		flylists(at)dbarrett.net Guest
		sprocket(at)vx-aviation.c Guest
				 Posted: Wed Feb 10, 2010 9:42 am    Post subject: Pitot heat relays |
				These are standard automotive relays.  If you don't want to place the
 minimum order, pick one up at your favorite auto parts store.
 I use devices that have internal resistors (or diodes) because it saves a
 bit of wiring-- but have 14 of them in my aircraft [another long topic about
 switch failures vs relay reliability].
 You can also purchase relay sockets that make installation a bit easier, if
 you wish.
 Vern Little
 Vx Aviation
 Sent: Wednesday, February 10, 2010 7:26 AM
 To: <aeroelectric-list(at)matronics.com>
 Subject: Pitot heat relays
		pestar
  Joined: 11 Apr 2007 Posts: 61 Location: Auckland, New Zealand
				 Posted: Wed Feb 10, 2010 1:07 pm    Post subject: Re: Pitot heat relays |
				Vern
 What manufacturers relays are you using where the diodes are built in?
 Peter Armstrong
		user9253
  Joined: 28 Mar 2008 Posts: 1944 Location: Riley TWP Michigan
				 Posted: Thu Feb 11, 2010 6:19 am    Post subject: Re: Pitot heat relays |
				Both Digikey and Mouser have diodes and relays.  Search their websites for this part number: G8JN-1C6T-F-DC12 made by Omron.  It has a metal one-hole mounting bracket and is weather proof.  Here is the data sheet:
 http://www.components.omron.com/components/web/PDFLIB.nsf/0/39018354E59A56C985257201007DD68C/$file/G8JN_0607.pdf
 I thought it interesting that the normally open contacts have a higher current rating than the normally closed contacts, maybe because magnetism closes contacts quicker and tighter with less bounce than a spring does.
 Joe
  _________________ Joe Gores |
		dfritzj(at)yahoo.com Guest
				 Posted: Thu Feb 11, 2010 6:55 am    Post subject: Pitot heat relays |
				I got mine from Waytek. I think they were Bosch.
 Dan
		pwmac(at)sisna.com Guest
				 Posted: Thu Feb 11, 2010 9:02 am    Post subject: Pitot heat relays |
				Ford uses N2 filled, diode internal relays used for the glow plugs. A
 handy source. I would have to check, but I bet NAPA sells the
 identical part for less $$??
 Paul
				 Posted: Thu Feb 11, 2010 2:11 pm    Post subject: Pitot heat relays |
				Here's what I'm using:  Digikey 255-2161-ND
 They have the built-in resistors.
 Standard automotive type.  Not having to wire in the diodes/resistors is a
 big bonus.  Also, the coils are polarity insensitive when using resistors
 rather than diodes, if that matters.
 Vern
 Sent: Wednesday, February 10, 2010 1:07 PM
 Subject: Re: Pitot heat relays
