Ski Size
patreilly43(at)hotmail.co
PostPosted: Mon Mar 02, 2009 2:42 pm    Post subject: Ski Size Reply with quote
Lynn Matteson, Looking at snowboards to convert to skis. What length and sq ' or " footprint do I need?
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Lynn Matteson
PostPosted: Mon Mar 02, 2009 5:21 pm    Post subject: Ski Size Reply with quote
Hi Pat-
Mine are about 600 sq inches each. I measured a Cub that turned out
to be 768 sq in for the pair, and another pair for a
Cub...Federals...that measured 1008 sq in for the pair. So mine are a
bit oversize, but work very well in 12-14" of snow. Narrow skis seem
to work better in hard snow, and wider are better for lighter snow,
it seems.
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
Status: flying
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
contribution_-
Lynn
Kitfox IV-Jabiru 2200
N369LM
CDNCH701
PostPosted: Mon Mar 02, 2009 6:39 pm    Post subject: Ski Size Reply with quote
Hey Lynn and Pat this link is from a 701 builder with some home built skis
on Yahoo, and here are a couple of messages... this is what he had to say:
"hi all took some time but the new skis are installed and tested
perfectly this past weekend. performed very well on the snow which b/c
of the recent thaw surface was very dense and hard. i can pull the
plane with one finger on prop on top of this stuff. because of the
cant in the main gear the outer edge of the ski is lower then i would
like but still performed very well on the grass.all skis are 15" wide
mains are 48" long and nw is 36" top speed was down about 5mph and is
noticable less responsive to full throttle up. A mushy 4ooo rpm to
5200 in flight, the engine responds like normal but the asi is a
little slower to catch up. climbout was still impressive as ever.
total weight of all hardware is 60 lbs. so not so good for passenger
carrying but at least spent 2hours sipping around doing t & g's with
the bunch of hanger buddies only able to watch from the snowbanks.
will post some pics soon but will look like carbon copies of the ones
listed at zenith."
"just uploaded some photos. mains are 14 x 48 x 1/8 alum sheet with a
3.5" incline. 2- 1 x 2" rails on 12" centers stitch welded with a 15 "
wide sheet of 1/8 uhmw popriveted to bottoms. an bolts for mounting
hardware and clips. rest of the cable, bungii and hardware is local
building material. the nw pivot is a shouldered bushing machined to
size witha 5/16 x 2 an bolt and locknut. the "s" brace is a just in
case support. I can remove the ski without touching the nw axle. tail
wheels are hockey pucks board and oilite bushings pressed into."
http://groups.yahoo.com/group/701builders/photos/album/995817052/pic/list
Let me know if you can access this link, there are some pics there of the
skis...
R.D.(Ron) Leclerc
CH701 Plans(Scrap) Builder #7-6699
Porsche Power Geared Redrive
Winnipeg, MB Canada
infow(at)mts.net
3/2/2009 7:56:49 PM
Sad
Sad
Sad
Sad Hi Pat-
Sad Mine are about 600 sq inches each. I measured a Cub that turned
Sad out to be 768 sq in for the pair, and another pair for a
Sad Cub...Federals...that measured 1008 sq in for the pair. So mine
Sad are a bit oversize, but work very well in 12-14" of snow. Narrow
Sad skis seem to work better in hard snow, and wider are better for
Sad lighter snow, it seems.
Sad
Sad Lynn Matteson
Sad Kitfox IV Speedster, taildragger
Sad Jabiru 2200, #2062, 605 hrs
Sad Sensenich 62x46
Sad Electroair direct-fire ignition system
Sad Status: flying
Sad
Sad
Sad On Mar 2, 2009, at 5:41 PM, Pat Reilly wrote:
Sad
SadSad Lynn Matteson, Looking at snowboards to convert to skis. What
SadSad length and sq ' or " footprint do I need?
SadSad
SadSad Pat Reilly
SadSad Mod 3 582 Rebuild
SadSad Rockford,IL
SadSad ============================================================
SadSad _-
SadSad _- contribution_-
SadSad
Sad
Sad = - The Kitfox-List Email Forum -
Sad = - MATRONICS WEB FORUMS -
Sad your generous support!
