Pete54
Posted: Thu Aug 27, 2009 11:54 am Post subject: Re: uk 601 xl aircraft cleared for flight |
There are some similarities, if only about restoring the reputation. Whilst I understand the need for aileron circuit tension I tend to support the UK authorities stance. The CS-VLA design code, which all UK modern homebuilts must meet states that the controls must not flutter, even under cable failure conditions.
Loosing the tension in the circuit can occur for a variety of reasons and I'm not keen on the aircraft having the potential for ripping itself to pieces if that happens. Cable jumps a pulley, fairlead wears/loosens, a lot of things could happen.
I'll try and post the drawings tomorrow from work. I would guess that CH may not issue these as the liability issues are complex. However I know a guy building a recent xl kit which was imported from the US (mine is a CZAW kit), his airframe has a considerable number of beefed up components within it compared with mine - generally around the centre section, but also including the aft wing spar attachment.
Whilst I've been frustrated to hell by the lack of speed and indecision by the LAA we will mod my aircraft and get it flying and put this behind us.
_________________ Pete Morris |
LHusky
Joined: 19 Jun 2008 Posts: 86 Location: Madras, Oregon
Posted: Thu Aug 27, 2009 12:04 pm Post subject: uk 601 xl aircraft cleared for flight |
I look forward to seeing those drawings.
Larry Husky
Madras, Oregon
In a message dated 8/27/2009 12:56:05 P.M. Pacific Daylight Time, peter.morris(at)optimusaberdeen.com writes:
| Quote: | --> Zenith601-List message posted by: "Pete54" <peter.morris(at)optimusaberdeen.com>
Pete Morris
http://forums.matronics.com/viewtopic.php?p=260026#260026===============================================
_-= Use the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
rtdin
Joined: 16 Mar 2008 Posts: 46 Location: Florida panhandle
Posted: Thu Aug 27, 2009 1:22 pm Post subject: uk 601 xl aircraft cleared for flight |
I certainly would like to see drawings of the mods either from ZAC or smuggled out of the UK. This is encouraging. I would like to resume work on my project.
About that Bonanza thing. I went through that with a friend who had a Bonanza. The later models (such as his) needed an increased ruddervator area due to higher GW & power. Beech just added more chord ahead of the fwd ruddervator spar. This new area was not adequately supported. Following accidents, there was an AD that reduced airspeed. Then came kits from about three vendors to support the L.E. My friend's 35 ended up with brackets attached to the fuselage side and supporting the L.E. Problem solved. Vne restored.
The 35's were always unforgiving for the inexperienced. A noted local gent bought the farm early 50's in VFR-to-IFR conditions. It was then known as a grave yard spiral. He was very experienced, with combat time in SE-5s and Spads. (But no instrument rating)
RTD
601XL plans #6-6791 (wings) [quote][b]
Scotsman
Joined: 27 Aug 2007 Posts: 89 Location: Johannesburg, South Africa
Posted: Thu Aug 27, 2009 9:21 pm Post subject: Re: uk 601 xl aircraft cleared for flight |
"In other words, the basis for the flutter testing was not following maintenance procedures which specify cable tensioning!
Karl
[quote] ---"
Sorry Karl, but if I remember correctly the latest XL crash was on an aircraft that had recently tensioned the cables and had these confirmed as being correct (I think it was 6 hours before the incident flight but I stand corrected). Is it not possible that the issue is more complex than just tightening the cables?
As in the descriptions of the Bonanza incident, the first place which receives the blame in a crash of unknown cause is the pilot which is not dissimilar to our situation except it is the pilot/builder. The matter is highly subjective without clear evidence but I do find it unusual (especially in the latest incident) that a commercial pilot would fly outside of the envelope of the aircraft (especially with the aircraft's history of wing failure) as it would appear that the aircraft in question's aileron cables were appropriately tensioned.
