdjester(at)cox.net
PostPosted: Sun Jun 15, 2014 5:13 am    Post subject: Broken louvre ring support rid Reply with quote
Thanks all...Doug has replacements.
Doc
> Sent from my iPad
>> <image.jpeg>
>> <image.jpeg>
>> </b></font></pre>
PostPosted: Sun Jun 15, 2014 5:24 am    Post subject: Broken louvre ring support rid Reply with quote
Oops! I was thinking it was a LOUVER rod. Not the adjustable ring brace rod.
Sorry for my misunderstanding.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
Dennis
From: Roger Kemp <f16viperdoc(at)me.com> (f16viperdoc(at)me.com) To: "yak-list(at)matronics.com" (yak-list(at)matronics.com) <yak-list(at)matronics.com> (yak-list(at)matronics.com) Sent: Saturday, June 14, 2014 11:02 PM Subject: Re: Broken louvre ring support rid
--> Yak-List message posted by: Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)> The CJ rods fit the YAK. Call doug Sapp. Doc Sent from my iPad > On Jun 14, 2014, at 7:22 PM, Dave Jester <wdjester(at)cox.net (wdjester(at)cox.net)> wrote: > > --> Yak-List message posted by: Dave Jester <wdjester(at)cox.net (wdjester(at)cox.net)> > > Make that cowling not calendar...gotta love auto correct. > > Sent from my iPad > >> On Jun 14, 2014, at 7:15 PM, David Jester <wdjester(at)cox.net (wdjester(at)cox.net)> wrote: >> >> All: I came back from a flight and found a cooling louver ring support Rod broken. Looking to see if anyone knows where I can get a replacement. Is the lower rod that supports the hook and wire that holds the lower calendar up when the cowling is open. Pictures attached. >> <image.jpeg> >> >> >> <image.jpeg> >> >> >> <pre><b><font size=3D2 color="#000000" face=3D"courier new,courier"> >> >> >> </b></font></pre> > > > > > http://www.matronics.com/Navigator?Yak-List
[/b]
Viperdoc
PostPosted: Sun Jun 15, 2014 6:52 am    Post subject: Broken louvre ring support rid Reply with quote
Correct Dennis. The YAK 50 louver axels are different and are not interchangeable with the 52. The ring braces rods and ends are though.
Doug has them. I keep a couple of spares just incase. The straight and the 45 degree ones.
Doc
On Jun 15, 2014, at 8:24 AM, "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
Dennis
[/b]
[/quote]
Viperdoc