Sad ->
nail13zg(at)centurytel.ne
PostPosted: Mon Mar 02, 2009 6:54 pm    Post subject: Ski Size Reply with quote
Ron,
How 'bout posting your pictures to the matronics/kitfox list
Trey Moran
PostPosted: Mon Mar 02, 2009 7:04 pm    Post subject: Ski Size Reply with quote
Ron C I couldn't open the photos.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Mon C 2 Mar 2009 20:38:26 -0600
Subject: Re: Ski Size
--> Kitfox-List message posted by: "R.D.(Ron) Leclerc" <infow(at)mts.net>
on Yahoo C and here are a couple of messages... this is what he had to say:
5200 in flight C the engine responds like normal but the asi is a
listed at zenith."
hardware and clips. rest of the cable C bungii and hardware is local
Let me know if you can access this link C there are some pics there of the
skis...
R.D.(Ron) Leclerc
Winnipeg C MB Canada
infow(at)mts.net
3/2/2009 7:56:49 PM
Sad --> Kitfox-List message posted by: Lynn Matteson
Sad
Sad
Sad Hi Pat-
Sad out to be 768 sq in for the pair C and another pair for a
Sad are a bit oversize C but work very well in 12-14" of snow. Narrow
Sad skis seem to work better in hard snow C and wider are better for
Sad lighter snow C it seems.
Sad
Sad Lynn Matteson
Sad Kitfox IV Speedster C taildragger
Sad Jabiru 2200 C #2062 C 605 hrs
Sad Sensenich 62x46
Sad Status: flying
Sad
Sad
Sad On Mar 2 C 2009 C at 5:41 PM C Pat Reilly wrote:
Sad
SadSad Lynn Matteson C Looking at snowboards to convert to skis. What
SadSad
SadSad Pat Reilly
SadSad Rockford CIL
SadSad _-
SadSad ==========
SadSad
Sad
Sad ->
http://ww Archive Search & Download C 7-Day Browse C Chat C FAQ C
&gt===
CDNCH701
PostPosted: Mon Mar 02, 2009 7:24 pm    Post subject: Ski Size Reply with quote
Let me know if this works...
Ron
Sad Ron, I couldn't open the photos.
Sad do not archive
Sad
Sad Pat Reilly
Sad Rockford, IL
Sad
Sad
SadSad From: infow(at)mts.net
SadSad To: kitfox-list(at)matronics.com
SadSad Date: Mon, 2 Mar 2009 20:38:26 -0600
SadSad Subject: Re: Ski Size
SadSad
SadSad --> Kitfox-List message posted by: "R.D.(Ron) Leclerc"
SadSad
SadSad
SadSad Hey Lynn and Pat this link is from a 701 builder with some
SadSad home built skis on Yahoo, and here are a couple of
SadSad messages... this is what he had to say:
SadSad
SadSad "hi all took some time but the new skis are installed and
SadSad tested perfectly this past weekend. performed very well on
SadSad the snow which b/c of the recent thaw surface was very dense
SadSad and hard. i can pull the plane with one finger on prop on top
SadSad of this stuff. because of the cant in the main gear the outer
SadSad edge of the ski is lower then i would like but still
SadSad performed very well on the grass.all skis are 15" wide mains
SadSad are 48" long and nw is 36" top speed was down about 5mph and
SadSad is noticable less responsive to full throttle up. A mushy
SadSad 4ooo rpm to 5200 in flight, the engine responds like normal
SadSad but the asi is a little slower to catch up. climbout was
SadSad still impressive as ever. total weight of all hardware is 60
SadSad lbs. so not so good for passenger carrying but at least spent
SadSad 2hours sipping around doing t & g's with the bunch of hanger
SadSad buddies only able to watch from the snowbanks. will post some
SadSad pics soon but will look like carbon copies of the ones listed
SadSad at zenith."
SadSad
SadSad "just uploaded some photos. mains are 14 x 48 x 1/8 alum
SadSad sheet with a 3.5" incline. 2- 1 x 2" rails on 12" centers
SadSad stitch welded with a 15 " wide sheet of 1/8 uhmw popriveted
SadSad to bottoms. an bolts for mounting hardware and clips. rest of
SadSad the cable, bungii and hardware is local building material.
SadSad the nw pivot is a shouldered bushing machined to size witha
SadSad 5/16 x 2 an bolt and locknut. the "s" brace is a just in case
SadSad support. I can remove the ski without touching the nw axle.
SadSad tail wheels are hockey pucks board and oilite bushings
SadSad pressed into."
