Instrument panel paint / treatment
lwinger
PostPosted: Mon Sep 19, 2011 2:14 pm    Post subject: Instrument panel paint / treatment Reply with quote
What kind of paint or treatment did you use on your instrument panel?  I'm leaning toward flat or low gloss black with texture (or even wrinkle finish) to hide imperfections and to reduce fingerprints.
Larry Winger
Zenith CH650 B / Corvair
Tustin, CA
Finishing instrument panel
Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger
jaybannist(at)cs.com
PostPosted: Mon Sep 19, 2011 2:31 pm    Post subject: Instrument panel paint / treatment Reply with quote
Larry,
Why in the world would you want to have imperfections in your panel?
I used Rustoleum from a rattle can, medium to dark gray, with white lettering (see photo).
Jay
 Filesize:  182.05 KB
 Viewed:  11496 Time(s)
gfmjr_20(at)HOTMAIL.COM
PostPosted: Mon Sep 19, 2011 2:43 pm    Post subject: Instrument panel paint / treatment Reply with quote
Used a Hammered paint
George May---
601XLB  912-----410hrs
Date: Mon, 19 Sep 2011 15:10:41 -0700
Subject: Instrument panel paint / treatment
Larry Winger
Tustin, CA
target=_blank>http://www.matronics.com/Navigator?Zenith-List
ttp://forums.matronics.com
=_blank>http://www.matronics.com/contribution
lwinger
PostPosted: Mon Sep 19, 2011 2:48 pm    Post subject: Instrument panel paint / treatment Reply with quote
Could be because it is built by an imperfect builder!  Nothing major, just a few scuffs that will probably be concealed with multiple coats of regular spray paint.
Larry
On Mon, Sep 19, 2011 at 3:28 PM, Jay Bannister <jaybannist(at)cs.com (jaybannist(at)cs.com)> wrote:
[quote] Larry,
Jay
Larry Winger
Tustin, CA
tshankland(at)sbcglobal.n
PostPosted: Mon Sep 19, 2011 6:41 pm    Post subject: Instrument panel paint / treatment Reply with quote
I used cherry veneer, you varnish then use transfer letters for any text
then varnish a few more times.
Tim Shankland 601HD
 Filesize:  863.05 KB
 Viewed:  11480 Time(s)
ken Buchmann
PostPosted: Tue Sep 20, 2011 4:15 am    Post subject: Re: Instrument panel paint / treatment Reply with quote
My intention is to use 3 ply mahogany aviation plywood finished with a water based product "The Good Stuff". Steinair recommended to place a silicone fabric between the plywood and the aluminum to prevent the plywood from cracking due to temperature expansion differences. Your panel looks great it has character and nostalgia.
KenB 750 project in progress
BARRY CHECK 6
PostPosted: Tue Sep 20, 2011 4:32 am    Post subject: Instrument panel paint / treatment Reply with quote
Ken:
How thick a ply?  Three score sounds weak...  Aviation ply's that I have used are 5 and 7 score.  Keeping the scores high and the ply's thin will give strength and the gauges will not be recessed too far.
Barry
On Tue, Sep 20, 2011 at 8:15 AM, ken Buchmann <buchdvm(at)fidnet.com (buchdvm(at)fidnet.com)> wrote:
[quote] --> Zenith-List message posted by: "ken Buchmann" <buchdvm(at)fidnet.com (buchdvm(at)fidnet.com)>
http://forums.matronics.com/viewtopic.php?p=352755#352755
target="_blank">http://www.matronics.com/Navigator?Zenith-List
le, List Admin.
ken Buchmann
PostPosted: Tue Sep 20, 2011 5:25 am    Post subject: Re: Instrument panel paint / treatment Reply with quote
Barry;
The plywood is my rendition of a finish for the aluminum panel in place of paint or perhaps even powder coat. My intention was not to use the plywood as a substitute for the aluminum panel. I find the plywood easier to handle than the veneer, a matter of personal preference.
KenB Zenith750
goodings(at)yorku.ca
PostPosted: Tue Sep 20, 2011 8:48 am    Post subject: Instrument Panel Paint / Treatment Reply with quote
I don't think it matters very much what paint you use on the instrument
panel itself. Glare on the panel is not really a problem. I would use a
semi-gloss or duller rather than a gloss (a gloss is harder to patch, in
any case). But what DOES matter is to have the top of the turtle deck
above the panel a semi-gloss or flat (not very flat - it is too hard to
clean). Then, glare is not a problem. I am attaching a picture showing
what I mean.
John Goodings, C-FGPJ, CH601HD with R912S, Carp (Ottawa)/Toronto/Orillia.
 Filesize:  0 Bytes
 Viewed:  11455 Time(s)
BARRY CHECK 6
PostPosted: Tue Sep 20, 2011 9:26 am    Post subject: Instrument panel paint / treatment Reply with quote
That is understood Ken, I did not think otherwise.  Matter of fact replacing the aluminum with would is not allowed.  It would not meet kit design.
And I agree 100% with the idea of plywood as an overlay.  The veneer has many expansion and contraction issues - Very easy to crack and split.  Even with the cloth backing as mentioned.  The cloth will bring in its own problems - Holding moisture in contact with the aluminum and wood.
Did you check out 5 and 7 score plywood as mentioned?  They usually come with a VERY nice top sheet of A or AA grade Beach.  It stains or paints extremely well.
Barry
On Tue, Sep 20, 2011 at 9:25 AM, ken Buchmann <buchdvm(at)fidnet.com (buchdvm(at)fidnet.com)> wrote:
Barry;
KenB Zenith750
http://forums.matronics.com/viewtopic.php?p=352757#352757
le, List Admin.
