Mark 3 582 engine mount needed
awcbs
PostPosted: Sat Dec 28, 2013 6:39 am    Post subject: Mark 3 582 engine mount needed Reply with quote
Looking for a 582 engine mount for or a mark 3.
Maybe someone has one laying around from an engine upgrade?
Aj
AJ Waldor
MK3C 503
Phantom 503
Rans S-9 Chaos 503
rowedenny
PostPosted: Sat Dec 28, 2013 11:01 am    Post subject: Mark 3 582 engine mount needed Reply with quote
AJ, Dave Lewis has an extra one I'm going to use on my 670, you are welcome to borrow it to trace it and I may even have some 1/4" plate laying around. Give me a call.
Dennis "Skid" Rowe
Mk3, 690L-70, Leechburg, PA
Aj
AJ Waldor
MK3C 503
Phantom 503
Rans S-9 Chaos 503
http://forums.matronics.com/viewtopic.php?p=416270#416270
rickofudall
PostPosted: Sun Dec 29, 2013 8:25 am    Post subject: Mark 3 582 engine mount needed Reply with quote
AJ, The 503 and the 582 use the same bolt pattern, 153 X 94 mm.
Rick Girard
On Sat, Dec 28, 2013 at 8:39 AM, awcbs <awcbsone(at)windstream.net (awcbsone(at)windstream.net)> wrote:
--> Kolb-List message posted by: "awcbs" <awcbsone(at)windstream.net (awcbsone(at)windstream.net)>
Aj
AJ Waldor
MK3C 503
Phantom 503
Rans S-9 Chaos 503
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
et="_blank">www.mypilotstore.com
"_blank">www.mrrace.com
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
rickofudall
PostPosted: Sun Dec 29, 2013 8:40 am    Post subject: Mark 3 582 engine mount needed Reply with quote
AJ, Thought of something else. The stock Kolb 503/582 mount plate will not work if you run an "E" gearbox. The starter motor and the Kolb motor mount frame interfere. The engine has to be moved aft 3/4" to gain minimal clearance. I have both plates in a CAD file that I can export in PDF format is you need them.
Rick
On Sun, Dec 29, 2013 at 10:25 AM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Rick Girard
Aj
AJ Waldor
MK3C 503
Phantom 503
Rans S-9 Chaos 503
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
rowedenny
PostPosted: Sun Dec 29, 2013 8:50 am    Post subject: Mark 3 582 engine mount needed Reply with quote
Funny you should mention this Richard. Dave just ran into this yesterday when mounting his E box to his 582 powered Slingshot. Definitely forward me the plans for the rearward engine plate as I'll also need to make one for my 670 as I am planning on using the E box also. AJ, looks like you nay have a good black anodized engine mount right in your back yard. Lol
Dennis "Skid" Rowe
[quote] On Dec 29, 2013, at 11:40 AM, Richard Girard <aslsa.rng(at)gmail.com> wrote:
Rick
> On Sun, Dec 29, 2013 at 10:25 AM, Richard Girard <aslsa.rng(at)gmail.com> wrote:
> Rick Girard
>> On Sat, Dec 28, 2013 at 8:39 AM, awcbs <awcbsone(at)windstream.net> wrote:
>> Thanks
>> Aj
>> AJ Waldor
>> MK3C 503
>> Phantom 503
>> Rans S-9 Chaos 503
>> ="_blank">http://www.matronics.com/contribution
>> le, List Admin.
>> arget="_blank">http://www.matronics.com/Navigator?Kolb-List
> Zulu Delta
> Mk IIIC
> Thanks, Homer GBYM
> - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
rowedenny
PostPosted: Sun Dec 29, 2013 8:57 am    Post subject: Mark 3 582 engine mount needed Reply with quote
Looks like a good project for my youngest boys Vo-Tech machinist class.
