uuccio(at)gmail.com Guest
Posted: Tue Oct 23, 2012 4:57 am Post subject: New fuel pump for 912 part number 893110 |
Hi List
I had to replace my fuel pump today and bought the new fuel pump, part number 893110. Anyone know what the third barb is for (looks like a fuel overflow) and how it should be installed? I can't find the manual for it anywhere on the web.
Sacha
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
joeing701(at)simnet.is Guest
Posted: Tue Oct 23, 2012 5:47 am Post subject: New fuel pump for 912 part number 893110 |
Hello Sacha.
You are correct, it is a fuel overflow if the pump fails.
Best regards,
Johann G.
Z701
----- Upprunaleg skilaboð -----
Frá: "Sacha" <uuccio(at)gmail.com>
Til: rotaxengines-list(at)matronics.com
Sent: Þriðjudagur, 23. Október, 2012 12:55:57
Efni: New fuel pump for 912 part number 893110
Hi List
Sacha
Posted: Tue Oct 23, 2012 1:04 pm Post subject: New fuel pump for 912 part number 893110 |
Thanks Johann
Does anyone have a pointer to some installation instructions? I have asked the retailer and Rotax so far but still waiting for a response.
Sacha
On Oct 23, 2012, at 15:46, joeing701(at)simnet.is wrote:
Quote: |
Hello Sacha.
Best regards,
Johann G.
Z701
Hi List
Sacha
Roger Lee
Posted: Tue Oct 23, 2012 6:51 pm Post subject: Re: New fuel pump for 912 part number 893110 |
Hi Sacha,
Attach a hose (it can be of the clear plastic type) to your third nipple. It is a drain. Run it down and out any where you want to the edge of the cowling or opening. Do not put it out in the air stream.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Tue Oct 23, 2012 7:02 pm Post subject: New fuel pump for 912 part number 893110 |
Johann and Roger
Thank you
BARRY CHECK 6
Posted: Tue Oct 23, 2012 8:08 pm Post subject: New fuel pump for 912 part number 893110 |
If it is a drain line for gas why would you put on a clear plastic line? Better to use an aluminum line or if you are really pressed a Tygon (yellow) plastic line. At least with the Tygon you know the fuel will not attack it and possibly cause a collapsed line; where you will loose your venting. Why is putting it out in the air stream a problem?
Barry
On Tue, Oct 23, 2012 at 10:51 PM, Roger Lee <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)> wrote:
[quote] --> RotaxEngines-List message posted by: "Roger Lee" <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)>
Hi Sacha,
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center - Heavy Maint. Rated
Home [url=tel:520-574-1080]520-574-1080[/url] TRY HOME FIRST
Cell [url=tel:520-349-7056]520-349-7056[/url]
http://forums.matronics.com/viewtopic.php?p=385903#385903
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
bob(at)fly-ul.com Guest
Posted: Tue Oct 23, 2012 9:18 pm Post subject: New fuel pump for 912 part number 893110 |
According to Rotax that can change the pressure. And yes, Rotax does want a line connected to that nipple as opposed to not attaching a hose to it (to prevent fuel from dripping down onto the hot exhaust)
Bob Comperini
On Oct 23, 2012, at 9:08 PM, FLYaDIVE <flyadive(at)gmail.com> wrote:
Quote: | Why is putting it out in the air stream a problem?
Barry
peteohms
Posted: Wed Oct 24, 2012 3:25 am Post subject: New fuel pump for 912 part number 893110 |
Barry,
You should'nt doubt what Roger says. He knows more about Rotax 9 series engines than anyone I know. I use the clear plastic hose from an oxygen cannula for the overflow on my Rotax carbs. Works great and last for years.
Pete
On Oct 23, 2012, at 11:08 PM, FLYaDIVE <flyadive(at)gmail.com (flyadive(at)gmail.com)> wrote:
[quote]If it is a drain line for gas why would you put on a clear plastic line? Better to use an aluminum line or if you are really pressed a Tygon (yellow) plastic line. At least with the Tygon you know the fuel will not attack it and possibly cause a collapsed line; where you will loose your venting. Why is putting it out in the air stream a problem?
Barry
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
Roger Lee
Posted: Wed Oct 24, 2012 6:38 pm Post subject: Re: New fuel pump for 912 part number 893110 |
It's just a drain hose if the fuel pump pukes any fuel. It most likely won't happen. It doesn't hold any fuel and it should just sit there for the "just in case" moment. It's just a way to route any dumped fuel away from the engine if such an event would occur.
