Photos Of CS Prop Bolt Safety Wiring...?
Site Admin
PostPosted: Sun Feb 28, 2010 12:10 pm    Post subject: Photos Of CS Prop Bolt Safety Wiring...? Reply with quote
Does anyone have any close-up photos of how they safety wired the prop bolts on a Hartzell CS prop? You have to run the safety wire though those roll-pins. What a pain. If you have to pull the torque up from the bottom, it seems impossible to actually set twist. Maybe if I twist both ends first... Hum...
Anyway, some pics would be most appreciated!
RV-8 #82880 N998RV
Site Admin
PostPosted: Sun Feb 28, 2010 3:33 pm    Post subject: Photos Of CS Prop Bolt Safety Wiring...? Reply with quote
Well, okay, so it wasn't quite as hard as I thought. It was still a pain though! Here are three pictures of the safety wiring I did on the Hartzell CS Prop bolts (photo of each pair of bolts). What do you guys think?
Best regards,
RV-8 #82880 N998RV
 Filesize:  125.01 KB
 Viewed:  2277 Time(s)
 Filesize:  122.46 KB
 Filesize:  127.76 KB
