Fuel Reserve and UL's
Goto page Previous  1, 2, 3  Next
PostPosted: Fri Feb 26, 2010 10:01 pm    Post subject: Fuel Reserve and UL's Reply with quote
> I flew all my two strokes at 5800 rpm cruise.
john hauck
(John, I think we've had this dance before, and still can't seem to agree if
it's a Cha-Cha or a Foxtrot... Hang in there buddy - two strokes are evil
and must be PUNISHED!)
Richard Pike
Richard P/Gang:
Sorry about that.
I think you took my reply the wrong way.
I was not arguing with nor trying to out do you. Simply stating the way I
flew and currently fly my airplanes.
I fly normal cruise if I fly 11 miles from my strip to Wetumpka Airport.
I fly normal cruise if I fly around the traffic pattern.
There is more than one way to fly an airplane.
john hauck
John Bickham
PostPosted: Sat Feb 27, 2010 4:30 am    Post subject: Re: Fuel Reserve and UL's Reply with quote
Sorry if I'm coming in late on this one.
Don't get lulled into the "30 min reserve" will keep you safe! Been there, done that, bent the gear in a hayfield in TX.
I was a heavy iron GA pilot and thought the FAA regs would keep me straight. Problem is the regs were written for planes that have cruise speeds of 120 mph plus. Planes that do 60 mph can't get as far as in 30 minutes. Throw in a little wind in the wrong direction and your options start to vanish quicker. Next airport just 30 minutes up the road can be well over 30 minutes with just a little bit of the wrong wind. Don't even think about mid morning radiant fog covering the airport when you get there.
Yes you do have a lot more options of off-field landings. Farmers around here ain't friendly to ruining their cane fields. As wet as we have been down here, you couldn't get in and out till summer.
Thanks too much,
John Bickham
Mark III-C w/ 912UL
St. Francisville, LA
I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for.
jbhart(at)onlyinternet.ne
PostPosted: Sat Feb 27, 2010 7:34 am    Post subject: Fuel Reserve and UL's Reply with quote
At 09:07 PM 2/26/10 -0600, you wrote:
Hi Guys:
When you all are contributing info on fuel burn, need to include power
setting, i.e., engine rpm. There is a great deal of difference in fuel burn
on two and four stroke aircraft engines at low power settings and higher
power settings. To me, 75% power is normal cruise. Seems most of the
others who have contributed info on fuel burn, cruise much slower.
John,
If you equate 75% power as 75% carburetor slide opening, the 447 will be
running at max power. This is due to the fact that the Bing 54 carburetor
is over sized for the engine. I found that the 447 will top out at 6,200 at
about 34% with the throttle at the 34% position.
If you equate 75% power relative to rpm, then .75 x 6,200 gives a cruise rpm
of 4,650 rpm. From my flight log, I pulled out the data shown below. All
of these flights were from and to Perryville and Painton, MO. You will
notice that all of the rpms listed are greater than your 75%. The rpm/rpm
indicates that a different rpm was set from the to and return flights. This
difference as due to the gps indicated ground speed and the expected gps
arrival time. If I had a head wind, I would crank in more rpm, etc. to get
to the meeting on time.
Date Fuel MPG Time RPM GPH MPH
(gal) (min) Ave. Ave.
12/19/99 5.5 19.6 119 5,200 2.8 54.5
02/20/00 5.5 19.6 126 5,400 2.6 51.4
09/17/00 4.9 22.0 104 5,800 2.8 62.3
05/12/01 5.5 19.6 114 ?,??? 2.9 56.8
06/23/01 5.5 19.6 111 5,600 3.0 58.4
08/19/01 6.0 18.0 112 5,200/ 3.2 57.9
6,200
10/07/01 5.75 18.8 101 5,600 3.4 64.2
11/04/01 6.00 18.0 107 5,700/ 3.4 60.6
5,600
02/17/02 6.75 16.0 112 5,200 3.3 57.9
Averages 5.71 18.9 112 5,550 3.06 57.9
I hope this is enlightening.
