C of G and a heavy nose...
pipross
PostPosted: Tue Jan 19, 2010 4:21 pm    Post subject: C of G and a heavy nose... Reply with quote
Hi all,
I brought a 701 with a EA81 engine 6 months ago. I've done about 100 hours in it so far but I'm still struggling with the weight and balance. When I brought it, it was forward CG, to the point of being dangerous, when I cut the throttle, just myself onboard, it would drop like a stone (think helicopter autorotation..) I thought.. some weight in the tail... 5kg's... and suddenly it had a glide ratio. I now have 8kg's in the tail (I know it's alot) and it handles well. Too much more weight in the tail and it gets a bit wobbly, not aft CG, but too much weight on a long arm. What I'm trying to achieve is being able to hold my nose off on touchdown, as JG was talking about in a previous post, with power off, which is what I can do with other well balanced aircraft. Whilst I understand that if I put a rotax in I would probably solve the weight and balance problem, I don't really want to spend the $$$ involved in that. The EA81 goes well, apart from the weight problem. I have a warp drive prop. Any comments and suggestions would be useful..
Cheers
Ross
ronlee
PostPosted: Tue Jan 19, 2010 5:07 pm    Post subject: Re: C of G and a heavy nose... Reply with quote
It's hard to keep the nose off the ground consistently with slats. The nose either wants to go up or down with little stick movement. Take the slats off and put on vortex generators and it will be much easier to flare and keep the nose wheel off and steady.
Ron Lee
Tucson, Arizona
arno7452(at)bellsouth.net
PostPosted: Tue Jan 19, 2010 5:08 pm    Post subject: C of G and a heavy nose... Reply with quote
Ross,
I suggest you sell this thing. But, there are still 2 cycle replacement
engines around that are cheap and light weight.
Ken
lvuman(at)gmail.com
PostPosted: Tue Jan 19, 2010 5:22 pm    Post subject: C of G and a heavy nose... Reply with quote
The trailing edge of the elevator is bent slightly up to compensate for the lighter designed weight (80HP) of the 701.  Bend the trailing edge down "slightly" and it will make a huge difference on keeping the nose off longer on landing and give you more authority in back trim on landing approach.  Simple solution.  Jim
On Tue, Jan 19, 2010 at 5:21 PM, pipross <pipross(at)xtra.co.nz (pipross(at)xtra.co.nz)> wrote:
[quote] --> Zenith701801-List message posted by: "pipross" <pipross(at)xtra.co.nz (pipross(at)xtra.co.nz)>
Hi all,
I brought a 701 with a EA81 engine 6 months ago. I've done about 100 hours in it so far but I'm still struggling with the weight and balance. When I brought it, it was forward CG, to the point of being dangerous, when I cut the throttle, just myself onboard, it would drop like a stone (think helicopter autorotation..) I thought.. some weight in the tail... 5kg's... and suddenly it had a glide ratio. I now have 8kg's in the tail (I know it's alot) and it handles well. Too much more weight in the tail and it gets a bit wobbly, not aft CG, but too much weight on a long arm. What I'm trying to achieve is being able to hold my nose off on touchdown, with power off, which is what I can do with other well balanced aircraft. Whilst I understand that if I put a rotax in I would probably solve the weight and balance problem, I don't really want to spend the $$$ involved in that. The EA81 goes well, apart from the weight problem. I have a warp drive prop. Any comments and suggestions w!
 ould be useful..
Cheers
Ross
http://forums.matronics.com/viewtopic.php?p=282338#282338
-List" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
le, List Admin.
larry(at)macsmachine.com
PostPosted: Tue Jan 19, 2010 5:44 pm    Post subject: C of G and a heavy nose... Reply with quote
Hi Ross,
Not sure of your configuration, but you might put the radiator back
under the belly a ways and move the 18 lbs or so that far to improve
your center of gravity.
I've attached a picture of an installation that does exactly that, tho
he's not using a Subaru, the installation is clearly the same for 601 or
701 with an EA-81.
My site shows the installation of this radiator on my engine page.
See attached image too.
pipross wrote:
Hi all,
I brought a 701 with a EA81 engine 6 months ago. I've done about 100 hours in it so far but I'm still struggling with the weight and balance. When I brought it, it was forward CG, to the point of being dangerous, when I cut the throttle, just myself onboard, it would drop like a stone (think helicopter autorotation..) The EA81 goes well, apart from the weight problem.
Cheers
Ross
http://forums.matronics.com/viewtopic.php?p 82338#282338
 Filesize:  99.26 KB
 Viewed:  25533 Time(s)
lgold(at)quantum-associat
PostPosted: Tue Jan 19, 2010 6:02 pm    Post subject: C of G and a heavy nose... Reply with quote
This sounds like a bad idea to me. If slats bring the center of lift forward
somewhat taking them off will exacerbate the balance problem.
pipross
PostPosted: Tue Jan 19, 2010 7:58 pm    Post subject: Re: C of G and a heavy nose... Reply with quote
Thanks for your replys... I forgot to mention it was built without slats (with VG's), I'm not a fan of two strokes particularly, I used to fly trikes and was not comfortable over bush or water hoping my two stroke would keep cycling, the radiator idea is pretty good, i'll attach a photo showing the current setup if I can find a side on one
pipross
PostPosted: Tue Jan 19, 2010 8:02 pm    Post subject: Re: C of G and a heavy nose... Reply with quote
Like this too, when you say bend, are we talking about cable adjustments, or something a little more agricultural??...
