Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27878 Location: Toledo Washington (KTDO) USA
Posted: Mon Dec 26, 2011 7:43 pm Post subject: Dynon Skyview Airspeed Calibration... |
Dear Listers,
I've been flying the new 10" Dynon Skyview in the RV-6 for a few weeks now and it seems like the airspeed is reading maybe 10mph fast. The GS always reads 10mph or more slower than the True airspeed, no matter which way I fly with respect to the current wind. Looking through the configuration options on the Skyview, I'm not seeing parameters to calibrate the airspeed. If the airspeed were *slow* compared to the GS, I could envision making adjustments to the Pitot tube to get it in better alignment with slipstream. But *fast* is a head scratcher. If there's no electronic configuration parameters to adjust, what do you do? Are there Pitot line "attenuators" like for RF in coax?
Matt
Matt "Red Dawg" Dralle
Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
Status: 42+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
_________________ Matt Dralle
Posted: Tue Dec 27, 2011 9:16 pm Post subject: Dynon Skyview Airspeed Calibration... |
At 07:40 PM 12/26/2011 Monday, Matt Dralle wrote:
| Quote: | Dear Listers,
Matt
Listers,
Thank you for all the great suggestions on resolving this airspeed issue! I took a look at the static ports on the RV-6 today and found that they are done using a flush head screw with a hole drilled in the center on either side of the fuselage. They do *not* protrude from the side of the plane at all. They are totally flush (see attached picture). Just for fun, I whipped up a couple of quick test deals using a 3/16" washer and some electrical tape. I poked a 1/16" hole in the center of the tape and then put the washer centered over the static ports on both sides of the fuselage (see attached pictures). Then, I went flying on this beautiful December 27 day in California!
I didn't have time to do any real scientific multi-leg testing, but I was amazed that the True Airspeed is now falling in a much more believable range compared to the GPS-derived ground speed. On one cross-country leg, I had an exactly 90 degree crosswind component and the True Airspeed and GPS Ground Speed were tracking exactly the same. Yahoo!
Obviously I need to do some additional, more scientific measurements and probably come up with a slightly more "permanent" washer arrangement, but the early returns are very promising!
Thanks again for all the great feedback!
Matt
57.45 KB |
3974 Time(s) |
136.56 KB |
3974 Time(s) |
124.68 KB |
3974 Time(s) |
68.35 KB |
3974 Time(s) |
Posted: Thu Dec 29, 2011 7:36 pm Post subject: Dynon Skyview Airspeed Calibration... |
At 07:39 PM 12/26/2011 Monday, you wrote:
| Quote: | --> RV-List message posted by: Matt Dralle <dralle(at)matronics.com>
Dear Listers,
Matt |
Listers,
I went flying tonight in the RV-6 around sunset and took some airspeed numbers flying the four points of the compass. I let each direction normalize for about 2 minutes before taking the readings. I've still got my little black-tape washer deals on the static ports that I detailed in a previous email.
Do these numbers make any sense?
I set the altimeter to 30.15 (KLVK ATIS). I compared the Dynon altitude with the Garmin 696 GPS altitude. The Dynon was high by 100 ft. I used the Dynon altitude adjustment to set it to match the GPS (-100ft). The readings above were after this adjustment.
Status: 48+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
36.65 KB |
3970 Time(s) |
m.l.marcotte(at)sympatico Guest
Posted: Fri Dec 30, 2011 11:10 am Post subject: Dynon Skyview Airspeed Calibration... |
I think one can calculate from the GPS numbers that you had a 14 MPH (approx) wind from the WNW and you were doing 182 TAS. Your IAS would appear to be 12 MPH too high.
Sent: Thursday, December 29, 2011 10:33 PM
To: rv-list(at)matronics.com (rv-list(at)matronics.com) ; rv8-list(at)matronics.com (rv8-list(at)matronics.com) ; rv7-list(at)matronics.com (rv7-list(at)matronics.com) ; rv10-list(at)matronics.com (rv10-list(at)matronics.com)
Subject: Re: Dynon Skyview Airspeed Calibration...
| Quote: | --> RV-List message posted by: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
Dear Listers,
Matt |
Listers,
[img]cid:22D7DA0DB537424EAE369E728B14E060(at)MobilePC[/img]
