oil Usage
bvossman(at)austin.rr.com
PostPosted: Thu Jul 02, 2009 5:10 am    Post subject: oil Usage Reply with quote
I have 200 hrs on my Jab 2200. I add 4 oz about every 3 hours to keep the level between "add oil" mark and 1/3 up the dipstick.
Bob Sonex/Jab 2200
zeprep251(at)aol.com
PostPosted: Thu Jul 02, 2009 5:39 am    Post subject: oil Usage Reply with quote
I have 440hrs on the 2200a in a MK3-C Kolb My vent system enters a 1 pint catch bottle then vents overboard The airframe stays clean by the vent hose,so all the oil ends up in the bottle.This indicates to me that the vent system on this engine requires some rethinking by Jabiru.My IO-470 continental used less oil in 25 hrs than the Jabiru does in 5hrs.This is a great little engine,they just need to tweak it in the vent and intake systems.
Gary Aman Akron Oh
tonyplane(at)bellsouth.ne
PostPosted: Thu Jul 02, 2009 5:49 am    Post subject: oil Usage Reply with quote
That is about what I use on my Jab3300, possibly slightly more, and also about the same dipstick reading for add of oil.
Tony Graziano
Zodiac XL/Jab3300; 506 hrs.
Lynn Matteson
PostPosted: Thu Jul 02, 2009 11:28 am    Post subject: oil Usage Reply with quote
What serial number?
Lynn Matteson
Jabiru 2200, #2062, 687.3 hrs
Sensenich 62"x46" Wood prop
Status: flying
On Jul 2, 2009, at 9:37 AM, zeprep251(at)aol.com wrote:
[quote] I have 440hrs on the 2200a in a MK3-C Kolb My vent system enters a
Gary Aman Akron Oh
Lynn
Kitfox IV-Jabiru 2200
N369LM
Lynn Matteson
What serial number?
Lynn Matteson
Status: flying
Bob Sonex/Jab 2200
contribution_-
Lynn
N369LM
Kayberg(at)AOL.COM
PostPosted: Thu Jul 02, 2009 12:21 pm    Post subject: oil Usage Reply with quote
In a message dated 7/2/2009 9:40:10 A.M. Eastern Daylight Time, zeprep251(at)aol.com writes:
The question of oil usage should be factored depending on the mission profile.
If you have a bird that can be whipped around, the oil can accumulate in the overflow bottle rather rapidly. If you always fly like grandma, not more than 30 degree banks and all positive G's, then you may only be burning it. Of course it will depend on where and how you place you  overflow bottle.
It will also depend on wether you overfill your oil regularly.
On a Kolb, you can get hammered around by thermals, so oil can be slopped up into the vent hose.
Since most Continentals use about a quart in 5-10 hours, that means your Jabiru must be using from 2.5 to 5 quarts in 5 hours!! Seems to me that something else is going on.
My experience is that Jabs do not burn much oil, but they can slop it with the best of them.
Doug Koenigsberg.
ces308
PostPosted: Thu Jul 02, 2009 7:54 pm    Post subject: Re: oil Usage Reply with quote
I have put very little in my A-2200 on my Kolb M3X with 32 hrs on it .However,I will pay close attention to what I add from here on out. And the vent catch on my engine seems to be a water/oil mix as it is very thin for it to be all oil not to mention if it was all oil from the crank case,then why is the oil level ok? After 2-3 hrs I empty the maybe 3-4 oz cup which is about 1/2 full. I simply soak what is in there with a paper towel and discard.
chris ambrose
M3X/Jab
N327CS
PostPosted: Fri Jul 03, 2009 8:56 pm    Post subject: oil Usage Reply with quote
Lynn,
Believe it is #1295
G.Aman
ces308
PostPosted: Fri Jul 03, 2009 9:18 pm    Post subject: Re: oil Usage Reply with quote
Lynn,
For what it's worth...mine is #1228 A-2200.
chris ambrose
M3X/jab
Lynn Matteson
PostPosted: Sat Jul 04, 2009 6:12 am    Post subject: oil Usage Reply with quote
Thanks, Gary...it really helps figure out what may be going on with
the engine if we would all post the serial number when we request
help....kinda like going to the doctor. He/she always needs to know
your age.
