awcbs
Joined: 28 Sep 2010 Posts: 20 Location: kittanning, PA
Posted: Sat Dec 28, 2013 6:39 am Post subject: Mark 3 582 engine mount needed |
Looking for a 582 engine mount for or a mark 3.
Maybe someone has one laying around from an engine upgrade?
Aj
_________________ AJ Waldor
MK3C 503
Phantom 503
Rans S-9 Chaos 503 |
rowedenny
Posted: Sat Dec 28, 2013 11:01 am Post subject: Mark 3 582 engine mount needed |
AJ, Dave Lewis has an extra one I'm going to use on my 670, you are welcome to borrow it to trace it and I may even have some 1/4" plate laying around. Give me a call.
Dennis "Skid" Rowe
Mk3, 690L-70, Leechburg, PA
Quote: | On Dec 28, 2013, at 9:39 AM, "awcbs" <awcbsone(at)windstream.net> wrote:
Aj
AJ Waldor
MK3C 503
Phantom 503
Rans S-9 Chaos 503
http://forums.matronics.com/viewtopic.php?p=416270#416270
rickofudall
Posted: Sun Dec 29, 2013 8:25 am Post subject: Mark 3 582 engine mount needed |
AJ, The 503 and the 582 use the same bolt pattern, 153 X 94 mm.
Rick Girard
On Sat, Dec 28, 2013 at 8:39 AM, awcbs <awcbsone(at)windstream.net (awcbsone(at)windstream.net)> wrote:
Quote: | --> Kolb-List message posted by: "awcbs" <awcbsone(at)windstream.net (awcbsone(at)windstream.net)>
Aj
AJ Waldor
MK3C 503
Phantom 503
Rans S-9 Chaos 503
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
et="_blank">www.mypilotstore.com
"_blank">www.mrrace.com
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
rickofudall
Posted: Sun Dec 29, 2013 8:40 am Post subject: Mark 3 582 engine mount needed |
AJ, Thought of something else. The stock Kolb 503/582 mount plate will not work if you run an "E" gearbox. The starter motor and the Kolb motor mount frame interfere. The engine has to be moved aft 3/4" to gain minimal clearance. I have both plates in a CAD file that I can export in PDF format is you need them.
Rick
On Sun, Dec 29, 2013 at 10:25 AM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Quote: | AJ, The 503 and the 582 use the same bolt pattern, 153 X 94 mm.
Rick Girard
Aj
AJ Waldor
MK3C 503
Phantom 503
Rans S-9 Chaos 503
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
rowedenny
Posted: Sun Dec 29, 2013 8:50 am Post subject: Mark 3 582 engine mount needed |
Funny you should mention this Richard. Dave just ran into this yesterday when mounting his E box to his 582 powered Slingshot. Definitely forward me the plans for the rearward engine plate as I'll also need to make one for my 670 as I am planning on using the E box also. AJ, looks like you nay have a good black anodized engine mount right in your back yard. Lol
Dennis "Skid" Rowe
[quote] On Dec 29, 2013, at 11:40 AM, Richard Girard <aslsa.rng(at)gmail.com> wrote:
Rick
> On Sun, Dec 29, 2013 at 10:25 AM, Richard Girard <aslsa.rng(at)gmail.com> wrote:
> Rick Girard
>> On Sat, Dec 28, 2013 at 8:39 AM, awcbs <awcbsone(at)windstream.net> wrote:
>> Thanks
>> Aj
>> AJ Waldor
>> MK3C 503
>> Phantom 503
>> Rans S-9 Chaos 503
>> ="_blank">http://www.matronics.com/contribution
>> le, List Admin.
>> arget="_blank">http://www.matronics.com/Navigator?Kolb-List
> Zulu Delta
> Mk IIIC
> Thanks, Homer GBYM
> - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
rowedenny
Posted: Sun Dec 29, 2013 8:57 am Post subject: Mark 3 582 engine mount needed |
Looks like a good project for my youngest boys Vo-Tech machinist class.
Dennis "Skid" Rowe
Rick
> Rick Girard
>> Thanks
>> Aj
>> AJ Waldor
>> MK3C 503
>> Phantom 503
>> Rans S-9 Chaos 503
>> le, List Admin.
