Firewall Forward Kit from Jab USA/Camloc Fasteners
AZFlyer
PostPosted: Wed Oct 07, 2009 11:50 am    Post subject: Firewall Forward Kit from Jab USA/Camloc Fasteners Reply with quote
List,
For those using the Jab USA supplied FWF kit:
Has anybody found the "Camloc Fasteners" (10 - Camloc #26S8-6) to be too long for the cowl? Just right? or ?
My cowl thickness seems to be around .150" which would indicate a 26S8-4 or -5.
I may be measuring incorrectly.....?
Thanks for feedback.
Mike Miller @ millrml@aol.com
601 XL-B, 3300, Dynon
Remember, "the second mouse gets the cheese"!
pete(at)usjabiru.com
PostPosted: Wed Oct 07, 2009 12:14 pm    Post subject: Firewall Forward Kit from Jab USA/Camloc Fasteners Reply with quote
Cowl thickness can vary a little bit and sometimes a -5 would work better.
Another option is to space the camloc body out away from the cowl with a
small washer or two between camloc body and cowl.
Pete
DaveG601XL
PostPosted: Thu Oct 08, 2009 2:56 am    Post subject: Re: Firewall Forward Kit from Jab USA/Camloc Fasteners Reply with quote
Mike,
I did just what Pete mentioned and spaced the camlock body away from the lower cowl with a piece of .032 aluminum. It worked great. Picture attached.
 Filesize:  101.15 KB
 Viewed:  6412 Time(s)
David Gallagher
Cincinnati, OH area
jakereyna(at)yahoo.com
PostPosted: Thu Oct 08, 2009 4:27 am    Post subject: Firewall Forward Kit from Jab USA/Camloc Fasteners Reply with quote
Mike, you might try another fastner, like Skybolt, they are adjustable. Here are a couple of links. The first is how I discovered Skybolt Fastners use on a Sonex cowl. Scroll to the bottom of the page for recommendations. Second link is to Skybolt.
http://www.americansonexassociation.org/Sonexenginecowlingmod.htm
http://www.skybolt.com/
Jake
AZFlyer
PostPosted: Fri Oct 09, 2009 7:28 am    Post subject: Re: Firewall Forward Kit from Jab USA/Camloc Fasteners Reply with quote
Many thanks to all that responded so quickly to my camloc question.
Now back to building.
