boom tube dolly
galen shirley
PostPosted: Wed Jun 14, 2006 8:00 pm    Post subject: boom tube dolly Reply with quote
I just saw a picture in the photo gallary of a boom tube dolly made by erich weaver. I could not get an e-mail to go thru to him. Did not see on the list either. Anybody got an idea of what the saddle is made of?
Galen
 Filesize:  26.69 KB
 Viewed:  475 Time(s)
lcottrell
PostPosted: Wed Jun 14, 2006 8:22 pm    Post subject: boom tube dolly Reply with quote
The set up that I have is a plastic water pipe cut in half, just measure the
tube- 6 inches? and buy an 8 or 10 inch diameter piece of the pvc pipe, cut
it in half and put some carpet inside the pipe to cradle the boom tube. The
PVC at that size is big enough and tuff enough to bolt to and handle the
load.
Larry, Oregon
by0ung(at)brigham.net
PostPosted: Thu Jun 15, 2006 5:29 am    Post subject: boom tube dolly Reply with quote
Galen
Erics boom tube dolly is a plastic irrigation  Saddle that fits the 6 inch pipe and has a 2 inch pipe thread outlet….  When in the trailer it is attached to some type of attachment that goes to the floor of his trailer…  during loading and unloading he screws a wheel into the pipe thread attach point….  To try and find the saddle I would try a sprinkler / irrigation  supplier.
Boyd
slyck(at)frontiernet.net
PostPosted: Thu Jun 15, 2006 6:32 am    Post subject: boom tube dolly Reply with quote
That is called a "saddle tee" -should be available at any plumbing
supply.
erich weaver.
either.
Galen
Boyd
galen shirley
PostPosted: Thu Jun 15, 2006 6:01 pm    Post subject: boom tube dolly Reply with quote
Larry, Thanks for the suggestion. DId you attach a wheel to the support?
Galen
[quote]From: "Larry Cottrell" <lcottrell(at)fmtcblue.com>
Reply-To: kolb-list(at)matronics.com
To: <kolb-list(at)matronics.com>
Subject: Re: boom tube dolly
Date: Wed, 14 Jun 2006 22:20:59 -0600
the tube- 6 inches? and buy an 8 or 10 inch diameter piece of the pvc pipe,
cut it in half and put some carpet inside the pipe to cradle the boom tube.
The PVC at that size is big enough and tuff enough to bolt to and handle
the load.
Larry, Oregon
galen shirley
PostPosted: Thu Jun 15, 2006 6:03 pm    Post subject: boom tube dolly Reply with quote
Boyd
Thanks for the info. THose saddles are kind of expensive but may be worth
it.
Galen
To: <kolb-list(at)matronics.com>, <oneaviator(at)msn.com>
Subject: boom tube dolly Date: Thu, 15 Jun 2006 07:24:30 -0600
erich
weaver.
either.
Galen
pipe and has a 2 inch pipe thread outlet.. When in the trailer it is
attached to some type of attachment that goes to the floor of his trailer.
point.. To try and find the saddle I would try a sprinkler / irrigation
supplier.
Boyd
galen shirley
PostPosted: Thu Jun 15, 2006 6:05 pm    Post subject: boom tube dolly Reply with quote
Robert,
Thanks for the info. I checked on price and they are kind of expensive but
probably worth it for the easy of loading.
Galen
Subject: Re: boom tube dolly Date: Thu, 15 Jun 2006 10:29:39
-0400
That is called a "saddle tee" -should be available at any plumbing supply.
>erich weaver.
>either.
>Thanks
>Galen
>Boyd
lcottrell
PostPosted: Thu Jun 15, 2006 6:40 pm    Post subject: boom tube dolly Reply with quote