I'm not familiar with the Kolb...is it a pusher or tractor set-up?
Does your oil vent line run uphill right after the dipstick tube
attachment, then down to the bottle? And is the Kolb an exposed engine?
My Kitfox is an enclosed cowl, tractor, and only requires about 10 oz
of oil addition between 25 hour oil changes.
Lynn Matteson
Jabiru 2200, #2062, 689.3 hrs
Status: flying
On Jul 4, 2009, at 12:55 AM, zeprep251(at)aol.com wrote:
[quote] Lynn,
Believe it is #1295
G.Aman
Lynn
N369LM
Lynn Matteson
PostPosted: Sat Jul 04, 2009 6:19 am    Post subject: oil Usage Reply with quote
Thanks, Chris. On another group, they suggest putting all pertinent
data regarding the aircraft in your signature. (Of course, if you're
writing to your girlfriend, you can delete all the airplane stuff.)
That way, someone that may be able to help or comment, will know what
engine they are dealing with. Saves some dummy like me from having to
ask. Also, knowing the type of plane the engine is in helps too.
Lynn Matteson
Status: flying
On Jul 4, 2009, at 1:18 AM, ces308 wrote:
Lynn,
chris ambrose
M3X/jab
http://forums.matronics.com/viewtopic.php?p 51410#251410
Lynn
N369LM
PostPosted: Sun Jul 05, 2009 3:10 am    Post subject: oil Usage Reply with quote
Lynn
It,s a pusher,the rear of the engine is covered by a molded fairing that smooths airflow into the cooling shrouds.I have only one picture on the computer to send but maybe it will show enough to explain the set-up
G,Aman
 Filesize:  304.36 KB
 Viewed:  15638 Time(s)
Lynn Matteson
PostPosted: Sun Jul 05, 2009 9:37 am    Post subject: oil Usage Reply with quote
Gary-
I guess I'd have to see where the oil collection bottle is in
reference to the airflow to know if it seemed right for your
installation. However, someone with the same setup might chime in and
help you out. I just re-read your original post, and I'm not sure if
you're indicating a problem or not. If all the expelled oil ends up
in the bottle, that seems right to me, unless you think TOO much oil
is being expelled by the engine. Just keep in mind that if the vent
overboard is in a high airflow area, maybe a vacuum is being formed
and helping to draw oil out of the engine.
Lynn Matteson
Jabiru 2200, #2062, 693.9 hrs
Status: flying
On Jul 5, 2009, at 6:59 AM, zeprep251(at)aol.com wrote:
[quote] Lynn
G,Aman
Lynn
N369LM
PostPosted: Sun Jul 05, 2009 12:23 pm    Post subject: oil Usage Reply with quote
Lynn,
Oil collection bottle is directly behind my seat on the floor of the fuselage.The last of the vent exits thru the floor on the bottom.It extends 1 inch below the bottom and is cut at 90 degrees to the pipe.I could place a short piece of 1/2" copper tube, cut at a 45 degree angle facing forward, in the tube which could slightly pressurize the system.I have had a modified PCV valve in the line 2 inches from the oil stick for some time now,hoping to put the crankcase in a partial vacuum,letting air out but not back in.This slowed the rate of oil loss but perhaps not for the reason it was installed.It may be just giving the oil a place to collect or to ubstruct its movement.
I can easily test the collector bottle for vacuum, for there is a 1/4 inch line installed from beside my seat thru the lid to near the bottom of the bottle to evacuate collected oil with a vacuum pump. If that test shows vacuum,I will try the angle vent to reverse it.The PCV valve will not let the crankcase be pressurized but could eliminate vacuum in the vent system ahead of it.
