n277dl
dlm46007(at)cox.net Guest
Posted: Thu May 20, 2010 3:48 pm Post subject: Door handle label |
My DAR never asked; no labels . I brief passengers about how to unlock
seatbelts and we go to great lengths to demonstrate the door and pin check,
Feel them all once before engine start and once before takeoff.
BrianNC
Posted: Fri May 21, 2010 6:04 am Post subject: Re: Door handle label |
Isn't it kind of ridiculous to have to put an exit label on the doors in a two door airplane? I mean seriously.
Posted: Fri May 21, 2010 6:12 am Post subject: Door handle label |
YES!
Linn
BrianNC wrote:
n277dl
Kelly McMullen
Posted: Fri May 21, 2010 6:50 am Post subject: Door handle label |
It would be interesting to know where the DAR gets this requirement. I
suspect it comes from some FAR dealing with commercially operated
aircraft. I've not seen a single engine type certificated aircraft
with an exit label....but wasn't really looking for it either. I know
I would have to buy a whole bunch of placards if I wanted to use my
Mooney for Part 135 operations.
On Fri, May 21, 2010 at 7:04 AM, BrianNC <EMINI2000(at)yahoo.com> wrote:
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Fri May 21, 2010 8:23 am Post subject: Door handle label |
If you have access to design / layout software (I use Adobe Illustrator)
you can layout all your markings / labels in any color, size and shape you
wish. Then send the file to Stein and for something like $20.00/sheet he
can reproduce the info on long lasting, UV resistant water floatable
decals. Then just trim, drop in a glass of water, wait a few seconds slide
off the backing and slide into position and let dry. It's about the
easiest part of building a plane and can look ultra professional. On my
next plane I plan on leaving my panel and breakers un-labeled and creating
the graphics myself using this technique. This allows me flexibility if I
choose to rearrange my breakers or switches etc... Attached are two photos
of my labels applied in place.
Robin
448.34 KB |
7413 Time(s) |
317.56 KB |
7413 Time(s) |