> Zulu Delta
> Mk IIIC
> Thanks, Homer GBYM
> - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
rickofudall
Posted: Sun Dec 29, 2013 10:34 am Post subject: Mark 3 582 engine mount needed |
Dennis, Here you go. Note that all dimensions are from the center of the Kolb engine mount on the frame. All the radius centers outside the periphery of the plate are offset for a 1" hole saw.
Rick
On Sun, Dec 29, 2013 at 10:49 AM, Dennis Rowe <rowedenny(at)windstream.net (rowedenny(at)windstream.net)> wrote:
Quote: | Funny you should mention this Richard. Dave just ran into this yesterday when mounting his E box to his 582 powered Slingshot. Definitely forward me the plans for the rearward engine plate as I'll also need to make one for my 670 as I am planning on using the E box also. AJ, looks like you nay have a good black anodized engine mount right in your back yard. Lol
Dennis "Skid" RoweMk3, 690L-70, Leechburg, PA
On Dec 29, 2013, at 11:40 AM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Quote: | AJ, Thought of something else. The stock Kolb 503/582 mount plate will not work if you run an "E" gearbox. The starter motor and the Kolb motor mount frame interfere. The engine has to be moved aft 3/4" to gain minimal clearance. I have both plates in a CAD file that I can export in PDF format is you need them.
Rick
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Description: |
 Download |
Filename: |
Engine_mount_plate_582E_2.pdf |
Filesize: |
11.13 KB |
Downloaded: |
343 Time(s) |
awcbs
Posted: Sun Dec 29, 2013 1:38 pm Post subject: Mark 3 582 engine mount needed |
Looks like I at least have one to copy or may end up with the one from Dave. Thanks guys.
On Dec 29, 2013, at 1:34 PM, Richard Girard <aslsa.rng(at)gmail.com> wrote:
[quote] Dennis, Here you go. Note that all dimensions are from the center of the Kolb engine mount on the frame. All the radius centers outside the periphery of the plate are offset for a 1" hole saw.
Rick
On Sun, Dec 29, 2013 at 10:49 AM, Dennis Rowe <rowedenny(at)windstream.net> wrote:
> Dennis "Skid" Rowe
>> Rick
>>> Rick Girard
>>>> Thanks
>>>> Aj
>>>> AJ Waldor
>>>> MK3C 503
>>>> Phantom 503
>>>> Rans S-9 Chaos 503
>>>> Read this topic online here:
>>>> le, List Admin.
>>> Zulu Delta
>>> Mk IIIC
>>> Thanks, Homer GBYM
>>> - Groucho Marx
>> Zulu Delta
>> Mk IIIC
>> Thanks, Homer GBYM
>> - Groucho Marx
> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
MK3C 503
Phantom 503
awcbs
Posted: Sun Dec 29, 2013 1:40 pm Post subject: Mark 3 582 engine mount needed |
Denny. May have to copy your steel gear legs also
Aj
Rick
> Dennis "Skid" Rowe
>> Rick
>>> Rick Girard
>>>> Thanks
>>>> Aj
>>>> AJ Waldor
>>>> MK3C 503
>>>> Phantom 503
>>>> Rans S-9 Chaos 503
>>>> le, List Admin.
>>> Zulu Delta
>>> Mk IIIC
>>> Thanks, Homer GBYM
>>> - Groucho Marx
>> Zulu Delta
>> Mk IIIC
>> Thanks, Homer GBYM
>> - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
MK3C 503
Phantom 503
rowedenny
Posted: Sun Dec 29, 2013 2:11 pm Post subject: Mark 3 582 engine mount needed |
No worries AJ
On Dec 29, 2013, at 4:39 PM, Windstream <awcbsone(at)windstream.net (awcbsone(at)windstream.net)> wrote:
[quote]Denny. May have to copy your steel gear legs also
Aj
On Dec 29, 2013, at 1:34 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Quote: | Dennis, Here you go. Note that all dimensions are from the center of the Kolb engine mount on the frame. All the radius centers outside the periphery of the plate are offset for a 1" hole saw.
Rick
Rick
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
<Engine mount plate 582E 2.pdf>
