Rotax 912 mounting options?....
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List
mjb777
PostPosted: Tue May 21, 2013 1:18 am    Post subject: Rotax 912 mounting options?.... Reply with quote
Howdy again,
I have just purchased a Rotax 912 engine which I am sure will please some of you who were horrified at my plans to use an Aerovee VW in place of the Rotax 582 engine in my Pulsar!
Can the experts out there let me know what are my options regarding engine mounting? I recall seeing some pictures of conventionally (frame) mounted, and also some bed mounted 912's in pulsars???
Also, does anyone have a full set of construction manuals (.PDF would be excellent!), for the XP??
Matt.
- The Matronics Pulsar-List Email Forum -
http://www.matronics.com/Navigator?Pulsar-List
Pulsar 1 TD Kit.
Captain B777.
Licenced Aircraft Maintenance Engineer.
gregsmi
PostPosted: Tue May 21, 2013 1:53 am    Post subject: Rotax 912 mounting options?.... Reply with quote
Matt, if your Pulsar is truly a Pulsar 1, with a header tank, there is a good possibility the fuselage and tail section are not designed to take the extra load of a 912. Depending on the serial number, the early Pulsar kits were manufactured for the 582. The factory used a light weight glass for the fuselage. When the 912 was introduced in the XP, the fuel was moved to the wings, the fuselage was manufactured with a heavier glass, and the tail section was beefed up. I do not see anyway a early model Pulsar can be safely converted to a 912 XP.
Greg
In a message dated 5/21/2013 4:21:40 A.M. Central Daylight Time, mattbrock777(at)gmail.com writes:
--> Pulsar-List message posted by: "mjb777" <mattbrock777(at)gmail.com>
Howdy again,
Matt.
Pulsar 1 TD Kit.
Captain B777.
http://forums.matronics.com/viewtopic.php?p=401052#401052
gregsmi
PostPosted: Tue May 21, 2013 10:29 am    Post subject: Rotax 912 mounting options?.... Reply with quote
Matt, in a private message to me, you asked for information on how to modify the Pulsar 1 to accommodate a 912 engine. Since you started the subject on the forum, and others have asked the same questions in the past, I thought it best to repeat the answers for everyone.
If you want to completely rebuild the airplane, then I guess it is possible. I will give you a few key parts that should be addressed then you can decide if the project is worth it or you want to do it your way.
1. With the extra weight of the 912, the fuel must be moved to the wings. You do not have enough elevator to handle a landing with that much weight on the nose and flight performance, stalls, a lot of safety issues. Dropping the nose on at higher speeds, with all that additional weight is risking a gear failure.
2. The wood spars will not carry more than 900 pounds gross, and then, only if they are the wood spars that had a long spar cap. If this is one of the early 582 Pulsars with the short spar caps, the gross is much less than 900 pounds.
3. The fuselage is made with 3 oz glass on the inside for the 582, The 912 Pulsar XP fuselage and tail surfaces are made with 9 oz. glass.
4. The horizontal spar tubes are much stronger in the 912 Pulsar.
These are just some of the differences. The 912 Pulsar was not just a 582 Pulsar with a few minor changes. The plane went through a lot of design analysis to handle the weight and performance of the 912 engine.
Matt, given the above facts, there is no way I would recommend or support such a project. There are way too many safety concerns. Even if you found a way to move the fuel, reinforce the fuselage, and rebuild the tail, you would be making the plane so heavy the spars would not safely take the load. And, if you found some way to beef up the spars, remember, the attach points in the fuselage are still to the 3 oz fuselage skins.
