Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Sat Sep 29, 2012 3:04 pm Post subject: Fixed Aileron Trim Tab |
Hello All.
Europa 914 Tri gear, Speed 125 kts in level flight, to keep the ball in the centre i have to hold on left rudder.
The Rudder has a fixed Trim Tab which servo,s the rudder to the left ( same as holding left rudder on)
But to maintain the ball in the centre i have to hold on more left rudder on and hold the stick to the right,
If i look out at my left Aileron i can see its about the thickness of the tip trailing edge down.
So i need more lift on the left wing to maintain lateral level. ( How can i achieve this ?)
1. If i put a fixed trim tab on the right aileron it will servo raise the aileron and keep the wings level, but i will have constant adverse drag
maybe only a very small amount, Also will a fixed aileron tab effect the mass balance of the ailerons, ( its only 4” x 1 1/2” of very thin alloy plate)
2. If i fix a Tab to the left flap outer edge, could i generate sufficient extra lift to compensate, so the ailerons remain in line (neutral).
Alan
bill.sue(at)orcon.net.nz Guest
Posted: Sat Sep 29, 2012 4:54 pm Post subject: Fixed Aileron Trim Tab |
Alan,
What I did to correct the same problem was to put a stop in to keep the port flap down sightly when fully retracted. Mine is a mono so a bit different to the Tri gear to achieve. It certainly worked for me and had not effect on performance.
For aileron trim to balance between one up and fully loaded I have a small bungee cord from the lower part of the stick to the tunnel. I only need this when one up as fully loaded my plane is balanced.
ZK CHV
Mono 914 Airmaster
1020hrs
And just for interest, yesterday I attended the first flight of a DeHavilland Mosquito FB26 at Ardmore Airport in NZ.
This is the only flying Mosquito in the world and was built scratch from the original plans in New Zealand.
Two Rolls Royce Merlins together makes a wonderful sound.
[img]cid:part1.09000400.03080304(at)orcon.net.nz[/img]
Sue and Bill Sisley
On 30/09/2012 12:04 p.m., Alan Carter wrote:
| Quote: | | Quote: | --> Europa-List message posted by: "Alan Carter" <alancarteresq(at)onetel.net> (alancarteresq(at)onetel.net)
Hello All.
maybe only a very small amount, Also will a fixed aileron tab effect the mass balance of the ailerons, ( its only 4†x 1 1/2†of very thin alloy plate)
Alan
http://forums.matronics.com/viewtopic.php?p=384264#384264
19.51 KB |
13425 Time(s) |
rlborger(at)mac.com Guest
Posted: Sat Sep 29, 2012 6:04 pm Post subject: Fixed Aileron Trim Tab |
Bill & Others,
Dang! I was hoping that would be Ardmore, Oklahoma. Would I love to see that Mosquito fly in person.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com (rlborger(at)mac.com)
On Sep 29, 2012, at 7:53 PM, bill <bill.sue(at)orcon.net.nz (bill.sue(at)orcon.net.nz)> wrote:
Alan,
<Snip>
ZK CHV
Mono 914 Airmaster
1020hrs
<548234_422729257784507_537658472_n.jpg>
Sue and Bill Sisley
europa471
Posted: Sun Sep 30, 2012 12:35 am Post subject: Fixed Aileron Trim Tab |
Maybe you will one day. I believe it is owned by an American so he will take it home eventually.
Meanwhile have a look at this and others.
https://www.youtube.com/watch?feature=player_detailpage&v=7vQOY3d89JE
Lance Sandford
On 30/09/12 12:02, Robert Borger wrote:
[quote] Bill & Others,
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
Alan Carter
Posted: Sun Sep 30, 2012 2:22 am Post subject: Re: Fixed Aileron Trim Tab |
Hi Sue and Bill, Howdy Bob.
What a lovely country you live in NZ, i visited a few years ago and it brought back memory's of Old England , that a compliment.
My favourite Aeroplane, nothing could catch it in WW2, and the later version had a pressurized cockpit, very tricky on one engine go around.
My neighbour now 95 was a Mossy Pilot, so i know a little about them.
We had one over here but crashed just after completion, over here they get the Who you Knows to fly them, and Not the What you Knows so they crash.
Hope that's not the case in NZ.
My Trim, Yes a little bit of differential on the Flap would do it, but i don,t know how to do it ?, as far as i know there is a Cross Bar into which the pins on each flap locate into, so both move together,
so if say i physically restricted one flap slightly it would twist the cross bar slight, not good, relocating the actual flap bracket and pin is OK, but i am not up to that expertise.
