Posted: Sun Oct 17, 2010 5:50 am Post subject: Another wheel question |
Gene- I got them just fine.
Bill Sullivan
russkinne(at)mac.com Guest
Posted: Sun Oct 17, 2010 5:56 am Post subject: Another wheel question |
what pictures?
On Oct 17, 2010, at 7:46 AM, Eugene Zimmerman wrote:
Eugene Zimmerman
Posted: Sun Oct 17, 2010 9:48 am Post subject: Another wheel question |
Ok Bob thanx,
I'm assuming It must just be a particular e-mail client problem then.
I suppose some clients have good reasons to be paranoid about malicious attachments because of their particular systemic vulnerabilities.
http://www.youtube.com/watch?v=GQb_Q8WRL_g
On Oct 17, 2010, at 9:19 AM, robert bean wrote:
they came through fine for me[b]
Dallas Shepherd
Posted: Sun Oct 17, 2010 12:40 pm Post subject: Another wheel question |
Dana
Posted: Sun Oct 17, 2010 6:50 pm Post subject: Another wheel question |
At 10:11 AM 10/16/2010, K I wrote:
| Quote: | | This is not my plane. It was one I considered purchasing at one time. This plane has never been in the air according to the seller. I think it has been disassembled and sold for parts by now. Never the less, here are the photos you asked for. |
That actually makes for a rather attractive airplane. Looks like much lower angle on the landing gear legs, to offset the increase in height from the larger wheels.
One drawback of larger wheels is that the brakes have to work harder, since the larger wheels put more torque on the brakes.
-Dana
"A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away." -Antoine de Saint-Exup,ry [quote][b]
David Lucas
Joined: 10 Jan 2006 Posts: 79 Location: Europe. based Amsterdam NL
Posted: Mon Oct 18, 2010 2:47 am Post subject: Re: Another wheel question |
| Quote: | Guys, I'm curious. Has anyone else had trouble viewing the pictures in my e-mail post?
Yes ! I did, but it's not an unusual occurrence with my set-up (Hotmail on Laptop running Win. Vista etc). Some get through, others don't. The ones that don't look like a series of Letters and numbers like this;
gAABBRi1DICAAAFJFRC1FWUUAgCIAAOgDAABBVVRPICAAAEFVVE8gICAgICAgICAAT0ZGICAgICAgICAg
But it takes up a huge amount of space on the e-mail (hundreds of lines), reducing the vertical slider to about 1/8th inch thick on a 15 inch screen. When it happens, I just go to the matronics site to look at the photos. There's probably some way of correcting it, but I haven't got around to researching it.
David.
Thumper
Posted: Wed Oct 20, 2010 5:43 pm Post subject: Re: Another wheel question |
What is the correct toe in and will that be with the tail wheel on the ground or elevated a bit? Ready to install my brakes with the new style axle to leg attachments on my Firestar KX. I am thinking no toe with tail on the ground and when the tail comes up there will be some? Any tips would be great.
Thanks The existing tires appear to be toe out until the tail comes up then they appear straight. It seems to handle fine on the blacktop and grass.
Dennis
1.52 MB |
11631 Time(s) |
1.16 MB |
11631 Time(s) |
_________________ Dennis Long
Oakland TN
2000 Aeroprakt A20 Vista Cruiser, 2016 A22LS Aeroprakt
Previously Kolb Mark IIIC, 94 Firestar, 84 Ultrastar.
1200+hours since 1/1/2009 |
by0ung(at)brigham.net Guest
Posted: Thu Oct 21, 2010 6:40 am Post subject: Another wheel question |
be great.
Dennis
| Quote: | >>>>>>>>>>>>>>>>>>>>.
The instruction manual for my mark III says " the wheels should be
aligned as shown: Parallel with the centerline axis of the airplane. If
you must err, err on the side of having the wheels toe out a bit. Do not
have any "toe-in""
I know that there has been conversation on the list that toe in is better,,
toe out is better,, straight is better...
Which is the best maybe I don't know,,,, but the above statement is from
the kolb instruction manual. Take it for what it is worth. My mkIII works
well on pavement.
