Firefly full enclosure
bob.kravis(at)gmail.com
PostPosted: Mon Feb 22, 2010 3:54 pm    Post subject: Firefly full enclosure Reply with quote
Does anybody have information about or experience with the full windscreen on a Firefly?  Here in Maine it might make a difference 8 months of the year.  I wrote to Travis and he told me that it is a hingeless installation.  He said you can just lift it and slip into the cockpit - "like lifting the sheet and getting into bed."  That seems odd and a bit awkward.  I would has suspected a hinge along the left edge of the cockpit but what do I know?  From what few pictures I have found on the web, and the YouTube video of the AmeriFly (great paint!) I can't tell very much.  BTW Travis said adds 10 lbs.  Bob
herbgh(at)nctc.com
PostPosted: Mon Feb 22, 2010 6:02 pm    Post subject: Firefly full enclosure Reply with quote
Yep....just attach the .0625 lexan to the left side of the fuselage
and let it fold over the nose and the rear hoop... Works very
well.. On the Right side ...attach a 1//4 inch or so rod that is
aligned to go through a hole in the tab that the nose cone attaches
to...that holds/secures the lexan over the nose cone...Make some
sort of latch to batten down the right rear side... On the rear
hoop...attach the lexan to the hoop about three 8ths of the way
up... on the nose cone end attach the lexan about 3/4 ths the way
up the left side.. Make some sort of of cable stop to prevent the
lexan from being blown over the left side... while allowing it to
come up high enough for entry...Install a prop to hold the windscreen
open for entering... You will need to attach aluminum angle on both
sides running up the left side to prevent the lexan from
bowing...same for right side.. These should be long enough to just
fit the nose cone to bow attach point..
Clear as mud I know...but my tele prompter is broken....Smile Herb
lcottrell
PostPosted: Mon Feb 22, 2010 6:04 pm    Post subject: Firefly full enclosure Reply with quote
I got a full enclosure from Kolb for my Firestar and it included the metal hardware to attach to the top of the cage, a full sheet of lexan and a alum tube. Basically you cut the lexan to fit over this hardware and the nose cone in one piece and is secured on the other side of the cage. In essence the lexan is secured on the left side of the cage, then to the alum tube in the middle of the wind screen. You can lift the right side to get in. I am still using the metal parts that they supplied even though I have redesigned the lexan to a bit differently. I did not use the alum piece in the center, even though you will eventually get used to it.
You can manufacture and install a heat collector on the shroud of the two strokes and pipe the heat into the cage for heat. Check the archives
Larry
elleryweld(at)aol.com
PostPosted: Mon Feb 22, 2010 8:39 pm    Post subject: Firefly full enclosure Reply with quote
I have built a full encloser for a firestar1 & firestar 2 That will not be a problem I have a welding / Machine shop and I am willing to help you out all you have to do is buy the material
Ellery Batchelder Jr.
herbgh(at)nctc.com
PostPosted: Mon Feb 22, 2010 10:50 pm    Post subject: Firefly full enclosure Reply with quote
I think all the attachment tabs were on my fuselage... Herb
At 10:08 PM 2/22/2010, you wrote:
[quote]I have built a full encloser for a firestar1 & firestar 2 That will not be a problem I have a welding / Machine shop and I am willing to help you out all you have to do is buy the material
Richard Pike
PostPosted: Tue Feb 23, 2010 5:28 am    Post subject: Re: Firefly full enclosure Reply with quote
There is a picture of the FSII one piece windshield and rear latch mechanism here:
http://www.bcchapel.org/pages/0003/Latch.html
Richard Pike
MKIII N420P (420ldPoops)
PostPosted: Tue Feb 23, 2010 5:42 am    Post subject: Firefly full enclosure Reply with quote
Richard,Thanks for the link.  I had never seen your site.  There's a lot of information there and I look forward to reading every bit of it.
On Tue, Feb 23, 2010 at 8:28 AM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
[quote]--> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Richard Pike
http://forums.matronics.com/viewtopic.php?p=287780#287780
le, List Admin.
joepilot503
PostPosted: Sat Feb 27, 2010 9:00 am    Post subject: Re: Firefly full enclosure Reply with quote
Here is how I built my enclosure for a original firestar. I can take both doors off in seconds. It also has hand holds to grab above head to make easier to get in, I'm 215 lbs so I need all the help I can get Smile I attached some pics, hope it helps. Brian Arrow
 Filesize:  352.4 KB
 Viewed:  15763 Time(s)
 Filesize:  369.8 KB
 Filesize:  374.66 KB
PostPosted: Sat Feb 27, 2010 7:43 pm    Post subject: Firefly full enclosure Reply with quote
The original Firestar top longeron was straight from one end to the other.
I noticed yours is drooped in the front, similar to the FSII.
john hauck
joepilot503
PostPosted: Sat Feb 27, 2010 8:14 pm    Post subject: Re: Firefly full enclosure Reply with quote
Yes it is, I lowered the sides when I restored it for easier entry. Also did the wing mods with the alum angle/.035 LE & TE/wing tip mod/lateral bracing. Here is my site with photos of rebuild you can see all the the mods I did. www.brianskolbfirestar.comlu.com
PostPosted: Sat Feb 27, 2010 9:59 pm    Post subject: Firefly full enclosure Reply with quote
Brian/Gang:
Wish I had had those mods on my FS wings 20 years ago next month. I might
still be flying it if I had.
They look good.
john hauck
rowedenny
PostPosted: Sun Feb 28, 2010 3:11 am    Post subject: Firefly full enclosure Reply with quote
Brian/Gang:
They look good.
john hauck
Brian,
That does look like first class work on your Firestar, always a pleasure to
see the work of real craftsman.
Denny Rowe, Mk-3, PA
Thom Riddle
PostPosted: Sun Feb 28, 2010 5:08 am    Post subject: Re: Firefly full enclosure Reply with quote
Very nice work and worthwhile mods.
I'm curious about your fuel tank. What are the dimensions and capacity?
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
joepilot503
PostPosted: Sun Feb 28, 2010 6:18 am    Post subject: Re: Firefly full enclosure Reply with quote
Thanks guys for the compliments. Thom as far as the dimensions of the tank I would guess about 13 x 16, It's 8 gal. Let me know if you need exact dimensions I'll measure it.
Thom Riddle
PostPosted: Sun Feb 28, 2010 6:54 am    Post subject: Re: Firefly full enclosure Reply with quote
Exact dimensions not required by me. Just curious how much you could carry in a drum tank.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