As in the Bonanza incidents only time will tell whether aileron cable tension alone is a sufficient control. At least there appears to be progress in the publication of the various testing results regardless of which side of the fence you sit on.
James
_________________ Cell +27 83 675 0815 |
Pete54
Posted: Fri Aug 28, 2009 12:18 am Post subject: Re: uk 601 xl aircraft cleared for flight |
The smuggled drawings!
Not on the drawings are the changes to the elevator trim horn - which has to be reversed. In the UK we have to fit a large trim tab (the original test aircraft had a heavy prop). We now have a mod to reduce the effectiveness of that bigger trim tab......
120.07 KB |
23039 Time(s) |
Scotsman
Posted: Fri Aug 28, 2009 2:00 am Post subject: Re: uk 601 xl aircraft cleared for flight |
Hi Pete, I cannot access the tif file you uploaded to the thread...can you upload in a different format or any ideas why I cannot download them?
Cheers
James
psm(at)att.net Guest
Posted: Fri Aug 28, 2009 3:39 am Post subject: uk 601 xl aircraft cleared for flight |
Hi James,
Thanks for posting the drawings.
After looking at them, I have a couple of questions. I don't know if
you are the right person to ask or not, but you are at least "The
Messenger" so I will give it a try.
1. I could not find any definition for the balance weights (6BA01-2,
6BA01-3). Do you know how these weights are constructed? How much
do they weigh?
2. The image shows hinged ailerons. Do you have any idea how this
design might translate to hingeless ailerons? (Are all UK Zodiacs
built with piano hinges on ailerons?)
Paul
Camas, WA, USA
At 03:00 AM 8/28/2009, you wrote:
<james.roberts(at)computershare.co.za>
Cheers
James
jaybannist(at)cs.com Guest
Posted: Fri Aug 28, 2009 4:09 am Post subject: uk 601 xl aircraft cleared for flight |
James,
I think it is interesting that you choose to use the term "pilot/builder". In fact, the only thing common among all the XL crashes is that NONE of the involved pilots were the builders of the airplane that crashed.
I am assuming that the latest crash you refer to is the one in Utah. It is STRICTLY a personal opinion, but I believe the same thing happened to that unfortunate pilot as the phenomena that ended Steve Fossett's storied life - inadvertent entry into a mountain down draft that the pilot and his airplane simply could not overcome.
Jay Bannister
tensioned.
tonyplane(at)bellsouth.ne Guest
Posted: Fri Aug 28, 2009 7:08 am Post subject: uk 601 xl aircraft cleared for flight |
Or, the stick was used to remove the wings. As I have related previously, I was letting a passenger, who was a Piper Tomahawk owner, fly. It was a gusty day and on climb out at about 80 - 90 kts, the nose pitched up. He slammed the stick forward to lower the nose and gave the seat belts a good workout. He did not go too far forward with the stick as I blocked the stick with my hand; however I have no doubt, he would have put us through the canopy if not for the belts.
(I still can not believe an experienced pilot would have done something like that!)
Tony Graziano
XL/Jab; N493TG; 524 hrs
pchap(at)primus.ca Guest
Posted: Fri Aug 28, 2009 7:28 am Post subject: uk 601 xl aircraft cleared for flight |
At 06:00 28-08-09, you wrote:
C
It is a multipage TIFF file that I'm not sure many browsers or
graphics programs naturally read.
There may well be better solutions, but I use plugin
AlternaTIFF (www.alternatiff.com), available for different web browsers.
Free but requires registration.
Peter Chapman
Toronto, ON
Scotsman
Posted: Fri Aug 28, 2009 7:32 am Post subject: Re: uk 601 xl aircraft cleared for flight |
Paul - not me I'm afraid I believe that it was another guy who posted the plans...unfortunately I cannot access the link.
Jay - Mea culpa...after reading the various news articles it appeared to infer that he was the builder and/or involved in the build. It is a pertinent point though that you raise...is the reason for the wing failures due to overhandling/flying outside of the envelope due to the lack of familiarity with the sensitivity of control etc?...possibly.