Ross
[quote="lvuman(at)gmail.com"]The trailing edge of the elevator is bent slightly up to compensate for the lighter designed weight (80HP) of the 701.� Bend the trailing edge down "slightly" and it will make a huge difference on keeping the nose off longer on landing and give you more authority in back trim on landing approach.� Simple solution.� Jim
johndread(at)aol.com
PostPosted: Tue Jan 19, 2010 8:13 pm    Post subject: C of G and a heavy nose... Reply with quote
Hi Ross;
 There was a post a year or so ago that was OK'd by the factory. The problem was that the elevator trim did not have much authority in one direction. The solution was to bend the rear of the elevator up so it was inline with the LE of the elevator. This should also help the hold the nose off.
John Read
CH701 - Elbert CO - Jabiru 3300
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 1/19/2010 9:04:31 P.M. Mountain Standard Time, pipross(at)xtra.co.nz writes:
--> Zenith701801-List message posted by: "pipross" <pipross(at)xtra.co.nz>
Ross
http://forums.matronics.com/viewtopic.php?p=282380#282380===============================================
_-= = Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
pipross
PostPosted: Tue Jan 19, 2010 8:18 pm    Post subject: Re: C of G and a heavy nose... Reply with quote
Some pre painting photos that'll show the layout... Thanks for the elevator info John..
 Filesize:  42.48 KB
 Viewed:  25510 Time(s)
pipross
PostPosted: Tue Jan 19, 2010 8:19 pm    Post subject: Re: C of G and a heavy nose... Reply with quote
and some more....
 Filesize:  51.99 KB
 Viewed:  25507 Time(s)
pipross
PostPosted: Tue Jan 19, 2010 8:21 pm    Post subject: Re: C of G and a heavy nose... Reply with quote
and now
 Filesize:  52.34 KB
 Viewed:  25502 Time(s)
vgstol(at)bigpond.net.au
PostPosted: Tue Jan 19, 2010 8:40 pm    Post subject: C of G and a heavy nose... Reply with quote
The slats don't bring the center of lift forward.  A bit surprising I know, but tested over and over again, that removing the slats caused no change in trim.  See the testing and results at www.stolspeed.com   There's a whole new set of tests there, comparing the performance with slats/no slats.
JG
On Wed, Jan 20, 2010 at 11:50 AM, Les Goldner <lgold(at)quantum-associates.com (lgold(at)quantum-associates.com)> wrote:
[quote]--> Zenith701801-List message posted by: "Les Goldner" <lgold(at)quantum-associates.com (lgold(at)quantum-associates.com)>
mksoucy(at)yahoo.com
PostPosted: Wed Jan 20, 2010 2:13 am    Post subject: C of G and a heavy nose... Reply with quote
What about an Aero Vee engine.
Sent from my iPod
On Jan 19, 2010, at 7:21 PM, "pipross" <pipross(at)xtra.co.nz> wrote:
Hi all,
ould be useful..
Cheers
Ross
blackmore(at)platinum.ca
PostPosted: Sat Jan 23, 2010 6:51 am    Post subject: C of G and a heavy nose... Reply with quote
I was just wondering if anyone has tried to put a jack screw like the ones found on the pa 18 , Navion and others, it sounds like a slick way to trim the tail, I know I shall be needing the weight back there anyway
Chris
[i]----
PostPosted: Sat Jan 23, 2010 12:10 pm    Post subject: C of G and a heavy nose... Reply with quote
Changing the incidence of the horizontal stab works for trimming at cruise speeds, but loses effectiveness at the very slow landing speeds of these aircraft.  So, the nose will still come down heavily on touch down, or even before, when the weight and balance overcomes the diminishing aerodynamic forces.....   JG
On Sun, Jan 24, 2010 at 12:51 AM, Chris Blackmore <blackmore(at)platinum.ca (blackmore(at)platinum.ca)> wrote:
[quote] I was just wondering if anyone has tried to put a jack screw like the ones found on the pa 18 , Navion and others, it sounds like a slick way to trim the tail, I know I shall be needing the weight back there anyway
Chris
[i]----
PostPosted: Sat Jan 23, 2010 12:24 pm    Post subject: C of G and a heavy nose... Reply with quote
Thanks, just learning!!, and still looking for an orphaned fuselage .
[i]----
jetboy
PostPosted: Sat Jan 23, 2010 12:46 pm    Post subject: Re: C of G and a heavy nose... Reply with quote
Ross:
Notwithstanding my opinion that the most important thing is to ensure the weight/balance is within design limits for TC 10141E compliance, and a "701" without the slats is NOT, you may get sufficient elevator authority with power off by installing the elevator VG kit from Zenair.
They have some videos of a set being trialled which is quite impressive.
Ralph
Ralph - CH701 / 2200a
pipross
PostPosted: Sat Jan 23, 2010 3:53 pm    Post subject: Re: C of G and a heavy nose... Reply with quote
Thanks Ralph, I already have VG's on the wings and the elevator
Ross
