wdjester(at)cox.net Guest
Posted: Sat Jun 14, 2014 4:16 pm Post subject: Broken louvre ring support rid |
All: I came back from a flight and found a cooling louver ring support Rod broken. Looking to see if anyone knows where I can get a replacement. Is the lower rod that supports the hook and wire that holds the lower calendar up when the cowling is open. Pictures attached.
<pre><b><font size=3D2 color="#000000" face=3D"courier new,courier">
512.21 KB |
11081 Time(s) |
491.53 KB |
11081 Time(s) |
Posted: Sat Jun 14, 2014 4:22 pm Post subject: Broken louvre ring support rid |
Make that cowling not calendar...gotta love auto correct.
| Quote: | On Jun 14, 2014, at 7:15 PM, David Jester <wdjester(at)cox.net> wrote:
<image.jpeg>
<image.jpeg>
</b></font></pre>
Posted: Sat Jun 14, 2014 4:23 pm Post subject: Broken louvre ring support rid |
And rod not ring.
<image.jpeg>
<image.jpeg>
</b></font></pre>
Posted: Sat Jun 14, 2014 5:27 pm Post subject: Broken louvre ring support rid |
Thanks Doug...need the one that hold up the hook and wire on the lower cowling. See photo and thanks again...
On Jun 14, 2014, at 7:55 PM, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
Dave,
In stock, back in the office on monday. On Jun 14, 2014 5:23 PM, "David Jester" <wdjester(at)cox.net (wdjester(at)cox.net)> wrote: | Quote: | All: I came back from a flight and found a cooling louver ring support Rod broken. Looking to see if anyone knows where I can get a replacement. Is the lower rod that supports the hook and wire that holds the lower calendar up when the cowling is open. Â Pictures attached.
com/Navigator?Yak-List" target="_blank">http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List</a>
RUMS -
cs.com" target="_blank">http://forums.matronics.com">http://forums.matronics.com</a>
ite -
com/contribution" target="_blank">http://www.matronics.com/contribution">http://www.matronics.com/contribution</a>
</b></font></pre></body></html>
ist"">http://www.matronics.com/Navigator?Yak-List
javiercarrascob
Posted: Sat Jun 14, 2014 6:47 pm Post subject: Broken louvre ring support rid |
Hi David,
My Yak needs them repair every now and then, I had one rebuild by the local AP when that happens.
Javier
To: yak-list <yak-list(at)matronics.com>
Sent: Saturday, June 14, 2014 8:15 PM
Subject: Broken louvre ring support rid
<pre><b><font size=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
_://www.matronics.com/Navigator?Yak-List" target="_blank">http://www.matronics.com/Navigator?Yak-List">http:=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
_-=3D - MATRONICS WEB FORtronics.com/" target="_blank">http://forums.matronics.com">http://www.matronics.com/contribution">http://www.matronics.com/contribution</a>
_-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
Viperdoc
Posted: Sat Jun 14, 2014 8:03 pm Post subject: Broken louvre ring support rid |
The CJ rods fit the YAK. Call doug Sapp.
Doc
| Quote: | On Jun 14, 2014, at 7:22 PM, Dave Jester <wdjester(at)cox.net> wrote:
> <image.jpeg>
> <image.jpeg>
> </b></font></pre>
_________________ Viperdoc |
Viperdoc
Posted: Sat Jun 14, 2014 8:05 pm Post subject: Broken louvre ring support rid |
Call Doig. A lot cheaper than machining another one
Doc
On Jun 14, 2014, at 9:47 PM, Javier Carrasco <javiercarrascob(at)yahoo.com (javiercarrascob(at)yahoo.com)> wrote:
[/quote]
Posted: Sun Jun 15, 2014 5:08 am Post subject: Broken louvre ring support rid |
Unless I am mistaken, the CJ rods are the same as the ones on the Yak 50, but not exactly the same as the 52's. The difference is the 52's rods have a slotted, countersunk end at the louver ring outside end (which makes them fit flush to the ring) and the CJ's are simply a flattened rod.
Dave Jester, take a look at the end of the rods around the outside of the ring on your 52 and then go look at the rods on your neighbor's CJ's ring.