I'm pretty sure that not all of the missing oil from the engine ends up in the collector, but it does not leak externally at all.If it burns it,it burns it,and I can live with that.I would just like to keep the collector dry as possible.
Thanks for the input.I'll let you know what I find.
Gary Aman
ces308
PostPosted: Sun Jul 05, 2009 1:29 pm    Post subject: Re: oil Usage Reply with quote
Lynn and Gary,
I will take some pictures of my set up tomorrow and show you guys. I believe my engine is doing fine on the oil burn...you have to remember that we are talking oz's of oil here..when you only have 2.4 qts it just seems like a lot when a little is missing.when talking on my O-320-E2D we talk in Quarts...not oz's.Lynn...you go to any fly-ins? I will put you on our Mi Kolb email list and maybe we can hook up some morning and talk Jabs !
chris ambrose
M3X/Jab A-2200
N327CS
Lynn Matteson
PostPosted: Mon Jul 06, 2009 5:12 am    Post subject: oil Usage Reply with quote
Chris-
I TRY to go to as many fly-ins as possible, but it seems that if I
plan on going, that alerts the weatherman to throw some showers in my
path. : )
I got turned off on the Sun 'n' Fun trip for the past three years,
and the same for the Virginia Festival of Flight for the past two
years. However, I always make it to Oshkosh, sometimes even in the
winter. I go to a lot of breakfasts in the Michigan, Indiana, Ohio,
and sometimes eastern Illinois area. Where are you located, Chris?
Lynn Matteson
Status: flying
On Jul 5, 2009, at 5:29 PM, ces308 wrote:
Lynn and Gary,
chris ambrose
M3X/Jab A-2200
N327CS
http://forums.matronics.com/viewtopic.php?p 51621#251621
Lynn
N369LM
Lynn Matteson
PostPosted: Mon Jul 06, 2009 5:15 am    Post subject: oil Usage Reply with quote
It may be the difference between your Kolb pusher, and my enclosed-
engine tractor Kitfox, but your plumbing sounds really convoluted!
This oil collection business doesn't seem to me to have to be all
that complicated, but of course in an engine-exposed environment
things will be different.
Keep us posted will you, Gary?
Lynn Matteson
Status: flying
On Jul 5, 2009, at 4:22 PM, zeprep251(at)aol.com wrote:
[quote] Lynn,
Gary Aman
Lynn
N369LM
zeprep251(at)AOL.COM
PostPosted: Mon Jul 06, 2009 5:12 pm    Post subject: oil Usage Reply with quote
Lynn,
Testing indicates no vacuum at the vent exit.Going to try 100W in place of 15/50W at next oil change.The first couple hours after the oil change the level stays up on the stick.But after that it slowly starts to evaporate.I did not put the first 188 hours on this engine,so it may have had an event that could cause this issue.I,ll quit bitching now and keep adding oil as it needs it.It,s a sweet running engine even with the carb twisted 20 degrees to even out the egt's.
Thanks G.Aman
Lynn Matteson
PostPosted: Tue Jul 07, 2009 4:51 am    Post subject: oil Usage Reply with quote
I finally went to the year-around exclusive use of 100W, after using
15/50W for a couple of winters. Now in the winter I heat my engine
with a 200 watt heater, so the use of the multi-grade is not
required....unless I find myself staying overnight in a hangar-less
area.
I'm surprised that you can rotate the carb that much with the
distributors in the way. I think I've finally got my EGT's where they
are happy...less than 100F apart, and the highest about 1370-1390F at
cruise (95-100 airspeed).
I just changed my oil, and this time I'm going to keep real good
records about when and how much I add between changes. I've written
it down before, but it happens so seldom that I lose the piece of
paper it is written on between oil additions...my bad.
Lynn Matteson
Jabiru 2200, #2062, 695.8 hrs
Status: flying
On Jul 6, 2009, at 8:56 PM, zeprep251(at)aol.com wrote:
[quote] Lynn,
the egt's.
Thanks G.Aman
Lynn
N369LM
