cutting windshield
egp8111
PostPosted: Thu Nov 11, 2010 6:08 am    Post subject: cutting windshield Reply with quote
I'm about to replace the windshield on my KF III. Whats the best way to make long straight cuts in the Lexan ?
thanks,
EG
sdemeyer
PostPosted: Thu Nov 11, 2010 6:54 am    Post subject: Re: cutting windshield Reply with quote
I tried using my bandsaw on a scrap piece but it came out looking like crap, all chipped up and crooked. Then I used a 4" thin metal cutoff wheel on my angle grinder and followed the line I drew. It came out nearly perfect, no chipped edges and almost perfectly straight. The 4" wheel wants to go straight and it was remarkably easy. Just take it slow and don't try to cut through all at once. I made several passes, making the cut a little deeper each time until I was through. If you try to cut all the way through in one fell swoop, you will end up melting the plastic.
Scott
Guy Buchanan
PostPosted: Thu Nov 11, 2010 7:37 am    Post subject: cutting windshield Reply with quote
I did it with a Dremel with the Dremel diamond cut-off blade. Go slow and DO cut all the way through. Make sure you have a line to follow and cut 1/32" outside the line. (One blade width.) You don't want to get the blade hot or the plastic starts melting onto it and it no longer cuts. If you need to cut corners do it in sections well outside the cutting line. Once you're done with the cut use a long (11") hard 60 grit sanding block to take the door down to the outside edge of the line. Use this block to sand radii into the corners as necessary. Next do the same with 220 and then 400, just removing the previous grit's scratches. Next use the Dremel buffing wheel with PBC (Plastic Buffing Compound) available by the stick to buff the edge until you can see into the plastic. (Don't let anything get hot, though.) This makes for a sexy finish and one that will resist cracking.
Guy Buchanan Normal Guy Buchanan 2 13 2010-09-24T17:53:00Z 2010-09-24T17:53:00Z 1 30 173 1 1 202 14.00 <![endif]--> false false false false EN-US X-NONE X-NONE <![endif]--> <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} <![endif]--> <![endif]--> <![endif]--> Guy Buchanan
Kitfox IV-1200 / 582-C / Warp 3cs / Soon to be a 912
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
lcfitt(at)sbcglobal.net
PostPosted: Thu Nov 11, 2010 7:40 am    Post subject: cutting windshield Reply with quote
I just finished fitting my windshield on my Model IV.
I am not necessarily saying this is the best way, but I used some of the
aviation tin snips and cut within about an eighth inch of the line then
used an electric plane to trim to the cut line. For the cut around the wing
spar, I used a Dremel with a diamond cut off wheel and a drum sander in the
Dremel for final smoothing. The Dremel was the most used tool when helping
with the neighbors Lancair IV. Incidentally on the Lancair, the cut line
was always marked with a strip of blue masking tape. This way, the cut dust
would not obscure a drawn line and there was no fear of a permanent mark on
the material being cut.
Lowell
Sent: Thursday, November 11, 2010 6:08 AM
Subject: cutting windshield
thanks,
EG
http://forums.matronics.com/viewtopic.php?p=318964#318964
larry huntley
PostPosted: Thu Nov 11, 2010 8:02 am    Post subject: cutting windshield Reply with quote
If it is Lexan it is polycarbonate and you can cut it with most anything. I
do mine on a band saw or if it is thin enough I sometimes use metal snips.
It doesn't crack like acrylic. Still need to drill holes oversize though.
Larry
Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade
henrysfork1(at)msn.com
PostPosted: Thu Nov 11, 2010 8:55 am    Post subject: cutting windshield Reply with quote
I agree with Larry, I have had good success cutting several wind shields using the left right tin snips.
Dee
[quote] From: asq(at)roadrunner.com
Subject: Re: Kitfox-List: cutting windshield
Date: Thu, 11 Nov 2010 10:57:30 -0500
--> Kitfox-List message posted by: "larry huntley" <asq(at)roadrunner.com>
Larry
msm_9949(at)yahoo.com
PostPosted: Thu Nov 11, 2010 9:08 am    Post subject: cutting windshield Reply with quote
Metal shears. Not sexy but fast and easy.
Marco Menezes N99KX
Hersey, MI
Model 2 582-90 C-Box 3:1 w/clutch
Date: Thursday, November 11, 2010, 9:08 AM
--> Kitfox-List message posted by: "egp8111" <egp8111(at)aol.com>
thanks,
EG
nbsp; (And Get Some AWESOME FREE Gif/contribution" rel=nofollow target=_blank>http://www.matronics.com/cont -Matt Dralle, Listr?Kitfox-List" rel=nofollow target=_blank>http://www.matronics.com/Navi - MATRONICS WEB=============
egp8111
PostPosted: Thu Nov 11, 2010 10:39 am    Post subject: Re: cutting windshield Reply with quote
thanks everyone.
