Posted: Wed Sep 15, 2010 6:23 pm Post subject: [Bulk] Re: lower cowl attach alternatives |
Which makes me ask .... why not use an aluminum angle and rivet to the
firewall as well as the bottom skin??
I don't plan on using the hinge in that area either .... just don't know
how I'm going to do it yet. I do plan on using countersunk screws and
tinnerman washers in that area.
Linn
Linn
On 9/15/2010 8:53 PM, Strasnuts wrote:
Tim Olson
Posted: Wed Sep 15, 2010 6:48 pm Post subject: [Bulk] Re: lower cowl attach alternatives |
It's just overkill. That metal plate doesn't move hardly at all...
and you really don't need more than that.
Tim Olson - RV-10 N104CD
On 9/15/2010 9:16 PM, Linn Walters wrote:
Posted: Wed Sep 15, 2010 8:41 pm Post subject: [Bulk] Re: lower cowl attach alternatives |
As I recall, the angle between firewall, skin and cowling is not quite
90 degreee. Close but not quite. The plate aligns with the skin and
cowling making a flusht joint. A piece of 90 degree angle stock won't
quite make a flush joint.
An angle fabricated from flat stock like Dave Saylor seems to have done
would work. If I get cracking (when flying...) I'll probably go with that.
But I'm doing this from memory and may be completely wrong. But the
plate seemed perfect when I did it.
Bill "still finishing FG parts" Watson
> <pitts_pilot(at)bellsouth.net>
> Linn