Jack B. Hart FF004
Winchester, IN
slyck(at)frontiernet.net
PostPosted: Sat Feb 27, 2010 8:47 am    Post subject: Fuel Reserve and UL's Reply with quote
75%power would be a difficult measurement to acquire accurately. Static prop thrust wouldn't even be accurate due
to inefficiencies with no forward motion. The only real way to do it would be on a dyno with no prop.
If you had a magic strain gauge between the prop and hub you could get something useful in flight.
On mine I just pull back a few rpm and settle for it.
BB
> Hi Guys:
John,
6,200
5,600
Jack B. Hart FF004
Winchester, IN
Richard Pike
PostPosted: Sat Feb 27, 2010 9:24 am    Post subject: Re: Fuel Reserve and UL's Reply with quote
john hauck
Richard Pike
Richard P/Gang:
Sorry about that.
john hauck
Nay nay, it was all in fun! I know you, I know how you are, you know me, you know how I am, - Hey, I see a chain, I think I'll pull it! (Not that you wouldn't) And here we go again! (May I have this dance?)
Laughing
It's all good. Finished getting the rust off the steel root rib for the left wing and welded up the hole for the clevis pin. Can you believe it was wallowed out to almost 3/8"? And somebody was flying it that way? So yes, there is more than one way to fly an airplane, in the case of this basket case we bought and cannibalized, by someone who apparently didn't mind rattling and flopping through the sky... Rolling Eyes
Richard Pike
N420P (420ldPoops)
cedavis
PostPosted: Sat Feb 27, 2010 9:31 am    Post subject: Fuel Reserve and UL's Reply with quote
My Firefly gets 2.5gph at 55 MPH turning 5300-5400 RPM. It's empty weight is about 280 lbs (from memory; too lazy to get my weight and balance).
If Terry Franz is reading, I believe he's say's his 103 Firefly get's closer to 2.0 gph, but he's done more optimization then I have.
Chuck Davis
Firefly, N7057K
PostPosted: Sat Feb 27, 2010 4:23 pm    Post subject: Fuel Reserve and UL's Reply with quote
Jack B. Hart FF004
I have been enlightened.
Thanks, will try to explain the way I do it somewhat later tonight. Right
now it is time for the Atlanta Supercross Live. Wink
john hauck
GeoB
PostPosted: Sun Feb 28, 2010 12:58 pm    Post subject: Re: Fuel Reserve and UL's Reply with quote
jbhart(at)onlyinternet.ne wrote:
If you equate 75% power as 75% carburetor slide opening, the 447 will be running at max power. This is due to the fact that the Bing 54 carburetor is over sized for the engine.
Also note that this carb, like MANY others, has no linear relationship between throttle-slide movement and cross-sectional area of the throttle bore opened.
Butterfly carbs have a similar problem.
I thought there was an 'official' definition of 75% power. I don't recall for sure but it seemed like it was something like 100% rpm, then back off 10% rpm.
GeoB
"Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors"
PostPosted: Sun Feb 28, 2010 1:03 pm    Post subject: Fuel Reserve and UL's Reply with quote
At 08:42 PM 2/26/10 -0600, you wrote:
Richard P/Gang:
My 582 powered mkIII cruised 80 mph at 5800 rpm and burned 5.5 gph.
My 447 powered FS cruised (can not remember the cruise speed) at 5800 rpm
and burned 3.5 to 3.75 gph.
My ULII02 powered US cruised (can not remember the cruise speed) at 5800 rpm
and burned 3.5 gph.
My 912UL powered mkIII cruised 85 mph at 5,000 rpm and burned 4.0 gph.
My 912ULS powered mkIII cruises at 88 mph at 5,000 rpm and burns 5.0 gph.
I flew/fly all my two and four stroke engines at aprx'ly 75% power. They
all were happy at that power setting and the airplanes and I were too.
John,
From being on the list for a few years, I questioned your 75% power cruise
statement because it countered my impression of how you flew your planes. I
checked with http://www.rotaxservice.com/rotax_engines and using the numbers
proved from the various engine model spec sheets this is what I found.
engine max hp max hp .75 max .75 max |John's hp % max
model (cont') rpm hp rpm | rpm (dev') hp
582 65 6,500 49 5,300 |5,800 61 94
447 40 6,500 30 5,200 |5,800 37 93
912ul 79 5,500 59 4,000 |5,000 74 94
912uls 95 5,500 71 4,200 |5,000 89 94
Approximately 75%?
