Door handle label
n277dl
PostPosted: Thu May 20, 2010 3:39 pm    Post subject: Door handle label Reply with quote
Group,
Working to get the DAR out in a few days and one of the things he's mentioned is labeling in general but particularly labeling the "exit" sign Smile
Does anyone have any pictures of how you may have labeled the door handle? I have standard Vans setup. I'm guessing it'll be something like "push here" - Pull up.
Thanks... getting close.
Doug
Doug
"Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes.
dlm46007(at)cox.net
PostPosted: Thu May 20, 2010 3:48 pm    Post subject: Door handle label Reply with quote
My DAR never asked; no labels . I brief passengers about how to unlock
seatbelts and we go to great lengths to demonstrate the door and pin check,
Feel them all once before engine start and once before takeoff.
pitts_pilot(at)bellsouth.
PostPosted: Thu May 20, 2010 4:04 pm    Post subject: Door handle label Reply with quote
This is part of what bugs me about some DARs that charge so much for
their 'service'. That label has absolutely no bearing on the airplanes
airworthiness.
I'd put a label on each door .... your example should be OK ..... and
then they'd magically disappear after the inspection.
Having said that, ingress and egress should be covered for your
passengers each time. Add it to your checklists.
Linn
n277dl wrote:
Group,
Doug
Doug
http://forums.matronics.com/viewtopic.php?p=298378#298378
BrianNC
PostPosted: Fri May 21, 2010 6:04 am    Post subject: Re: Door handle label Reply with quote
Isn't it kind of ridiculous to have to put an exit label on the doors in a two door airplane? I mean seriously.
PostPosted: Fri May 21, 2010 6:12 am    Post subject: Door handle label Reply with quote
YES!
Linn
http://forums.matronics.com/viewtopic.php?p=298424#298424
n277dl
PostPosted: Fri May 21, 2010 6:41 am    Post subject: Re: Door handle label Reply with quote
n277dl wrote:
Group,
Doug
Let me clarify before my sarcasm gets blown completely out of proportion... I'm pretty sure he's asking to label how to open the door not explicitly putting an exit sign on the door.
I'm thinking my Brother label printer may be my best buddy during this inspection. (whoops... there goes that sarcasm again Smile )
Still would like to see any pictures where anyone has labeled the door in any fashion.
Doug
Doug
Kelly McMullen
PostPosted: Fri May 21, 2010 6:50 am    Post subject: Door handle label Reply with quote
It would be interesting to know where the DAR gets this requirement. I
suspect it comes from some FAR dealing with commercially operated
aircraft. I've not seen a single engine type certificated aircraft
with an exit label....but wasn't really looking for it either. I know
I would have to buy a whole bunch of placards if I wanted to use my
Mooney for Part 135 operations.
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
robin(at)PaintTheWeb.com
PostPosted: Fri May 21, 2010 8:23 am    Post subject: Door handle label Reply with quote
If you have access to design / layout software (I use Adobe Illustrator)
you can layout all your markings / labels in any color, size and shape you
wish. Then send the file to Stein and for something like $20.00/sheet he
can reproduce the info on long lasting, UV resistant water floatable
decals. Then just trim, drop in a glass of water, wait a few seconds slide
off the backing and slide into position and let dry. It's about the
easiest part of building a plane and can look ultra professional. On my
next plane I plan on leaving my panel and breakers un-labeled and creating
the graphics myself using this technique. This allows me flexibility if I
choose to rearrange my breakers or switches etc... Attached are two photos
of my labels applied in place.
Robin
 Filesize:  448.34 KB
 Viewed:  7417 Time(s)
 Filesize:  317.56 KB