However, even the pilot/builder will not have experienced the sensitivity of the XLs controls until his or her first flight (just the same as a person who buys a completed XL). So is it realistic to suggest that a pilot/builder will be more prone to ignoring/being unaware of the over controlling risk?
Similarly, if that were the case, I would expect to hear of similar wing failure incidents on other homebuilts where the owner is not the builder. It is personal opinion but I am not convinced by the theory that pilot error is the primary cause of all of the number of accidents that we have observed.
Cheers
James
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Fri Aug 28, 2009 7:33 am Post subject: Re: uk 601 xl aircraft cleared for flight |
| Pete54 wrote: | | I know a guy building a recent xl kit which was imported from the US (mine is a CZAW kit), his airframe has a considerable number of beefed up components within it compared with mine - generally around the centre section, but also including the aft wing spar attachment. |
What were the differences, especially since this was a recent kit from Zenith? Did they have anything in common with the new UK recommendations? (I couldn't view the tif file, so apologies in advance if that would have answered my question).
Patrick
carlossa52(at)gmail.com Guest
Posted: Fri Aug 28, 2009 7:49 am Post subject: uk 601 xl aircraft cleared for flight |
You can use the "Windows Pictures and Fax Viewer" (download the file, then right click on it and select the Viewer).
Optionally, using Files Explorer, right click the tiff file and select Preview.
Note that there are two pairs of buttons at the bottom of the viewer. The left most will take you from file to file within the same folder.
The other pair will flip pages within a TIFF file - you can also flip pages with the page up/down keys on your keyboard.
The file in question has 4 pages.
Carlos
2009/8/28 Peter Chapman <pchap(at)primus.ca (pchap(at)primus.ca)>
| Quote: | --> Zenith601-List message posted by: Peter Chapman <pchap(at)primus.ca (pchap(at)primus.ca)>
| Quote: | --> Zenith601-List message posted by: "Scotsman" <james.roberts(at)computershare.co.za (james.roberts(at)computershare.co.za)>
C
It is a multipage TIFF file that I'm not sure many browsers or graphics programs naturally read.
There may well be better solutions, but I use plugin AlternaTIFF (www.alternatiff.com), available for different web browsers.
Peter Chapman
Toronto, ON
Doug.Norman(at)sportaviat Guest
Posted: Fri Aug 28, 2009 7:50 am Post subject: uk 601 xl aircraft cleared for flight |
I have some experience teaching people to fly the Zodiac as I’m a CFI and used my Zodiac for a while as a teaching platform. A repeatable characteristic among those who fly high(er)-wing-loaded aircraft and are transitioning to the Zodie is their heavy-handedness on the controls. This generalizes from private pilots to ATPs. In fact, there were two other CFIs I couldn’t sign-off to fly the Zodiac because they couldn’t land it – an almost unbreakable PIO near the ground for both. They were the instructors who spent most of their time in twins. It’s clear (to me) there is a certain kinesthetic sense required to fly the Zodiac which is conflict with those built up in other GA airplanes. This seems to be borne out from the insurance stats. One-finger control to press on the stick to change attitude followed by trim is the drill I would often use.
Another “quirk” of the Zodiac is the location/height of the gear (I’m referring to a 2007 AMD airplane) and the angle of incidence of the wing (lower angle of incidence, not like the 650 is now or the 601 was earlier). This combination requires a deliberate rotating of the airplane for takeoff. Without the rotation the airplane will just continue down the runway never taking off. Given the weight distribution wrt the gear location, the deliberate action required to rotate is too much stick for maintaining the nose angle one wants for climbout. Thus, it almost immediately results in a nose-too-high attitude once the airplane leaves the ground.
