A Rotisserie
cs(at)charlesstringham.co
PostPosted: Mon Aug 30, 2010 7:05 am    Post subject: A Rotisserie Reply with quote
The next question: Shall I build a fuselage rotisserie or not? Chet
Sent from my Verizon Wireless BlackBerry
craigtxtx(at)yahoo.com
PostPosted: Mon Aug 30, 2010 11:13 am    Post subject: A Rotisserie Reply with quote
I built one late in my QB construction and wish I had done it a lot earlier. It eliminates or reduces a lot of bendiing over the longerons to access the inside of the fuselage.
Craig Gallenbach
RV8A N184CG 145 hrs
--- On Mon, 8/30/10, cs(at)charlesstringham.com <cs(at)charlesstringham.com> wrote:
From: cs(at)charlesstringham.com <cs(at)charlesstringham.com>
Subject: A Rotisserie
To: rv8-list(at)matronics.com
Date: Monday, August 30, 2010, 11:03 AM
--> RV8-List message posted by: cs(at)charlesstringham.com (cs(at)charlesstringham.com)
Sent frs.com/Navigator?RV8-List" target=_blank>http://www.matronics.com/Navigato A href="http://forums.matronics.com/" target=_blank>http://forums.matrobsp; - List Contribution Web Site -http://www=======================
gaillard.peck.ctr(at)nell
PostPosted: Mon Aug 30, 2010 11:59 am    Post subject: A Rotisserie Reply with quote
Craig,
Are there plans available for the fuselage rotisserie?
Gail Peck, Las Vegas
RV-8 Wings - Tanks under construction and thinking about the Fuselage
PostPosted: Mon Aug 30, 2010 4:34 pm    Post subject: A Rotisserie Reply with quote
Gail,
I really didn't have anyplans and was not one to document all the details with photos when I was building. It amounted to a little imagination and a trip or two to Home Depot. I also put the whole assembly on casters so it could be rolled around the hanger as needed.
Craig
--- On Mon, 8/30/10, Peck, Gaillard R CTR USAF ACC USAFWS/CBD <gaillard.peck.ctr(at)nellis.af.mil> wrote:
From: Peck, Gaillard R CTR USAF ACC USAFWS/CBD <gaillard.peck.ctr(at)nellis.af.mil>
Subject: RE: A Rotisserie
To: "rv8-list(at)matronics.com" <rv8-list(at)matronics.com>
Date: Monday, August 30, 2010, 3:57 PM
--> RV8-List message posted by: "Peck, Gaillard R CTR USAF ACC USAFWS/CBD" <gaillard.peck.ctr(at)nellis.af.mil (gaillard.peck.ctr(at)nellis.af.mil)>
Craig,
Speedy11(at)aol.com
PostPosted: Tue Aug 31, 2010 7:03 am    Post subject: A Rotisserie Reply with quote
In a word - yes.
Use your imagination to build it (should be fairly simple). I didn't build one, but should have. I kept the fuselage low to the ground on spar inserts with wheels for as long as possible. Something to rotate the fuselage would have been helpful - consider putting it on locking wheels.
There may be one for sale "out there" that would save you time, money and effort.
As far as the builders manual goes - I've always told potential quick builders to not depend on it. It basically says "build wing, attach wing."
Just flew my 8A from Daytona Beach to VT and back. I took a cruise through the Hudson VFR corridor on the way up and flew over JFK at 10.5 on the way back.
Stan Sutterfield
geezer02(at)windstream.ne
PostPosted: Tue Aug 31, 2010 1:09 pm    Post subject: A Rotisserie Reply with quote
Is there any one that needs a wing rack. This is a rack just to hold the wings after they are built, if so I have a set not being used any more. not the rotisserie but still useful.
Louis Dunn
RV-8 Someday
Getting closer.
704-562-3747
In a word - yes.
effort.
way back.
Stan Sutterfield
Jerry Grimmonpre'
PostPosted: Wed Sep 01, 2010 2:33 am    Post subject: A Rotisserie Reply with quote
Simple rotisserie rotates on two 1/2" bolts. Work standing or sitting.
 Filesize:  52.52 KB
 Viewed:  9756 Time(s)
 Filesize:  53 KB
Paul Valovich
PostPosted: Wed Sep 01, 2010 5:44 am    Post subject: A Rotisserie Reply with quote
Check the archives – I built mine based on posts and pix from precious posters.
PostPosted: Wed Sep 01, 2010 7:55 am    Post subject: A Rotisserie Reply with quote
Nice. Thanks. Gail Peck