Dennis
From: Roger Kemp <f16viperdoc(at)me.com> To: "yak-list(at)matronics.com" <yak-list(at)matronics.com> Sent: Saturday, June 14, 2014 11:02 PM Subject: Re: Broken louvre ring support rid
--> Yak-List message posted by: Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)>The CJ rods fit the YAK. Call doug Sapp.DocSent from my iPad> On Jun 14, 2014, at 7:22 PM, Dave Jester <wdjester(at)cox.net (wdjester(at)cox.net)> wrote:> > --> Yak-List message posted by: Dave Jester <wdjester(at)cox.net (wdjester(at)cox.net)>> > Make that cowling not calendar...gotta love auto correct.> > Sent from my iPad> >> On Jun 14, 2014, at 7:15 PM, David Jester <wdjester(at)cox.net (wdjester(at)cox.net)> wrote:>> >> All: I came back from a flight and found a cooling louver ring support Rod broken. Looking to see if anyone knows where I can get a replacement. Is the lower rod that supports the hook and wire that holds the lower calendar up when the cowling is open. Pictures attached.>> <image.jpeg>>> >> >> <image.jpeg>>> >> >> <pre><b><font size=3D2 color="#000000" face=3D"courier new,courier">>> >> >> </b></font></pre>> > > > > http://www.matronics.com/Navigator?Yak-List
Posted: Sun Jun 15, 2014 5:13 am Post subject: Broken louvre ring support rid |
Thanks all...Doug has replacements.
| Quote: | On Jun 14, 2014, at 11:02 PM, Roger Kemp <f16viperdoc(at)me.com> wrote:
Doc
> Sent from my iPad
>> <image.jpeg>
>> <image.jpeg>
>> </b></font></pre>
Posted: Sun Jun 15, 2014 5:24 am Post subject: Broken louvre ring support rid |
Oops! I was thinking it was a LOUVER rod. Not the adjustable ring brace rod.
Sorry for my misunderstanding.
Dennis
| Quote: | A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1 | On 6/15/2014 8:04 AM, A. Dennis Savarese wrote:
| Quote: | Unless I am mistaken, the CJ rods are the same as the ones on the Yak 50, but not exactly the same as the 52's. The difference is the 52's rods have a slotted, countersunk end at the louver ring outside end (which makes them fit flush to the ring) and the CJ's are simply a flattened rod.
Dennis
From: Roger Kemp <f16viperdoc(at)me.com> (f16viperdoc(at)me.com) To: "yak-list(at)matronics.com" (yak-list(at)matronics.com) <yak-list(at)matronics.com> (yak-list(at)matronics.com) Sent: Saturday, June 14, 2014 11:02 PM Subject: Re: Broken louvre ring support rid
--> Yak-List message posted by: Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)> The CJ rods fit the YAK. Call doug Sapp. Doc Sent from my iPad > On Jun 14, 2014, at 7:22 PM, Dave Jester <wdjester(at)cox.net (wdjester(at)cox.net)> wrote: > > --> Yak-List message posted by: Dave Jester <wdjester(at)cox.net (wdjester(at)cox.net)> > > Make that cowling not calendar...gotta love auto correct. > > Sent from my iPad > >> On Jun 14, 2014, at 7:15 PM, David Jester <wdjester(at)cox.net (wdjester(at)cox.net)> wrote: >> >> All: I came back from a flight and found a cooling louver ring support Rod broken. Looking to see if anyone knows where I can get a replacement. Is the lower rod that supports the hook and wire that holds the lower calendar up when the cowling is open. Pictures attached. >> <image.jpeg> >> >> >> <image.jpeg> >> >> >> <pre><b><font size=3D2 color="#000000" face=3D"courier new,courier"> >> >> >> </b></font></pre> > > > > > http://www.matronics.com/Navigator?Yak-List
[/b] | [b]
Viperdoc
Posted: Sun Jun 15, 2014 6:52 am Post subject: Broken louvre ring support rid |
Correct Dennis. The YAK 50 louver axels are different and are not interchangeable with the 52. The ring braces rods and ends are though.
Doug has them. I keep a couple of spares just incase. The straight and the 45 degree ones.
Doc
On Jun 15, 2014, at 8:24 AM, "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
| Quote: | Oops! I was thinking it was a LOUVER rod. Not the adjustable ring brace rod.
Dennis
334-285-6263
www.yak-52.com
Dennis
[/b] |
[/quote]
