javiercarrascob
Posted: Thu Jan 28, 2010 8:55 pm Post subject: Gill attachment replacement/fix |
Hello gang!
Hey any advice on how to repair this gill attachment bar?
Or how to replaces them... I'm talking about the thingy that holds the bar in place and that connects to the engine pistons. please see the attached picture.
It broke during a 8 G vertical pull.
JC
| how can I fix/replace this? |
69.9 KB |
13272 Time(s) |
cjpilot710(at)aol.com Guest
Posted: Fri Jan 29, 2010 4:24 am Post subject: Gill attachment replacement/fix |
JC,
You can make the "thingy". It's not that hard. The "thingy" is just an aluminum tube that has had its ends squeezed and bent, than holes drilled at the ends. Its kind of important on how long they are and angles of the bends, but super dup per wise. Any A&P could make one of these "thingy" in less than an hour. HOWEVER I happen to have some of those "thingys" that I could not use when I replaced the gill system on CJ-6. 8Gs???? Man that must have hurt.
Jim "Pappy" Goolsby
N642K
Posted: Fri Jan 29, 2010 7:27 am Post subject: Re: Gill attachment replacement/fix |
8 G's? I'd continue to look for broken things and loose rivets. Especially at the belly, center of the wings.
Plus if that was my airplane, from that picture, I'd say I was out of oil.
talew(at)bellsouth.net Guest
Posted: Fri Jan 29, 2010 7:36 am Post subject: Gill attachment replacement/fix |
What kind of aircraft did you put the 8g's on ?
Terry
Posted: Fri Jan 29, 2010 8:01 am Post subject: Gill attachment replacement/fix |
JC,Send me the length (there are 4-5 different ones on each set of gills) I most likley have them in stock. 8 g's?? You may need more than just a shutter standoff rod...........
Doug
On Thu, Jan 28, 2010 at 8:55 PM, javiercarrascob <javiercarrascob(at)yahoo.com (javiercarrascob(at)yahoo.com)> wrote:
Maybe life is not the party that we were expecting,
but in the mean time, we're here, the band is playing, so we may as well dance....."
Douglas Sapp
Doug Sapp LLC
18B Riverview Road
Omak WA 98841
PH 509-826-4610
Fax 509-826-3644
Noplugs
Posted: Fri Jan 29, 2010 6:00 pm Post subject: Re: Gill attachment replacement/fix |
I would like to know where you got that nice looking seal on the outer ring, mine...well I'm embarrassed to call it a seal.
Posted: Fri Jan 29, 2010 6:38 pm Post subject: Gill attachment replacement/fix |
Try an aircraft upholstry shop. They can make one for you. The fun part will be mounting it on the ring.
Doc
Posted: Sat Jan 30, 2010 8:22 am Post subject: Gill attachment replacement/fix |
I have the new outer ring w/seal in stock for the CJ6, but you would have to change out the metal plates which hold the ends of the gill vane pivot rods. The CJ6 uses a T type end on the rods, while the Yak uses a C/S straight slot type end. Other than that difference they are the same.
Doug
On Fri, Jan 29, 2010 at 6:00 PM, Noplugs <qas44n(at)yahoo.com (qas44n(at)yahoo.com)> wrote:
Douglas Sapp
Doug Sapp LLC
18B Riverview Road
Omak WA 98841
PH 509-826-4610
Fax 509-826-3644
Posted: Sat Jan 30, 2010 7:02 pm Post subject: Gill attachment replacement/fix |
Sierra Hotel… I just found a source for the YAK-50 gill axles.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of doug sapp
Sent: Saturday, January 30, 2010 10:21 AM
To: yak-list(at)matronics.com
Subject: Re: Re: Gill attachment replacement/fix
Doug
--> Yak-List message posted by: "Noplugs" <qas44n(at)yahoo.com (qas44n(at)yahoo.com)>
http://forums.matronics.com/viewtopic.php?p=283994#283994
rget="_blank">http://www.matronics.com/Navigator?Yak-List
le, List Admin.
Douglas Sapp
Doug Sapp LLC
18B Riverview Road
Omak WA 98841
PH 509-826-4610
Fax 509-826-3644
| Quote: | | http://www.matronics.com/Navigator?Yak-List | 0123456789
keithmckinley
Posted: Sun Jan 31, 2010 10:17 am Post subject: Re: Gill attachment replacement/fix |
I think the "thingy" connected to the "piston" broke during an 8 G landing.
But that's just me.
javiercarrascob
Posted: Sun Jan 31, 2010 7:54 pm Post subject: Re: Gill attachment replacement/fix |
Thank you all for your suggestions!!!
I will try to briefly reply to everyone:
I apologize for not knowing the proper term for the part that Iām seeking (I still donāt)ā¦
The plane is a Yak-55 (build for 9 Gās), and while doing Vertical rolls I normally do the initial pull at 7 or 7.5 Gās. In this Particular time I heard a metallic ping, discontinued flight and after taking the cowlings off I saw the āGill Barā broke at the base.
I was also wondering if there was something that looks sturdier (like some 52-TWs) as
Doug suggested.
Iāll have to go next weekend and measure them and I may need a couple.
The nice looking seal on the outer ring came with the plane⦠sorry ļ
javiercarrascob
Posted: Sun Jan 31, 2010 8:03 pm Post subject: Gill attachment replacement/fix |
Hi Doug Thank you very much,
Let me take the measures next week, how much are the ones that you have?
JC
--- On Fri, 1/29/10, doug sapp <dougsappllc(at)gmail.com> wrote:
Subject: Re: Gill attachment replacement/fix
Date: Friday, January 29, 2010, 11:00 AM
JC, Send me the length (there are 4-5 different ones on each set of gills) I most likley have them in stock. 8 g's?? You may need more than just a shutter standoff rod...........
Doug
Douglas Sapp
Doug Sapp LLC
18B Riverview Road
Omak WA 98841
PH 509-826-4610
Fax 509-826-3644
=nofollow target=_blank>http://www.matronics.com/Navigator?Yak-List
et=_blank>http://forums.matronics.com
llow target=_blank>http://www.matronics.com/contribution