SadSad http://groups.yahoo.com/group/701builders/photos/album/995817052/pic/l
SadSad ist
SadSad
SadSad
SadSad Let me know if you can access this link, there are some pics
SadSad there of the skis... R.D.(Ron) Leclerc CH701 Plans(Scrap)
SadSad Builder #7-6699 Porsche Power Geared Redrive Winnipeg, MB
SadSad Canada infow(at)mts.net 3/2/2009 7:56:49 PM
SadSad
SadSad
SadSad --> Kitfox-List message posted by: Lynn Matteson
SadSad
SadSad
SadSad Hi Pat-
SadSad Mine are about 600 sq inches each. I measured a Cub that
SadSad turned out to be 768 sq in for the pair, and another pair for
SadSad a Cub...Federals...that measured 1008 sq in for the pair. So
SadSad mine are a bit oversize, but work very well in 12-14" of
SadSad snow. Narrow skis seem to work better in hard snow, and wider
SadSad are better for lighter snow, it seems.
SadSad
SadSad Kitfox IV Speedster, taildragger
SadSad Jabiru 2200, #2062, 605 hrs
SadSad Sensenich 62x46
SadSad Electroair direct-fire ignition system
SadSad Status: flying
SadSad
SadSad
SadSad On Mar 2, 2009, at 5:41 PM, Pat Reilly wrote:
SadSad
SadSad
SadSad Pat Reilly
SadSad Rockford,IL
SadSad _-
SadSad ==========
contribution_-
SadSad
SadSad
SadSad = - The Kitfox-List Email Forum -
SadSad http://www.matronics.com/Navigator?Kitfox-List
SadSad = - MATRONICS WEB FORUMS -
SadSad your generous support!
SadSad ->
SadSad http://ww Archive Search & Download, 7-Day Browse, Chat, FAQ,
SadSad ===
SadSad
SadSad
Sad _-
Sad = - The Kitfox-List Email:-( Features Navigator to Archive Search & Download, 7-Day
Sad > http://www.matronics.:-( -
Sad  MATRONICS WEB FORUMS -->
Sad -
Sad  List Contribution:-( http://www.matronics.com/contribution _-
 Filesize:  72.79 KB
 Viewed:  14063 Time(s)
 Filesize:  29.67 KB
 Filesize:  38.1 KB
Lynn Matteson
PostPosted: Tue Mar 03, 2009 5:47 am    Post subject: Ski Size Reply with quote
The photos and text came through loud and clear, Ron, and thanks.
His skis are similar to my old ones, in that they let the tire
penetrate (in my opinion) too far, and he has the "cheese slicer"
effect going for (against) him. I can't imagine this arrangement
weighing 60 lbs, either, but it DOES include a nosewheel ski, which I
don't have the equivalent of for my tailwheel....haven't found the
need for it yet.
No need for skis around here...Lower Michigan....as the ground is
clear of snow, but it's 3 degrees F. above zero, clear as a bell and
wind-less, and I'm gonna go fly some lakes!
Lynn Matteson
Sensenich 62x46
Status: flying
Ron
<kau03y1ven8r4w7ebnlt>
<76a4ovan2d8qbizff2h3>
<38fieofllxwituveings>
Sad do not archive
Lynn
N369LM
PostPosted: Tue Mar 03, 2009 7:02 am    Post subject: Ski Size Reply with quote
Ron C Yes C photos are great. It looks like you put carpeet on the tops of the skis. There is a diamond pattern on thetop of the ski. What is that?
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Mon C 2 Mar 2009 21:23:37 -0600
Subject: RE: Ski Size
.ExternalClass {font-family:'Tahoma';font-size:10pt;font-color:'#000000';} .ExternalClass LI {display:list-item;} .ExternalClass p {display:block;} .ExternalClass {;} Let me know if this works...
Ron
[img]cid:kau03y1ven8r4w7ebnlt(at)poco[/img]
[img]cid:76a4ovan2d8qbizff2h3(at)poco[/img]
[img]cid:38fieofllxwituveings(at)poco[/img]
Sad Ron C I couldn't open the photos.
Sad do not archive
Sad
Sad Pat Reilly
Sad Rockford C IL
Sad
Sad
SadSad Date: Mon C 2 Mar 2009 20:38:26 -0600
SadSad Subject: Re: Kitfox-List: Ski Size
SadSad
SadSad
SadSad
SadSad home built skis on Yahoo C and here are a couple of
SadSad
SadSad 4ooo rpm to 5200 in flight C the engine responds like normal
SadSad at zenith."
SadSad
SadSad the cable C bungii and hardware is local building material.
SadSad ist
SadSad
SadSad
SadSad Let me know if you can access this link C there are some pics
SadSad Builder #7-6699 Porsche Power Geared Redrive Winnipeg C MB
SadSad
SadSad
SadSad
SadSad
SadSad Hi Pat-
SadSad turned out to be 768 sq in for the pair C and another pair for
SadSad mine are a bit oversize C but work very well in 12-14" of
SadSad snow. Narrow skis seem to work better in hard snow C and wider
SadSad are better for lighter snow C it seems.
