RV-10 compatible engines
rv10(at)sinkrate.com
PostPosted: Fri Apr 07, 2006 2:13 pm    Post subject: RV-10 compatible engines Reply with quote
I am still in the planning faze and rounding up tools but getting ready to purchase the empennage kit in the next couple of weeks.  I am wondering about motors.  Specifically which 540’s will work w/o a whole lot of re-arranging?  I am sure this has been covered several times but I cannot find much searching through the archived messages.  It seems there are several Aztec motors IO-540-C4B5’s on the market.  What about a Cherokee six motors O-540-E4B5?  Will any of these work?
Any info on motors and how to read motor codes would be appreciated.
Ben Westfall
Portland, OR
Almost an Empennage
jesse(at)itecusa.org
PostPosted: Fri Apr 07, 2006 2:40 pm    Post subject: RV-10 compatible engines Reply with quote
Any parallel valve 540 will do the trick.  The main thing that may not be the same would be the engine mount ears, but that is not the end of the world because they can be changed.  The parallel valve engines are the 235-260HP versions, not the 300+HP versions.  I think the angle valve models start in K, so anything else should be fine.  Some Aztecs have the 300HP versions, but both of the model numbers that you mentioned should be fine, though I am pretty sure you will have to change the ears if they come off the Aztec.  We have a C4B5 on N256H and we had to change the ears.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
I'm in Ecuador right now and should be back in the country by the end of May.  You may call me at 352-505-1899 and leave a message that I can check from down here.  Any I-TEC questions can be directed to the I-TEC office at 352-465-4545.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall
Sent: Friday, April 07, 2006 5:12 PM
Subject: RV-10 compatible engines
Ben Westfall
Portland, OR
Almost an Empennage
bldgrv10450(at)comcast.ne
PostPosted: Fri Apr 07, 2006 4:47 pm    Post subject: RV-10 compatible engines Reply with quote
Ben
I haven't put much effort into engine choice. All I know for now is that an IO-540 is the ticket and they cost a bunch of money. What I will share with you is that building the RV10 is a lot of fun. I got kit 450 for my birthday gift. I like to think of it as: kit number four fifty, for my 50th.
I too am here in Portland. Handy to Van's close by. I was able to will call the kits in my van.
Couple pictures of my progress attached.
Best wishes, you'll enjoy the project.
Paul Grimstad
 Filesize:  296.07 KB
 Viewed:  401 Time(s)
 Filesize:  303.13 KB
 Viewed:  398 Time(s)