mjb777
PostPosted: Wed May 22, 2013 5:24 pm    Post subject: Re: Rotax 912 mounting options?.... Reply with quote
Thanks for that information Greg,
I have started an analysis on wing, wing/ gear mounting and fuselage loads and reinforcement. (I commenced this a while ago using the Aerovee VW engine). Once loads are calculated, I'll be looking at reinforcing the inside surfaces of the fuselage shells with uni-directional tape which would allow me to distribute loads more specifically and accurately, to give the same or greater strength as the additional 6 Oz of glass used in th XP, but use a lot less material and therefore result in less weight. It would look like a 2D composite version of a steel truss type structure projected onto the shells. (Same theory as the load bearing structure created by the tape used to reinforce the lower engine cowling/ mount).
the Landing gear and wing "box" structure will be reinforced accordingly after analysis and design, and the fuselage and tail analysis goes from there. It also starts at the engine mounts (bed at this stage) and load paths are also developed and combined. I have been looking into either a pure carbon or aluminium horizontal stab tube and would be interested to know the wall thickness of the XP horizontal stab aluminium tube as it would help to be able to compare my calculated required strengths and modulus to what was originally used with the XP there also.
As far as the fuel tank problem is concerned, I have a copy of the wing tank supplement and at this stage my intention is to make fully molded wing tanks which mount the same way as the XP wooden spar version, but will have less joins and fiberglass ribs to remove/ reduce the likelihood of foam rib and leakage issues. I'll also be using ethanol resistant resin. (Of course I wont bother if the C of G element of the analysis works with the "header" style tank, it's a "Plan B" thing).
I can assure you that all of my calculations will be checked by an aeronautical engineer prior to construction. Components, the entire airframe and flying surfaces will be static load tested. Standard stuff and a lot more thought and testing than most re engined/ modified homebuilt aircraft get, (Probably Pulsars included!). I'm not looking to go faster or make it aerobatic.
I have seen pictures of Pulsar 1's converted to Jabiru 2200 engines using a bed mount and with the header tank, and it has been recommended to me to use the Jabiru engine previously, it appears to have a very similar weight to the 912? I'm guessing these aircraft wouldn't have been structurally improved and probably only had the 900lb spar at maximum? (See Pictures of one example).
My AC is a Tail dragger so the nose gear failure issue isn't a concern. We will use the Grove aluminium gear. (The original fiberglass/ foam gear is still available if someone needs it, but its not worth my job trying to "sneak" it along for a ride in the 777. The guys I fly for don't have much of a sense of humor!).
Why would I bother going through this instead of disposing of my kit and doing it the easy way? I have the kit, it is a great Aircraft with loads of potential, and this is what sport aviation is all about when done properly! (.......And Sonex's don't have the curves!).
So........... do you have the XP manuals available? Wink
 Filesize:  48.14 KB
 Viewed:  11405 Time(s)
 Filesize:  31.66 KB
Pulsar 1 TD Kit.
Captain B777.
gregsmi
PostPosted: Wed May 22, 2013 6:25 pm    Post subject: Rotax 912 mounting options?.... Reply with quote
Your assumption on the Jabiru weights is wrong. The 2200 Jabiru is 15 pounds heavier than the installed wet weight of the 582, making it a good swap. Do not forget, the gross weight is limited by the wood spars.
I am sorry Matt, I cannot support you in this endeavor. You are using a proven design to make a new airplane. When you are done, it may look like a Pulsar, but with all of the modifications, it will become your own design. If you want a 912 Pulsar there are plenty of those out there and I am sure you can find one for sale. There is one on Barnstormers.
Greg
In a message dated 5/22/2013 8:27:21 P.M. Central Daylight Time, mattbrock777(at)gmail.com writes:
--> Pulsar-List message posted by: "mjb777" mattbrock777(at)gmail.com (mattbrock777(at)gmail.com)
So........... do you have the XP manuals available?  [Wink]
Pulsar 1 TD Kit.
Captain B777.
http://forums.matronics.com/viewtopic.php?p=401159#401159
http://forums.matronics.com//files/5920_4_pulengine_162.jpg
http://forums.matronics.com//files/5920_6_pulintake_453.jpg
mjb777
PostPosted: Wed May 22, 2013 6:53 pm    Post subject: Re: Rotax 912 mounting options?.... Reply with quote
No assumptions Greg, the Rotax and Jabiru websites have the weights with exhaust etc and they are pretty much the same, so I'd like to hear your opinion on that?