Jack B. Hart FF004
Winchester, IN
PostPosted: Sun Feb 28, 2010 2:11 pm    Post subject: Fuel Reserve and UL's Reply with quote
Jack B. Hart FF004
OK
john hauck
herbgh(at)nctc.com
PostPosted: Sun Feb 28, 2010 8:49 pm    Post subject: Fuel Reserve and UL's Reply with quote
71 hp divided by 12 hp per gal per hour...comes to abt 5.9 gals
hour... Seems a bit high...I am guessing that the 912uls burns about
5.5 gals hour at 75 % power? Herb
At 04:10 PM 2/28/2010, you wrote:
--=======AVGMAIL-29A51582=======
Content-Type: text/plain; charset=us-ascii
Jack B. Hart FF004
OK
john hauck
Content-Type: multipart/alternative;
boundary="=======AVGMAIL-1D000391======="
--=======AVGMAIL-1D000391=======
Content-Type: text/plain; x-avg=cert; charset=us-ascii
Content-Transfer-Encoding: quoted-printable
Content-Disposition: inline
Content-Description: "AVG certification"
Checked by AVG - www.avg.com
34:00
--=======AVGMAIL-29A51582=======--
Thom Riddle
PostPosted: Mon Mar 01, 2010 4:51 am    Post subject: Re: Fuel Reserve and UL's Reply with quote
The power curve in Rotax (and other engine manuals) shows the maximum power available for that engine at that RPM at sea level on a standard day, not the actual power being produced at that rpm under other conditions. The actual power being produced at a given rpm depends upon two primary variables. One is the density altitude and the other is the prop loading.
The power curve is valid only at DA of zero and at wide-open-throttle (WOT). The actual power being produced in straight and level cruise at normally encountered density altitudes at partial throttle is less than that shown on the power curve.
John's 75% power at 5,000 rpm are pretty close at typical DAs in lowlands knowing he pitches his prop generally for 5500 rpm WOT in S&L flight. At a density altitude of about 8,000' the 912 engines will produce only 75% of rated power with WOT at 5,500 rpm, not 5,000 rpm. As you go higher still, the maximum available power continues to decrease.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
GeoB
PostPosted: Mon Mar 01, 2010 8:57 am    Post subject: Re: Fuel Reserve and UL's Reply with quote
I hear you saying that to be very close to actual 75% power you would have to solve an equation that relates temp, humidity, altitude and prop attributes. It sounds like if you had a glass panel you could have a read-out of your %-power. Funny! It doesn't even involve the engine!
Thanks for your post.
GeoB
Thom Riddle
PostPosted: Mon Mar 01, 2010 9:21 am    Post subject: Re: Fuel Reserve and UL's Reply with quote
GeoB,
As I've said either here or elsewhere, I think one of the easiest ways to know what your current engine power output is under whatever conditions you are flying, is a fuel flow meter. A 4-stroke engine maintained and operated according to the manufacturer's instructions will consume roughly .45 lbs (+ or - .03 lbs) of gasoline per hour per HP being produced.
For example:
An engine with rated sea level max continuous power of 80 HP, when running at 75% power (60 HP), no matter what the rpm or density altitude required to make that power, will be consuming approximately 4.2 - 4.8 US gallons per hour. If your 4-stroke engine is burning less than that your engine is producing less than that amount of power. Again, assuming it is maintained and operated properly. Another way to look at it is each US gallon/hour is equivalent to roughly 12 1/2 to 14 hp.
Most Rotax 2-stroke engines run closer to .6 lb/hp/hr BSFC.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Richard Pike
PostPosted: Mon Mar 01, 2010 10:28 am    Post subject: Re: Fuel Reserve and UL's Reply with quote
Thom Riddle wrote:
GeoB,
For example:
Thom, math is the weakest of all my weak skills, so given that I typically burn 4 gph at 5300 rpm, how do I set up the equation (using a 2-stroke) to figure out how much horsepower I am using to do it? Knowing the answer to that tells me how much horsepower it takes to push my MKIII at 63-65 mph.
