passenger stick
sarg314(at)gmail.com
PostPosted: Sat Dec 19, 2009 9:06 am    Post subject: passenger stick Reply with quote
I put a 1/4" pin thru my passenger side stick (RV-6A) secured with a spring clip.  There's a small connector on the cable from the stick grip, so the thing is pretty easily removable.  My problem is that it wobbles slightly.  I tried putting a little scotch tape on it to fill the gap, but 1 layer of scotch tape on the tube is too much. So it must be just a few thousandths undersize. Still it's easy to feel.  Even when the pilot stick is moved I can feel the passenger stick rattling around.   Does any one have any suggestions for securing this?
Tom Sargent, RV-6A, final assembly
sbuc(at)hiwaay.net
PostPosted: Sat Dec 19, 2009 1:22 pm    Post subject: passenger stick Reply with quote
Deform the end of the stick just enough to make it less "round". That
should make it a friction fit in the socket.
Sam Buchanan
sportav8r(at)gmail.com
PostPosted: Sat Dec 19, 2009 1:54 pm    Post subject: passenger stick Reply with quote
Tom, I replaced the supplied steel tube with hardware store aluminum, for weight savings and because the steel stick caused my panel mounted compass to go nuts.  A spiral wrap of black electrician's tape (not overlapping) makes for a snug fit.  I removed the stick-mounted pax PTT switch when I made the change, and did not realize until a long time after, that with my current intercom wiring and no passenger PTT switch, when I key the mic and let the pax talk on the comm, all anyone hears is dead air.  Drat!  They have to use my headset to talk to the other members of the flight, and that's not going to happen!  Project for a rainy day, I guess.
I did the spring clip/clevis pin thing at first, too, but decided it was totally unnecessary.  I leave the stick out unless I intend to offer the pax some stick time.  Makes ingress and egress for beefier thighs much more comfortable and assures I have full aileron deflection available.
On Sat, Dec 19, 2009 at 11:38 AM, thomas sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)> wrote:
[quote] I put a 1/4" pin thru my passenger side stick (RV-6A) secured with a spring clip.  There's a small connector on the cable from the stick grip, so the thing is pretty easily removable.  My problem is that it wobbles slightly.  I tried putting a little scotch tape on it to fill the gap, but 1 layer of scotch tape on the tube is too much. So it must be just a few thousandths undersize. Still it's easy to feel.  Even when the pilot stick is moved I can feel the passenger stick rattling around.   Does any one have any suggestions for securing this?
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
t="_blank">http://www.matronics.com/Navigator?RV-List
tp://forums.matronics.com
Bret Smith
PostPosted: Sat Dec 19, 2009 3:51 pm    Post subject: passenger stick Reply with quote
Why not tape off the stick above the joint and hit the area that slides in the joint with a light coat of your favorite spray paint. If it is still not snug enough, hit it with another coat.
Bret Smith
RV-9A N16BL
Blue Ridge, GA
www.FlightInnovations.com
Bret Smith
RV-9A (Emp)
bob194bn(at)verizon.net
PostPosted: Sat Dec 19, 2009 4:55 pm    Post subject: passenger stick Reply with quote
Tom when i built my 9-a painted stick and sanded down to friction fit in scoket very tight, but can be removed in flight and replaced in flight no pins needed.
To: rv-list <rv-list(at)matronics.com>
Sent: Sat, December 19, 2009 8:38:11 AM
Subject: passenger stick
[b]www.aeroelectric.com
omebuiltHELP
Dale Ensing
PostPosted: Sat Dec 19, 2009 5:42 pm    Post subject: passenger stick Reply with quote
One or two more coats of paint on the stick..maybe?
Dale Ensing
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
dan.pat.b(at)gmail.com
PostPosted: Sat Dec 19, 2009 5:59 pm    Post subject: passenger stick Reply with quote
Tom:My pax side stick fits tightly and requires considerable effort to remove.  That notwithstanding, I secured it with an AN3 bolt & nyloc nut - but of course it's not conveniently removed - takes about 10 minutes and can only be done on the ground.   Some builders use a pin with a ring on one end and a spring clip on the other.  Others simply set it in place (friction fit) and hope it doesn't come out at some inopportune moment; it has happend.   I'd say, better safe now than sorry later.  Secure it - with a pin or bolt - doesn't cost much and only takes a few minutes.  I've been giving my wife lessons and if there is any way for that stick to come out accidentally - she'd find it.
Dan Bergeron
RV-7A, N307TB
Nearly 70 hours flight time since
first flight on 08/04/09 at 7B2 (Northampton, MA)
On Sat, Dec 19, 2009 at 4:15 PM, BOB L WATSON <bob194bn(at)verizon.net (bob194bn(at)verizon.net)> wrote:
From: thomas sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)>
To: rv-list <rv-list(at)matronics.com (rv-list(at)matronics.com)>
Subject: RV-List: passenger stick
omebuiltHELP [url=http://www.homebuilthelp.com/][/url]
==== _blank">www.aeroelectric.com .com" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com _blank">http://www.matronics.com/contribution t="_blank">http://www.matronics.com/Navigator?RV-List tp://forums.matronics.com [/b]
johnd(at)wlcwyo.com
PostPosted: Mon Dec 21, 2009 2:53 pm    Post subject: passenger stick Reply with quote
Check out the attached PDF. This is the mod I did to my passenger stick.
Do not fly without having the stick attached someway.
I had forgotten to attach my passenger stick and while letting the passenger perform some stalls, the stick came out.
Good thing I was following along with my hand on my stick.
You should have seen the look on his face when the stick came out.
Priceless
[b]John L. Danielson[/b]
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of thomas sargent
Sent: Saturday, December 19, 2009 9:38 AM
To: rv-list
[b]www.aeroelectric.comwww.buildersbooks.com
CONTROL_STICK_MOD_(1).pdf
 Filename:  CONTROL_STICK_MOD_(1).pdf
 Filesize:  39.4 KB
 Downloaded:  614 Time(s)
Deerlake(at)bresnan.net
PostPosted: Mon Dec 21, 2009 5:05 pm    Post subject: passenger stick Reply with quote
Hi, John.
That made me chuckle. When Charlie T. (now lives in Casper if you
didn't know) first flew with me, I let him fly it with a "loose stick"
and we hit a bit of turbulence. The stick came out. The look on his
face was hilarious!
I left my stick loose because there were too many times landing when I
needed to get some extra aileron and the passenger's leg was in the
way. My normal procedure on final was to pull it out and hand it to the
passenger. That always got some funny looks.
The downside to a loose stick is you really hit some turbulence. I was
flying west of my house and hit the worst turbulence I'd ever hit in 25
years of flying. The stick flew out and hit the canopy. That could
have been bad.
Bob Skinner
Priceless
**John L. Danielson**
racerjerry
PostPosted: Wed Dec 23, 2009 9:25 am    Post subject: Re: passenger stick Reply with quote
Install the removable passenger stick using an AN3 bolt & nyloc nut. Tightening the bolt will remove all backlash. Your insurance company, kids and wife will thank you (in that order).
Jerry King
