galen shirley
Joined: 09 Apr 2006 Posts: 12 Location: Show Low Arizona
Posted: Wed Jun 14, 2006 8:00 pm Post subject: boom tube dolly |
I just saw a picture in the photo gallary of a boom tube dolly made by erich weaver. I could not get an e-mail to go thru to him. Did not see on the list either. Anybody got an idea of what the saddle is made of?
Galen
26.69 KB |
475 Time(s) |
lcottrell
Posted: Wed Jun 14, 2006 8:22 pm Post subject: boom tube dolly |
The set up that I have is a plastic water pipe cut in half, just measure the
tube- 6 inches? and buy an 8 or 10 inch diameter piece of the pvc pipe, cut
it in half and put some carpet inside the pipe to cradle the boom tube. The
PVC at that size is big enough and tuff enough to bolt to and handle the
load.
Larry, Oregon
by0ung(at)brigham.net Guest
Posted: Thu Jun 15, 2006 5:29 am Post subject: boom tube dolly |
Galen
| Quote: | >>>>>>>>>>>>>>>>
Erics boom tube dolly is a plastic irrigation Saddle that fits the 6 inch pipe and has a 2 inch pipe thread outlet…. When in the trailer it is attached to some type of attachment that goes to the floor of his trailer… during loading and unloading he screws a wheel into the pipe thread attach point…. To try and find the saddle I would try a sprinkler / irrigation supplier.
Boyd
Posted: Thu Jun 15, 2006 6:32 am Post subject: boom tube dolly |
That is called a "saddle tee" -should be available at any plumbing
supply.
On 15, Jun 2006, at 9:24 AM, boyd wrote:
erich weaver.
either.
Galen
Boyd
galen shirley
Posted: Thu Jun 15, 2006 6:01 pm Post subject: boom tube dolly |
Larry, Thanks for the suggestion. DId you attach a wheel to the support?
Galen
[quote]From: "Larry Cottrell" <lcottrell(at)fmtcblue.com>
Reply-To: kolb-list(at)matronics.com
To: <kolb-list(at)matronics.com>
Subject: Re: boom tube dolly
Date: Wed, 14 Jun 2006 22:20:59 -0600
the tube- 6 inches? and buy an 8 or 10 inch diameter piece of the pvc pipe,
cut it in half and put some carpet inside the pipe to cradle the boom tube.
The PVC at that size is big enough and tuff enough to bolt to and handle
the load.
Larry, Oregon
galen shirley
Posted: Thu Jun 15, 2006 6:03 pm Post subject: boom tube dolly |
Boyd
Thanks for the info. THose saddles are kind of expensive but may be worth
it.
Galen
| Quote: | From: "boyd" <by0ung(at)brigham.net>
To: <kolb-list(at)matronics.com>, <oneaviator(at)msn.com>
Subject: boom tube dolly Date: Thu, 15 Jun 2006 07:24:30 -0600
erich
weaver.
either.
Galen
pipe and has a 2 inch pipe thread outlet.. When in the trailer it is
attached to some type of attachment that goes to the floor of his trailer.
point.. To try and find the saddle I would try a sprinkler / irrigation
supplier.
Boyd
galen shirley
Posted: Thu Jun 15, 2006 6:05 pm Post subject: boom tube dolly |
Robert,
Thanks for the info. I checked on price and they are kind of expensive but
probably worth it for the easy of loading.
Galen
| Quote: | From: robert bean <slyck(at)frontiernet.net>
Subject: Re: boom tube dolly Date: Thu, 15 Jun 2006 10:29:39
-0400
That is called a "saddle tee" -should be available at any plumbing supply.
>erich weaver.
>either.
>Thanks
>Galen
>Boyd
lcottrell
Posted: Thu Jun 15, 2006 6:40 pm Post subject: boom tube dolly |