If you don't want to use plastic tubing then use fuel line. It doesn't matter it should stay empty.
Tucson, Az.
Cell 520-349-7056 |
BARRY CHECK 6
Posted: Thu Oct 25, 2012 9:32 am Post subject: New fuel pump for 912 part number 893110 |
Pete:
Davehr'yay, noh praver'yay --- Trust but Verify.
Only a fool follows blindly. And why would you use such an odd ball undocumented item (your oxygen cannula tubing)? There are clearly better items for the handling of gas; approved items.. All you have to do is read AC 43-13.
Roger's knowledge in not in question. His reasoning is. Maybe Roger would explain why he recommends non approved item for handling gas.
W.W.R.D. [What Would Rotax Do?]
I just read Roger's response: " It's just a drain hose if the fuel pump pukes any fuel. It most likely won't happen. It doesn't hold any fuel and it should just sit there for the "just in case" moment. It's just a way to route any dumped fuel away from the engine if such an event would occur."
This is acceptable to you! If it is so benign why not use a paper straw? It would be so much easier to use a proper item that is fuel approved. It is not like it is expensive or difficult to obtain.
Barry
http://www.youtube.com/embed/Fos4EPUOsHo?feature=player_embedded
On Wed, Oct 24, 2012 at 7:25 AM, Pete Christensen <pchristensen10(at)austin.rr.com (pchristensen10(at)austin.rr.com)> wrote:
[quote]Barry,
Pete
Quote: | If it is a drain line for gas why would you put on a clear plastic line? Better to use an aluminum line or if you are really pressed a Tygon (yellow) plastic line. At least with the Tygon you know the fuel will not attack it and possibly cause a collapsed line; where you will loose your venting. Why is putting it out in the air stream a problem?
Barry
Quote: | --> RotaxEngines-List message posted by: "Roger Lee" <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)>
Hi Sacha,
Roger Lee
Tucson, Az.
peteohms
Posted: Thu Oct 25, 2012 10:43 am Post subject: New fuel pump for 912 part number 893110 |
I fly an experimental. I'm experimenting. Get over it.
Pete
On Oct 25, 2012, at 12:31 PM, FLYaDIVE <flyadive(at)gmail.com (flyadive(at)gmail.com)> wrote:
[quote]Pete:
Barry
Pete
Barry
Hi Sacha,
Roger Lee
Tucson, Az.
Leander, TX
rickofudall
Posted: Thu Oct 25, 2012 7:45 pm Post subject: New fuel pump for 912 part number 893110 |
Barry, Here's Roger's original recommendation:"Attach a hose (it can be of the clear plastic type) to your third nipple. It is a drain. Run it down and out any where you want to the edge of the cowling or opening. Do not put it out in the air stream."
I don't see where his recommendation is to use something that's completely incompatible with gasoline. Plastic takes in a lot of territory. I've attached McMaster Carr's Chemical Compatibility chart for just one type that I picked out, PVC. Some is recommended for gasoline, some isn't, and this chart is for tubing that will hold gasoline, not just sit there holding nothing but air, waiting for some gas to run through it.
Pete didn't specify anything either, other oxygen system cannula tubing. No chemical formulation. Again, takes in a lot of territory.
How exactly is your wise council any better? Use aluminum you say. What alloy? What hardness? Work hardened? Heat treated? WTF?
My ex-wife liked to leap to conclusions and start running her mouth. That was the primary reason I booted her fat butt out the door.
Rick Girard
On Thu, Oct 25, 2012 at 1:52 PM, FLYaDIVE <flyadive(at)gmail.com (flyadive(at)gmail.com)> wrote:
Quote: | Pete:
Did you build the plane?
Barry
On Thu, Oct 25, 2012 at 2:42 PM, Pete Christensen <pchristensen10(at)austin.rr.com (pchristensen10(at)austin.rr.com)> wrote:
Quote: | I fly an experimental. I'm experimenting. Get over it.
Pete
Barry
Pete
Barry
Hi Sacha,
Roger Lee
Tucson, Az.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Description: |
 Download |
Filename: |
McMaster_Carr_Chemical_compatibility_chart.pdf |
Filesize: |
544.14 KB |
Downloaded: |
5011 Time(s) |
