isolation circuit
jamesneely
PostPosted: Tue Mar 24, 2009 11:17 am    Post subject: isolation circuit Reply with quote
I have a flightline fl-760 and the manual says that both mikes go hot on transmit. That doesn't seem a like a great idea, particularly in a noisy cockpit. They mention an optional isolation relay board, but apparently they never did produce it, so I have to make up my own.
The problem is that while I can solder just fine, I suck at designing circuits. Has anyone made one of these boards, or has a schematic that I can work from? or any source for buying such beast?
thanx,
James
PostPosted: Wed Mar 25, 2009 10:57 am    Post subject: isolation circuit Reply with quote
make up my own.
Are you using the hot-mic intercom feature . . . or
is it just a comm transceiver?
( -Thomas Paine 1776- )
jamesneely
PostPosted: Wed Mar 25, 2009 11:47 am    Post subject: Re: isolation circuit Reply with quote
I'm using the vox feature. works great on the bench. I'm not sure you can turn that feature off in this radio.
Would it work if I just put a relay in to disconnect the copilot mike on transmit..breaks the connection from the copilot mike to pin #3? And at the same time grounds pin #7 (the transmit PTT)?
There will only be one PTT[/list]
 Filesize:  258.65 KB
 Viewed:  14721 Time(s)
jamesneely
PostPosted: Wed Mar 25, 2009 11:57 am    Post subject: isolation circuit Reply with quote
I'm using the vox intercom feature.  That part seems to work great, so I'd like to use it.
James
2009/3/25 Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
--> AeroElectric-List message posted by: "jamesneely" <neelyjame(at)gmail.com (neelyjame(at)gmail.com)>
ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
PostPosted: Wed Mar 25, 2009 5:17 pm    Post subject: isolation circuit Reply with quote
That would work. Check out
this relay:
http://www.radioshack.com/product/index.jsp?productId 62483
jamesneely
PostPosted: Wed Mar 25, 2009 6:57 pm    Post subject: Re: isolation circuit Reply with quote
Thanks Bob, but I'm not having any luck with that product ID. Which relay is it? There's a dpdt miniature part #275-249
James
PostPosted: Wed Mar 25, 2009 11:28 pm    Post subject: isolation circuit Reply with quote
James
Hmmmm . . . I guess I don't know where you are located.
That website link was to a Radio Shack part. The relay
is a sealed, low power 12v, dpdt device. Do you have
access to a Radio Shack store?
The part suggested is a Tyco part. Here's the data
sheet:
http://relays.tycoelectronics.com/datasheets/OMI-2P.pdf
If you don't have access to Radio Shack then any
other small signal relay will do (2A or
less contacts).
jamesneely
PostPosted: Thu Mar 26, 2009 3:16 am    Post subject: Re: isolation circuit Reply with quote
When I tried the link it didn't get me to that part, but it looks like that's the one I found one their site. Given the info on the data sheet, I think my problem is solved. Thanks to you, and all the others that chimed in.
We have "the Source" here in the frozen north, a subsidiary of Radio Shack. I'll have no trouble getting what I need.
Thanx again,
James