Boyd young mkIII
Posted: Thu Oct 21, 2010 7:33 am Post subject: Another wheel question |
| Quote: | What is the correct toe in
| Quote: | aligned as shown: Parallel with the centerline axis of the airplane. If
> Boyd young mkIII
Boyd, Dennis, group,
I recall (clearly) the last time this subject came up. I had set my own "toe setting"
within a few days of the previous discussion. I set my newly-built steel gear legs to
have slight toe out. This is what the Kolb manual said, so that's what I did.
I read somewhere a long time ago that a taildragger airplane should have slight toe-out.
The thinking is that if one wing is raised, the remaining rolling tire will try to drive AWAY from the
raised wing, causing it to lower. In the fast and furious events of a raised wing landing,
whether this really makes a difference, I don't have any idea. But that's the theory.
I also remember John H said he had slight toe-in, and Kolbs like a little toe-in. If that
is true that Kolbs like a little toe-in;
A) he'd probably know, more than anyone else
OR
B) a little toe-out, a little toe-in, or straight may not make any noticable difference
whatsoever.
I think the latter may be the truth of the matter. Go with a straight toe setting,
and you won't know the difference.
From my math calculations, I came up with a 2 degree toe-out for each tire, on my plane.
I think if I were doing it again, I think I would set them straight and not think about them again.
To look at them, they appear to be straight.
If I remember correctly, measured at the front of the tire, if straight were zero, toe-in would be
about an 1/8th", and toe-out is about an 1/8th".
I'd go with the Kolb recommended setting....set them straight, but if you are going to err,
don't err, just set them straight!!!
Mike Welch
MkIII, getting closer all the time
Posted: Thu Oct 21, 2010 9:35 am Post subject: Another wheel question |
Boyd,
You cannot talk about toe in with out addressing camber and aircraft5 loading
too. I
had zero toe in and trying to taxi on hard surface runway, the FireFly was
wild in any cross wind condition. Then I adjusted camber and set it with
the gear settled with 200 pounds of bagged sand in the seat. No move
problems. Very docile during cross wind conditions. How it was done can be
seen at:
http://jackbhart.com/firefly/firefly126.html
and:
http://jackbhart.com/firefly/firefly127.html
Boyd,
too. I had zero toe in and trying to taxi on hard surface runway, the FireFly
was wild in any cross wind condition. Then I adjusted camber and set it with
the gear settled with 200 pounds of bagged sand in the seat. No more problems.
Very docile during cross wind conditions. How it was done can be seen at:
and:
Jack B. Hart FF004
Winchester, IN
Posted: Thu Oct 21, 2010 10:58 am Post subject: Another wheel question |
| Quote: | the kolb instruction manual. Take it for what it is worth. My mkIII
works
well on pavement.
Boyd young mkIII
Boyd Y/Gang:
My mkIII also performs well on pavement with 800X6 Air Tracs. I set mine up
neutral, but there must be a tad of toe in because the gear will spread when
pushed backwards.
Rock House, OR
_________________ John Hauck
Titus, Alabama |
Posted: Thu Oct 21, 2010 11:03 am Post subject: Another wheel question |
Mike W/Gang:
Based on the type of landing gear legs on Kolb Aircraft, toe out will cause the main gear to spread, especially on pavement, if they are toed out. This will cause increased drag and slow take offs, plus accelerate wear on the tires. On grass, the Kolb probably could care less which way the wheels point.
Rock House, OR
Mike Welch
Titus, Alabama |
Richard Pike
Posted: Fri Oct 22, 2010 3:48 pm Post subject: Re: Another wheel question |
Sigh...
http://imageresizer.codeplex.com/
Richard Pike
MKIII N420P (420ldPoops)
herbgh(at)nctc.com Guest
Posted: Fri Oct 22, 2010 4:12 pm Post subject: Another wheel question |
Neat program Richard...I use Irfanview...which is more involved...
Right clicking on an image and then clicking on drop down menu item
is simple...Herb
At 06:48 PM 10/22/2010, you wrote:
