Pulling a 912ULS Gear Box
JohnF
PostPosted: Fri Jul 16, 2010 9:46 am    Post subject: Pulling a 912ULS Gear Box Reply with quote
I need to pull the gear box from my 912ULS to have it checked out after a prop strike. I have removed the 10 (or is it Cool smaller bolts, and the two larger ones at the bottom.
The forward case doesn't seem to want to move...a few genle taps with a rubber hammer didn't do anything, so it seems I need information.
How do you 'pull' the gear box? Force? Some special puller tool? What?
JohnF
bob(at)fly-ul.com
PostPosted: Fri Jul 16, 2010 10:04 am    Post subject: Pulling a 912ULS Gear Box Reply with quote
You really need the gear puller that's available for that gearbox. Hammer on it, and you might crack something. Piece of cake with the puller.
Bob Comperini
e-mail: bob(at)fly-ul.com
WWW: http://www.fly-ul.com
rlborger(at)mac.com
PostPosted: Fri Jul 16, 2010 10:13 am    Post subject: Pulling a 912ULS Gear Box Reply with quote
John,
Go to my Europa Owners Gallery. You should see an album concerning the Lockwood 9XX School. Click on the album and then go to page 4. Toward the top of the page there are a couple pictures concerning removal of the gearbox.
Yes, there is a special tool made for gearbox removal.
Good luck,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232
http://www.biplaneforumgallery.com/index.php?cat=10046
Europa Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
JohnF
href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.matronics.com/Navigator?RotaxEngines-List
bob(at)fly-ul.com
PostPosted: Fri Jul 16, 2010 10:34 am    Post subject: Pulling a 912ULS Gear Box Reply with quote
And don't forget to consult the 912 maintenance manual(s). They usually have decent descriptions of how to remove things like this. You'll certainly want to consult it when you re-install the gearbox too, so you have the torque values, and know the proper flange sealant to use when reassembling the gear box.
Bob Comperini
Roger Lee
PostPosted: Fri Jul 16, 2010 11:58 am    Post subject: Re: Pulling a 912ULS Gear Box Reply with quote
Here is an inexpensive homemade gearbox puller.
The cost for a gearbox inspection including parts is about $450 and if the shaft is bent past the acceptable limits then that is another $640. About 70% of the shaft flanges are bent, just many people never bother to check it or know how to check it.
Homemade Gearbox puller1.pdf
Homemade gearbox puller
 Filename:  Homemade Gearbox puller1.pdf
 Filesize:  144.6 KB
 Downloaded:  691 Time(s)
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
kevann(at)gotsky.com
PostPosted: Fri Jul 16, 2010 12:53 pm    Post subject: Pulling a 912ULS Gear Box Reply with quote
Hi John,
rotaxowner.com has video on how to remove and install (with the proper sealant) your gearbox. You can make a tool from a cheap slide hammer and fabricated bolt on fixture that Roger showed in a photo.
Kevin
Dick Maddux
PostPosted: Sat Jul 17, 2010 12:42 pm    Post subject: Pulling a 912ULS Gear Box Reply with quote
Holy cow Roger ! That is about the "cheesest " puller I have seen but if does the job then thats great. I have one I cut out of 1/4 inch steel sheet with a plasma cutter and attached it to a small slide hammer.It works great!
Anyway Johann you can buy one from California Power Systems if you want for about $75. Lockwood and LEAF also have them but I think they are higher. This of course is if you don't want to make one
      Dick Maddux
      912UL
      Milton,Fl
Roger Lee
PostPosted: Sat Jul 17, 2010 1:59 pm    Post subject: Re: Pulling a 912ULS Gear Box Reply with quote
This puller works just as good as the most expensive ones and it cost about $10 to make. You can use a slide hammer with it or just get a 2' all thread screw from Ace Hardware. Put a nut on each end and a 2.5 lb. dumb bell weight on the long shaft to slide back against your nut. Works like a charm. Slide hammers are cheap at Harbor Freight.
Roger Lee
Tucson, Az.
Cell 520-349-7056
b.carl@sympatico.ca
PostPosted: Sun Jul 18, 2010 6:59 am    Post subject: Pulling a 912ULS Gear Box Reply with quote
Hi Dick
Could you post a picture of your puller?
Carl
701/ 912
Dick Maddux
PostPosted: Wed Jul 21, 2010 4:00 pm    Post subject: Pulling a 912ULS Gear Box Reply with quote
Carl,
Here are some pictures of my homemade gear box puller.It is cut out of 1/4steel plate with a plasma cutter.
      Dick Maddux
      912UL
      Milton,Fl
 Filesize:  386.51 KB
 Viewed:  10068 Time(s)
 Filesize:  382.65 KB