I fully understand the wood spar limitation and am not intending to exceed it?
At the end of the day all I am requesting is a copy of the XP manuals for reference.
If anyone has a set that I can get a hard or electronic copy of then please let me know. I am happy to pay.
mattbrock777(at)gmail(dot)com
Pulsar 1 TD Kit.
Captain B777.
gregsmi
PostPosted: Wed May 22, 2013 8:08 pm    Post subject: Rotax 912 mounting options?.... Reply with quote
Matt, you are making some bad assumptions on weight. The web sights do not give you install weight.
In a message dated 5/22/2013 9:56:51 P.M. Central Daylight Time, mattbrock777(at)gmail.com writes:
Pulsar 1 TD Kit.
Captain B777.
http://forums.matronics.com/viewtopic.php?p=401167#401167
kdpalmer(at)mweb.co.za
PostPosted: Wed May 22, 2013 9:19 pm    Post subject: Rotax 912 mounting options?.... Reply with quote
Matt,
The failure in an aircraft is based on it's weakest point, do you
know where the Pulsars weakest point is based on it's current construction -
NO
K'd
briana(at)xtra.co.nz
Matt,
I have a 912 in a Pulsar XP. I also have a Jabiru in my new Flitzer. I can assure you that there is a significant difference in the installed weight.
FWIW, the installed weight that I used for determine the engine mount measurements for my Flitzer was about 140lbs, everything included. The CofG turned out to be exactly correct. The specified "ramp weight" in the manual says 134lbs. Close enough considering mine has a heavier exhaust system.
On the other hand, the manual for the Rotax 912 lists the dry weight, plus a lot of components separately, and then you have to add the oil tank, radiator, oil cooler etc etc and the fluids. By the time everything is included you will be over 160lbs.
Why are you aiming to re-engineer a perfectly good design - - - one that we know works already. Having installed the Jabiru I can't imagine how one could be fitted to a "bed" mount of the type used for the 912 in the Pulsar XP.
I can only reinforce Greg's point of view. Those of us who have built Pulsars, in accordance with the manuals, know that everything works well, and I'm sure we have a deal of admiration for the designer. The resulting performance is brilliant. There have been many changes as the design evolved over the years, all for good reasons.
Of course you are free to do whatever you want, but please don't call the result a Pulsar. It won't be. It will be a new experimental that looks like a Pulsar. Think also about the approval process for a new design. Oh, and where are the manuals that came with the kit ? The XP manuals tell you how to bold the kit. They don't give you all the dimensions and specifications for all the components.
I think that most of my fellow Pulsar builders would be horrified at what you are planning to do.
Brian
Pulsar 1 TD Kit.
Captain B777.
ccoulter(at)wavecable.com
PostPosted: Thu May 23, 2013 9:43 am    Post subject: Rotax 912 mounting options?.... Reply with quote
I have not seen anyone mention that the 582 Pulsars had
blue foam ribs. If you move the fuel to the wings the
fuel fumes will eat up the ribs.
Clarke
On Wed, 22 May 2013 22:22:56 -0400 (EDT)
Jabiru is 15
spars.
You are using a
it may look like a
there and I am sure
Barnstormers.
Greg
Daylight Time,
_mattbrock777(at)gmail.com_
(mailto:mattbrock777(at)gmail.com)
and fuselage loads
the Aerovee VW
projected onto the
analysis goes from
into either a pure
as it would help to
modulus to what was
copy of the wing
works with the
checked by an
faster or make it
aerobatic.
2200 engines using
very similar weight
been structurally
example).
isn't a concern. We
my job trying to
a sense of humor!).
when done properly!
[Wink]
Pulsar 1 TD Kit.
Captain B777.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List All times are GMT - 8 Hours