The challenge is ensuring folks don’t panic at this point and shove the nose down (gotta ensure you box the stick with your hands!). That can result in a “good belt workout” at a critical altitude. If one takes off at 60 knots, there’s enough kinetic energy in the airplane for a nice easy correction.
love the plane,
Doug
Near 400 hrs in N601DN
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of T. Graziano
Sent: Friday, August 28, 2009 11:02 AM
Subject: Re: Re: uk 601 xl aircraft cleared for flight
Tony Graziano
----- Original Message -----
To: zenith601-list(at)matronics.com (zenith601-list(at)matronics.com)
Sent: Friday, August 28, 2009 7:03 AM
Subject: Re: Zenith601-List: Re: uk 601 xl aircraft cleared for flight
James,
Jay Bannister
| 0123456
789 | Quote: | Sorry Karl, but if I remember correctly the latest XL crash was on an aircraft
| 0 | Quote: | Sorry Karl, but if I remember correctly the latest XL crash was on an aircraft
| 1Sorry Karl, but if I remember correctly the latest XL crash was on an aircraft
| 2 | Quote: | Sorry Karl, but if I remember correctly the latest XL crash was on an aircraft
| 3 | Quote: | Sorry Karl, but if I remember correctly the latest XL crash was on an aircraft
| 4 | Quote: | Sorry Karl, but if I remember correctly the latest XL crash was on an aircraft
| 5 | Quote: | Sorry Karl, but if I remember correctly the latest XL crash was on an aircraft
| 6 | Quote: | Sorry Karl, but if I remember correctly the latest XL crash was on an aircraft
| 7 | Quote: | Sorry Karl, but if I remember correctly the latest XL crash was on an aircraft
| 8 | Quote: | Sorry Karl, but if I remember correctly the latest XL crash was on an aircraft
| 9 | Quote: | that had recently tensioned the cables and had these confirmed as being correct
| 0 | Quote: | that had recently tensioned the cables and had these confirmed as being correct
| 1 | Quote: | that had recently tensioned the cables and had these confirmed as being correct
| 2 | Quote: | that had recently tensioned the cables and had these confirmed as being correct
| 3 | Quote: | that had recently tensioned the cables and had these confirmed as being correct
| 4 | Quote: | that had recently tensioned the cables and had these confirmed as being correct
| 5 | Quote: | that had recently tensioned the cables and had these confirmed as being correct
| 6 | Quote: | that had recently tensioned the cables and had these confirmed as being correct
| 7 | Quote: | that had recently tensioned the cables and had these confirmed as being correct
| 8 | Quote: | that had recently tensioned the cables and had these confirmed as being correct
| 9 | Quote: | (I think it was 6 hours before the incident flight but I stand corrected). Is
| 0 | Quote: | (I think it was 6 hours before the incident flight but I stand corrected). Is
| 1
z601a(at)anemicaardvark.c Guest
Posted: Fri Aug 28, 2009 8:38 am Post subject: uk 601 xl aircraft cleared for flight |
On Friday 28 August 2009 10:33, PatrickW wrote:
| Quote: | What were the differences, especially since this was a recent kit from
My 601XL kit, delivered in October of last year, does not have all of the
stiffners added by the drawing. Six additional vertical stiffners are added,
three on either side of the center.
Two of these are pretty much the same as the attach points added for the stick
option. Two are inboard of this, between the stick attach and the center of
the carry-through spar.
The other two are "L" brackets added to the existing outboard wing attach
uprights.
I converted the drawings (the tiff actually has several drawings within it) so
I could read them. If there's enough interest, I'll post them in jpeg format.
I think I'll wait and see if Chris Heintz comments on these changes. I'm not
that convinced they do anything worthwhile.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Fri Aug 28, 2009 9:56 am Post subject: Re: uk 601 xl aircraft cleared for flight |
Doug,
I flew your airplane when it was based at CAMS Flight in Florida for a checkout prior to flying mine on it's first flight. It was great to have a 601XL available so close to Sun-N-Fun when I attended in 2008. My favorite picture here at work my me next to your beautiful airplane with palm trees in the background.
