[Bulk] Re: lower cowl attach alternatives
pitts_pilot(at)bellsouth.
PostPosted: Wed Sep 15, 2010 6:23 pm    Post subject: [Bulk] Re: lower cowl attach alternatives Reply with quote
Which makes me ask .... why not use an aluminum angle and rivet to the
firewall as well as the bottom skin??
I don't plan on using the hinge in that area either .... just don't know
how I'm going to do it yet. I do plan on using countersunk screws and
tinnerman washers in that area.
Linn
Linn
On 9/15/2010 8:53 PM, Strasnuts wrote:
Here is what I did. I replaced the rivets with AN426-4-5 rivets instead of the An426-3's that were there initially.
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
http://forums.matronics.com/viewtopic.php?p=312569#312569
http://forums.matronics.com//files/cowl_attach2_185.jpg
http://forums.matronics.com//files/cowl_attach1_163.jpg
http://forums.matronics.com//files/cowl_attach_158.jpg
Tim Olson
PostPosted: Wed Sep 15, 2010 6:48 pm    Post subject: [Bulk] Re: lower cowl attach alternatives Reply with quote
It's just overkill. That metal plate doesn't move hardly at all...
and you really don't need more than that.
Tim Olson - RV-10 N104CD
Linn
Linn
> Cust. #40936
> RV-10 SB Fuselage
> N801VR reserved
MauleDriver(at)nc.rr.com
PostPosted: Wed Sep 15, 2010 8:41 pm    Post subject: [Bulk] Re: lower cowl attach alternatives Reply with quote
As I recall, the angle between firewall, skin and cowling is not quite
90 degreee. Close but not quite. The plate aligns with the skin and
cowling making a flusht joint. A piece of 90 degree angle stock won't
quite make a flush joint.
An angle fabricated from flat stock like Dave Saylor seems to have done
would work. If I get cracking (when flying...) I'll probably go with that.
But I'm doing this from memory and may be completely wrong. But the
plate seemed perfect when I did it.
Bill "still finishing FG parts" Watson
> <pitts_pilot(at)bellsouth.net>
> Linn