So i was considering a fixed trim tab on the Flaps outer trailing edge but would just the tab generate enough lift,?? ( i can manage to make and glue or should i say bond a tab on)
I find i need this left rudder with one or two up
The rubber Bungee , is that,s just from the control stick to the centre tunnel, to hold the stick slight over is that right. A fixed aileron tab would do this, but i suppose a Bungee may be adjustable
Simple but maybe practical.
Alan
Duncan McFadyean
Posted: Sun Sep 30, 2012 2:44 am Post subject: Fixed Aileron Trim Tab |
<<..if say i physically restricted one flap slightly it would twist the
cross bar slight, not good,>>
That situation is already built in to the design, because the actuating horn
welded to the cross bar is located off centre. Which (due to the elasticity
of the cross bar) results in the cross bar twisting and the port side
retracting slightly ahead of the s'bd side. So a thicker stop on the port
side will help to counter this when the flaps are in the retracted position.
Duncan McF.
Posted: Sun Sep 30, 2012 3:26 am Post subject: Fixed Aileron Trim Tab |
Lance,
Wonderful! Thanks!
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
On Sep 30, 2012, at 3:34 AM, Lance Sandford <sandford(at)melbpc.org.au (sandford(at)melbpc.org.au)> wrote:
Lance Sandford
| Quote: | Bill & Others,
Bob Borger
phillik747
Joined: 04 Apr 2012 Posts: 74 Location: Birminham, AL USA
Posted: Sun Sep 30, 2012 2:49 pm Post subject: Re: Fixed Aileron Trim Tab |
I remember talking to Bud about this a few months ago and couldn't remember if I saw it somewhere else or not. However I did a quick search and found this post on www.europaowners.com
This should help get you in the right direction. (no pun intended) :p
| Bud Yerly wrote: | Adjust the flap which is up too far with the set screw in the baggage
bay (Custom Flight Mod) or by adding a shim to the back of the baggage
bay and the flap tube through the hole in the side of the aircraft with
thin wedges to shim the flaps 1/32nd of an inch to correct roll. |
http://www.europaowners.org/main.php?g2_itemId=80559&g2_imageViewsIndex=1
Kyle
_________________ Kyle
Europa Tri-gear (under construction) |
Alan Carter
Posted: Mon Oct 01, 2012 4:01 am Post subject: Re: Fixed Aileron Trim Tab |
Hi Kyle.
Read your link.
thin wedges to shim the flaps 1/32nd of an inch to correct roll. Right
flap down rolls right. Go fly. When roll is cured you may need to
adjust the aileron to match. But wait, most likely, then it needs the
flap to be trimmed again for less deflection due to the aileron
trimming, or because you made the airplane with very little friction in
your roll system, you may see both ailerons now evenly up or down as
appropriate. Go fly again. Test trim, then re-do stall series.
I have just purchased the Aircraft, have not had the wings off yet, so as your might expect, a Bungee or Fixed tab is easiest for me.
Can you or any one, explain in more detail about the Flap 1/32 shim, pretty thin shim, i am willing to try if i knew how to do it,
I need the aeroplane to Roll more to the Right
"thin wedges to shim the flaps 1/32nd of an inch to correct roll. Right
flap down rolls right" also Don,t understand this bit about roll right,
Alan
phillik747
Posted: Tue Oct 02, 2012 5:21 am Post subject: Re: Fixed Aileron Trim Tab |
Alan,
My plane is still in the process of being built so I haven't the real-world experience with this fix. If you look at the photo in the link it is showing the flap tube on the port side of the aircraft. You will see this when you remove the wings. The next photo shows the flap adjustment screw. By adding a shim to the tube or the inside of the rear bulkhead of the lower baggage bay (the part that comes in contact with the flap tube) you are forcing the port flap to not retract all the way. This would cause an increase in lift on the port side. From what I understand it doesn't take much since the flap is so large compared to the aileron.
Just my thoughts here, again no experience. The screw is probably a better solution for tuning the amount of deflection needed due to just adjusting the amount the screw protrudes and rests on the flap tube verses adding shims.
If I were you, just taking ownership of a finished aircraft, I’d follow Bud’s instructions from step 1 (found on the link above). Try to determine what is causing the right yaw movement and see if there is a more efficient fix before “creating more drag the counter the other.”
Kyle
Alan Carter
Posted: Tue Oct 02, 2012 9:43 am Post subject: Re: Fixed Aileron Trim Tab |
Thanks Kyle.
Hope your building is going well.
I will have a look at the flap bar next time i am up at the field, I see the photo,s now, Think this Flap adjustment screw is a mod and not on my aircraft, and it would would work well, but a shim stuck there would be easier i guess.
If it all looks to complicated i will fix a tab at least it will hold the wings level.
All the best
Alan