I was pleased that the Instructor there was very thorough in describing the pitch control of the XL. I had heard about pitch sensitivity on the forums and was glad to see he was on top of it. The checkout went smoothly as a result with me careful not to get into pitch PIO.
Of the small handful of rides I have given to pilots and non-pilots, it is the certified pilots that I am most watchful of. I have briefed them all about the pitch sensitivity prior to relinquishing the stick. The non-pilots have been very good at keeping to small movements. This is probably due to their unfamiliarity with flying, in general, combined with a bit of apprehension (dare I call it fear?). Most of the pilots start ham fisting it right away. I do not have much of a stomach for negative G's and have immediately grabbed the stick on several occasions to tame them down.
77.81 KB |
23009 Time(s) |
_________________ David Gallagher
Cincinnati, OH area |
Posted: Fri Aug 28, 2009 5:26 pm Post subject: uk 601 xl aircraft cleared for flight |
David,
I'm glad you were able to be introduced to the Zodie in my airplane; and
thanks for the kind words about it.
Best of continued good fortune to you and your airplane.
Doug
Pete54
Posted: Sat Aug 29, 2009 2:46 am Post subject: Re: uk 601 xl aircraft cleared for flight |
The beefed up parts I referred to are not those featured in the UK drawings (my apologies to those who could not read them and my thanks to the chap who has re-posted them.)
From memory it is the rear wing spar attachment points, the centre section uprights and the tailplane attachments where we have noticed differences - there may be others - these were just the areas the chap was working on an wanted to check my aircraft to get a feel for the final assembly. Then he started to measure the parts mentioned as they were so obviously different. The official reason he was given was these were changes due to the increase in mauw from 560 to 600kg.
Scotsman
Posted: Sat Aug 29, 2009 8:01 am Post subject: Re: uk 601 xl aircraft cleared for flight |
Hi Pete, do you know the thickness of the revised parts mentioned in your post above as I wanted to check against my own kit? James
Posted: Sat Aug 29, 2009 11:09 am Post subject: uk 601 xl aircraft cleared for flight |
"From memory it is the rear wing spar attachment points, the centre section
uprights and the tailplane attachments where we have noticed differences"
Some of these changes are not particularly new and some are related to the
650 changes.
The 4 large "L"s that tie the center spar to the outer skins of the fuselage
(6B13-1) are shown as 0.063 inches thick on my 08/05 plans. That was an
increase (form 0.040?) from my older plans. This change is listed in "ZODIAC
CH 601 XL Updates included in 3rd edition 1st revision: April 2005"
"6-B-13 02/05 WING JIG
1) 6B13-1 Rev. 1 change material thickness from t=.040” to t=.063” deleted
bend
radius = ¼” changed length from 470 to 480 (02/05)"
http://www.zenithair.com/zodiac/xl/data/xl-update-3rd-ed-1st-rev-4-05.pdf
The plate that attaches the rear spar to the fuselage (6B5-4) changed from
0.063 (08/05 plans) to 0.12. At OSH 2008 Patrick Hoyt (among others) noticed
the thicker plates on the 650 and asked Caleb about it (I was standing
there). Caleb said that to shift the plate on the 650 vertically (as
compared to the 601XL) to changes the wing's angle of incidence the height
of the plate had to be reduced. The increase in thickness was to give the
plate adequate strength in its attachment to the fuselage. Caleb said it had
nothing to do with strengthening the attachment between the rear spar and
the plate. Below is a picture Patrick shot:
http://picasaweb.google.com/Patrick.Hoyt/Zodiac650AtOshkosh#5243761730774797
442
This document states "Attach Plate Geometry and thickness changed to
accommodate change in wing incidence angle.":
"ZODIAC CH 650: Summary of changes from the Zodiac CH 601 XL (4th edition,
1/2008 drawings)"
http://www.zenithair.com/zodiac/ch650/data/650-drawing-list-6x-0.pdf
-- Craig