Richard Pike
MKIII N420P (420ldPoops)
Thom Riddle
PostPosted: Mon Mar 01, 2010 10:42 am    Post subject: Re: Fuel Reserve and UL's Reply with quote
Richard,
Assuming my statement is correct, that most Rotax 2-stroke engines use about .60 lbs of fuel per hour per horsepower, you take the known fuel consumption of 4 GPH and multiply it by 6 lbs/ US gallon to get 24 lbs/hour fuel consumption.
4 GPH x 6 lbs/US gallon = 24 lbs/hour
Then divide the 24 lbs/hr by the approximate .60 Brake Horsepower Specific Consunption (BSFC) figure as follows:
24 lbs/hour / .6 lb = 40 HP
It turns out to be pretty easy math to do in your head with a 2-stroke BSFC of about .6 since each US gallon of fuel weighs 6 lbs. If your 2-stroke engine if you throttle back to 3.5 gph your engine is producing approximately 35 HP. In other words, about 10 HP per GPH.
I hope this helps.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Thom Riddle
PostPosted: Mon Mar 01, 2010 10:44 am    Post subject: Re: Fuel Reserve and UL's Reply with quote
OOOPs.
BSFC stands for Brake Specific Fuel Consumption. I got my words twisted around and mixed up. Aging ungracefully, as you can plainly tell.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
NeilsenRM(at)comcast.net
PostPosted: Mon Mar 01, 2010 10:52 am    Post subject: Fuel Reserve and UL's Reply with quote
Thom
I don't mean to throw cold water on you calculations but. Throttled engines
waste a lot of power working against the vacuum behind the throttle plate. I
have no idea how much fuel is burned at idle throttle but your power per
fuel burn calculations would be off the charts. A calculation of 75% power
by fuel consumption needs to take into account of this non liner fuel
efficiency and might give you only 70-73% power.
Rick Neilsen
Redrive VW Powered MKIIIC
Thom Riddle
PostPosted: Mon Mar 01, 2010 2:04 pm    Post subject: Re: Fuel Reserve and UL's Reply with quote
Rick,
You are correct about it not being linear over a wide RPM range but it is close enough for first order estimates at any reasonable cruise RPM.
There is usually one most efficient engine rpm, i.e., the rpm at which the engine produces the most amount of power for each ounce of fuel consumed. Attached is an image from a Rotax 2-stroke manaul showing how the BSFC varies with RPM for the 582. Notice that it is most efficient at about 5,700-5,800 rpm. This assumes a correct prop loading among other things. Since the number I quoted is really only valid at or near normal cruise RPM, where it is most efficient, the efficiency drops off somewhat on either side of that RPM, as you can see on the cruve. BUT the BSFC and the known fuel consumption with a little arithmetic does give a rough estimate of the HP being produced during cruise at any altitude. The RPM alone is not a very good prediction of HP being produced over a wide range of density altitudes, at least not as good as fuel consumption in normal cruise rpm range.
 Filesize:  130.47 KB
 Viewed:  14010 Time(s)
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Dana
PostPosted: Mon Mar 01, 2010 3:56 pm    Post subject: Fuel Reserve and UL's Reply with quote
At 01:50 PM 3/1/2010, Richard & Martha Neilsen wrote:
I don't mean to throw cold water on you calculations but. Throttled engines waste a lot of power working against the vacuum behind the throttle plate. I have no idea how much fuel is burned at idle throttle but your power per fuel burn calculations would be off the charts. A calculation of 75% power by fuel consumption needs to take into account of this non liner fuel efficiency and might give you only 70-73% power.
That makes sense... if it's 0.6 lb/hp-hour, then at 3.3gph (cruise at 5700 rpm) my Cuyuna should be producing 33hp... a wee bit more than 75% power...
-Dana
Capital punishment: people in the Capitol need to be punished... [quote][b]
Page 2 of 3
