jamesneely
Posted: Tue Mar 24, 2009 11:17 am Post subject: isolation circuit |
I have a flightline fl-760 and the manual says that both mikes go hot on transmit. That doesn't seem a like a great idea, particularly in a noisy cockpit. They mention an optional isolation relay board, but apparently they never did produce it, so I have to make up my own.
The problem is that while I can solder just fine, I suck at designing circuits. Has anyone made one of these boards, or has a schematic that I can work from? or any source for buying such beast?
thanx,
James
Posted: Wed Mar 25, 2009 10:57 am Post subject: isolation circuit |
At 02:17 PM 3/24/2009, you wrote:
make up my own.
Are you using the hot-mic intercom feature . . . or
is it just a comm transceiver?
( -Thomas Paine 1776- )
jamesneely
Posted: Wed Mar 25, 2009 11:47 am Post subject: Re: isolation circuit |
I'm using the vox feature. works great on the bench. I'm not sure you can turn that feature off in this radio.
Would it work if I just put a relay in to disconnect the copilot mike on transmit..breaks the connection from the copilot mike to pin #3? And at the same time grounds pin #7 (the transmit PTT)?
There will only be one PTT[/list]
258.65 KB |
14722 Time(s) |
jamesneely
Posted: Wed Mar 25, 2009 11:57 am Post subject: isolation circuit |
I'm using the vox intercom feature. That part seems to work great, so I'd like to use it.
James
2009/3/25 Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
| Quote: | --> AeroElectric-List message posted by: "jamesneely" <neelyjame(at)gmail.com (neelyjame(at)gmail.com)>
ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
Posted: Wed Mar 25, 2009 5:17 pm Post subject: isolation circuit |
At 02:47 PM 3/25/2009, you wrote:
That would work. Check out
this relay:
http://www.radioshack.com/product/index.jsp?productId 62483
jamesneely
Posted: Wed Mar 25, 2009 6:57 pm Post subject: Re: isolation circuit |
Thanks Bob, but I'm not having any luck with that product ID. Which relay is it? There's a dpdt miniature part #275-249
James
Posted: Wed Mar 25, 2009 11:28 pm Post subject: isolation circuit |
At 09:57 PM 3/25/2009, you wrote:
James
Hmmmm . . . I guess I don't know where you are located.
That website link was to a Radio Shack part. The relay
is a sealed, low power 12v, dpdt device. Do you have
access to a Radio Shack store?
The part suggested is a Tyco part. Here's the data
sheet:
http://relays.tycoelectronics.com/datasheets/OMI-2P.pdf
If you don't have access to Radio Shack then any
other small signal relay will do (2A or
less contacts).
jamesneely
Posted: Thu Mar 26, 2009 3:16 am Post subject: Re: isolation circuit |
When I tried the link it didn't get me to that part, but it looks like that's the one I found one their site. Given the info on the data sheet, I think my problem is solved. Thanks to you, and all the others that chimed in.
We have "the Source" here in the frozen north, a subsidiary of Radio Shack. I'll have no trouble getting what I need.
Thanx again,
James
