flylists(at)dbarrett.net Guest
sprocket(at)vx-aviation.c Guest
Posted: Wed Feb 10, 2010 9:42 am Post subject: Pitot heat relays |
These are standard automotive relays. If you don't want to place the
minimum order, pick one up at your favorite auto parts store.
I use devices that have internal resistors (or diodes) because it saves a
bit of wiring-- but have 14 of them in my aircraft [another long topic about
switch failures vs relay reliability].
You can also purchase relay sockets that make installation a bit easier, if
you wish.
Vern Little
Vx Aviation
Sent: Wednesday, February 10, 2010 7:26 AM
To: <aeroelectric-list(at)matronics.com>
Subject: Pitot heat relays
pestar
Joined: 11 Apr 2007 Posts: 61 Location: Auckland, New Zealand
Posted: Wed Feb 10, 2010 1:07 pm Post subject: Re: Pitot heat relays |
Vern
What manufacturers relays are you using where the diodes are built in?
Peter Armstrong
user9253
Joined: 28 Mar 2008 Posts: 1942 Location: Riley TWP Michigan
Posted: Thu Feb 11, 2010 6:19 am Post subject: Re: Pitot heat relays |
Both Digikey and Mouser have diodes and relays. Search their websites for this part number: G8JN-1C6T-F-DC12 made by Omron. It has a metal one-hole mounting bracket and is weather proof. Here is the data sheet:
http://www.components.omron.com/components/web/PDFLIB.nsf/0/39018354E59A56C985257201007DD68C/$file/G8JN_0607.pdf
I thought it interesting that the normally open contacts have a higher current rating than the normally closed contacts, maybe because magnetism closes contacts quicker and tighter with less bounce than a spring does.
Joe
_________________ Joe Gores |
dfritzj(at)yahoo.com Guest
Posted: Thu Feb 11, 2010 6:55 am Post subject: Pitot heat relays |
I got mine from Waytek. I think they were Bosch.
Dan
pwmac(at)sisna.com Guest
Posted: Thu Feb 11, 2010 9:02 am Post subject: Pitot heat relays |
Ford uses N2 filled, diode internal relays used for the glow plugs. A
handy source. I would have to check, but I bet NAPA sells the
identical part for less $$??
Paul
Posted: Thu Feb 11, 2010 2:11 pm Post subject: Pitot heat relays |
Here's what I'm using: Digikey 255-2161-ND
They have the built-in resistors.
Standard automotive type. Not having to wire in the diodes/resistors is a
big bonus. Also, the coils are polarity insensitive when using resistors
rather than diodes, if that matters.
Vern
Sent: Wednesday, February 10, 2010 1:07 PM
Subject: Re: Pitot heat relays