Dennis "Skid" Rowe
Rick
> Rick Girard
>> Thanks
>> Aj
>> AJ Waldor
>> MK3C 503
>> Phantom 503
>> Rans S-9 Chaos 503
>> le, List Admin.
> Zulu Delta
> Mk IIIC
> Thanks, Homer GBYM
> - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
rickofudall
PostPosted: Sun Dec 29, 2013 10:34 am    Post subject: Mark 3 582 engine mount needed Reply with quote
Dennis, Here you go. Note that all dimensions are from the center of the Kolb engine mount on the frame. All the radius centers outside the periphery of the plate are offset for a 1" hole saw.
Rick
On Sun, Dec 29, 2013 at 10:49 AM, Dennis Rowe <rowedenny(at)windstream.net (rowedenny(at)windstream.net)> wrote:
Dennis "Skid" RoweMk3, 690L-70, Leechburg, PA
On Dec 29, 2013, at 11:40 AM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Rick
Rick Girard
Aj
AJ Waldor
MK3C 503
Phantom 503
Rans S-9 Chaos 503
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
Engine_mount_plate_582E_2.pdf
 Filename:  Engine_mount_plate_582E_2.pdf
 Filesize:  11.13 KB
 Downloaded:  417 Time(s)
awcbs
PostPosted: Sun Dec 29, 2013 1:38 pm    Post subject: Mark 3 582 engine mount needed Reply with quote
Looks like I at least have one to copy or may end up with the one from Dave. Thanks guys.
On Dec 29, 2013, at 1:34 PM, Richard Girard <aslsa.rng(at)gmail.com> wrote:
[quote] Dennis, Here you go. Note that all dimensions are from the center of the Kolb engine mount on the frame. All the radius centers outside the periphery of the plate are offset for a 1" hole saw.
Rick
On Sun, Dec 29, 2013 at 10:49 AM, Dennis Rowe <rowedenny(at)windstream.net> wrote:
> Dennis "Skid" Rowe
>> Rick
>>> Rick Girard
>>>> Thanks
>>>> Aj
>>>> AJ Waldor
>>>> MK3C 503
>>>> Phantom 503
>>>> Rans S-9 Chaos 503
>>>> Read this topic online here:
>>>> le, List Admin.
>>> Zulu Delta
>>> Mk IIIC
>>> Thanks, Homer GBYM
>>> - Groucho Marx
>> Zulu Delta
>> Mk IIIC
>> Thanks, Homer GBYM
>> - Groucho Marx
> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
AJ Waldor
MK3C 503
Phantom 503
Rans S-9 Chaos 503
awcbs
PostPosted: Sun Dec 29, 2013 1:40 pm    Post subject: Mark 3 582 engine mount needed Reply with quote
Denny. May have to copy your steel gear legs also
Aj
Rick
> Dennis "Skid" Rowe
>> Rick
>>> Rick Girard
>>>> Thanks
>>>> Aj
>>>> AJ Waldor
>>>> MK3C 503
>>>> Phantom 503
>>>> Rans S-9 Chaos 503
>>>> le, List Admin.
>>> Zulu Delta
>>> Mk IIIC
>>> Thanks, Homer GBYM
>>> - Groucho Marx
>> Zulu Delta
>> Mk IIIC
>> Thanks, Homer GBYM
>> - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
AJ Waldor
MK3C 503
Phantom 503
Rans S-9 Chaos 503
rowedenny
PostPosted: Sun Dec 29, 2013 2:11 pm    Post subject: Mark 3 582 engine mount needed Reply with quote
No worries AJ
On Dec 29, 2013, at 4:39 PM, Windstream <awcbsone(at)windstream.net (awcbsone(at)windstream.net)> wrote:
[quote]Denny. May have to copy your steel gear legs also
Aj
On Dec 29, 2013, at 1:34 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Rick
Rick
Rick Girard
Aj
AJ Waldor
MK3C 503
Phantom 503
Rans S-9 Chaos 503
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
<Engine mount plate 582E 2.pdf>