EG
Float Flyr
PostPosted: Fri Nov 12, 2010 7:00 am    Post subject: cutting windshield Reply with quote
I used a spin saw.
First I would put tape over the glass where I was going to cut. If your
glass still has the protective plastic on it leave it there. Then I used a
board clamped to the bench at both ends just as a guide for the spin saw.
Take it easy with the spin saw and don't rush.
When drilling holes I always deburred to prevent cracking through the holes.
I personally tried using a hot welding wire to actually burn holes so the
edges would heal and increase the strength.. It worked for me but others
have said it didn't work for them.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Fri Nov 12, 2010 7:03 am    Post subject: cutting windshield Reply with quote
One other point Scott after using your cutoff wheel on plastic it may be a
good idea to reserve that particular wheel for cutting plastics only. The
rule of thumb I was told with any grinding medium was not to use it on any
metal that doesn't spark. For instance grinding aluminium causes shards of
aluminium to imbed itself in the wheel where it can heat up causing the
wheel to explode.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
pwmac(at)sisna.com
PostPosted: Fri Nov 12, 2010 9:40 am    Post subject: cutting windshield Reply with quote
Do you mean the tool that fits in your drill and spins like a drill bit?
PW
At 06:56 AM 11/12/2010, you wrote:
I used a spin saw.
Noel
Float Flyr
PostPosted: Fri Nov 12, 2010 11:51 am    Post subject: cutting windshield Reply with quote
Yes but I use mine in the Dremel (11,000rpm ?) the spinning action of the
saw blade is self cleaning and makes a very smooth cut without heating up
the plastic. Without the wood as a guide a straight cut is very difficult
though.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Roger Lee
PostPosted: Fri Nov 12, 2010 2:40 pm    Post subject: Re: cutting windshield Reply with quote
The Dremel is certainly a handy tool. I use it all the time. I have used the composite cut off wheel to do plastics, but usually use it on metals. I now use the Dremel blade that looks like a toothed round saw. Like something you might see on a table saw. I have used this blade on several plastic projects and like it better since the other composite cut off blade can sometimes melt the plastic and leave a terrible edge. The round tooth saw blade does not melt the plastic and leaves a nice smooth cut and with the variable speed of the Dremel making a nice edge with this is easy.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
Tommy Walker
PostPosted: Sat Nov 13, 2010 4:58 am    Post subject: Re: cutting windshield Reply with quote
Hi,
A trick that the Zenith builders use is an Olfa Knife and a straight edge. The Olfa is great for cutting thin (.016 - .032) aluminum and plastics like Lexan. You just have to finish off the cut edge with a file. I wouldn't be without an Olfa knife, available at Home Depot and other places.
Tommy Walker
N25A - Anniston, AL
airjunkee
PostPosted: Sat Nov 13, 2010 7:42 pm    Post subject: Re: cutting windshield Reply with quote
Hello
I have found that the best way to make a new windshield is to use the old one as a template. Cut a 4x8 sheet of plywood(1/2 inch) to the desired shape with a combination of circular saw with straight edge and jig shaw for the tight inside curves. Place the new sheet of lexan over the plywood and clamp as required. Use a trim router with a flush cutting bit to cut out the windshield. You will find that the cuts are very smooth and require no additional sanding. Now save the plywood template, next time a windshield is needed it will take all of 10 minutes to cut another one.
Shawn
PMorel
PostPosted: Sun Nov 14, 2010 5:22 am    Post subject: Re: cutting windshield Reply with quote
I really like the idea of keeping a plywood template. What I've done to add to the windshield is to mask off about a 1 inch edge along the inside of the windshield and door windows. Then spray flat black paint in order to give a clean sharp edge. Looks great!
 Filesize:  699.99 KB
 Viewed:  25829 Time(s)
Beemer
PostPosted: Tue Nov 30, 2010 6:12 am    Post subject: Re: cutting windshield Reply with quote
I used to use a scroll saw to cut mine. It works ok, is fast, can easily accomodate a guide for straight cuts. Then finish off with a belt sander or a router for a rounded edge.
I bought one of those oscillating saws from Sears for a home project. On a whim, I tried it on the Lexan for my windshield. With the saw attachment, it really works great! You could fab a fence for dead-straight cuts, but the tool will follow a line very well without it.
Beemer
Beemer
KF2 (and now an M3!)
Suzuki G10 three-banger
Middle Georgia
WurlyBird
PostPosted: Tue Nov 30, 2010 7:15 am    Post subject: Re: cutting windshield Reply with quote
Same same. Scroll saw by hand, belt sander for finish, dremel with a sanding disc for curves.
James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl.
shanesather(at)netkaster.
PostPosted: Wed Dec 08, 2010 5:01 pm    Post subject: cutting windshield Reply with quote
Just a test as I am not receiving messages
Shane