SadSad
SadSad Kitfox IV Speedster C taildragger
SadSad Jabiru 2200 C #2062 C 605 hrs
SadSad
SadSad
SadSad On Mar 2 C 2009 C at 5:41 PM C Pat Reilly wrote:
SadSad
SadSad
SadSad Pat Reilly
SadSad Rockford CIL
SadSad ==========
SadSad _-
SadSad ==========
contribution_-
SadSad ==========
SadSad
SadSad
SadSad ->
SadSad http://ww Archive Search & Download C 7-Day Browse C Chat C FAQ C
SadSad ===
SadSad
SadSad
Sad _-
Sad = - The Kitfox-List Email Sad Features Navigator to Archive Search & Download C 7-Day
Sad > http://www.matronics. Sad -
Sad -
Sad  List Contribution Sad
Sad ==========
 Filesize:  72.79 KB
 Viewed:  14048 Time(s)
 Filesize:  29.67 KB
 Filesize:  38.1 KB
akflyer
PostPosted: Tue Mar 03, 2009 9:58 am    Post subject: Re: Ski Size Reply with quote
[quote="patreilly43(at)hotmail.co"]Lynn Matteson, Looking at snowboards to convert to skis. What length and sq ' or " footprint do I need?
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
ohh caa caa... here we go again lol... What are the average snow depths? mine have 780 sq. in. and I would not want any less for the snow I fly off of most of the time. I had them in knee deep powder and they performed great. Only sunk in about 4 inches or so. Now to make a tail ski and I will be golden.
Snakeman
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Float Flyr
PostPosted: Tue Mar 03, 2009 1:10 pm    Post subject: Ski Size Reply with quote
Lynn:
We had 11C ~ 51F temps here today. Ceiling was minimal with several rain
showers. We lost over a foot of snow today but more to go yet.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Lynn Matteson
PostPosted: Tue Mar 03, 2009 2:02 pm    Post subject: Ski Size Reply with quote
I don't think those are carpet.....they look like paver blocks to me,
Pat. Look closer and you'll see that where the diamond pattern is,
there is no ski attached to the hanging brackets. And these aren't
Ron's skis....he was just posting the link.
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 3, 2009, at 10:01 AM, patrick reilly wrote:
Ron, Yes, photos are great. It looks like you put carpeet on the
What is that?
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Date: Mon, 2 Mar 2009 21:23:37 -0600
Ron
Sad do not archive
Sad
Sad Pat Reilly
Sad Rockford, IL
Sad
Sad
SadSad
SadSad
SadSad
SadSad
SadSad
SadSad at zenith."
SadSad
995817052/pic/l
SadSad ist
SadSad
SadSad
SadSad
SadSad
SadSad
SadSad
SadSad
SadSad Hi Pat-
SadSad
SadSad
SadSad
SadSad
SadSad
SadSad Pat Reilly
SadSad Rockford,IL
SadSad ==========
SadSad _-
SadSad ==========
contribution_-
SadSad ==========
SadSad
SadSad
SadSad ->
SadSad ===
SadSad
SadSad
Sad _-
Sad Features Navigator to Archive Search & Download, 7-Day
Sad -
Sad -
Sad Sad ==========
Lynn
N369LM
PostPosted: Tue Mar 03, 2009 2:34 pm    Post subject: Ski Size Reply with quote
Len C We don't have knee deep powder. Never! As a matter of fact we don't have powder period. I'm shooting for 600 sq " per ski. But thanks for info.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Tue C 3 Mar 2009 09:58:48 -0800
--> Kitfox-List message posted by: "akflyer" <akflyer_2000(at)yahoo.com>
[quote="patreilly43(at)hotmail.co"]Lynn Matteson C Looking at snowboards to convert to skis. What length and sq ' or " footprint do I need?
Pat Reilly
Mod 3 582 Rebuild
Rockford CIL
> [b]
Snakeman
DO NOT ARCHIVE
Soldotna AK
Avid &quot;C&quot; / Mk IV
582 IVO IFA
Full Lotus 1260
hander outer of humorless darwin awards
http://forums.matronics.com/viewtopic.php?p=232974#232974
&g============
PostPosted: Tue Mar 03, 2009 3:02 pm    Post subject: Ski Size Reply with quote
Lynn C Jeeez... I must be going blind. The ski isn't in the picture C just the mounting bracket.That is a patio block. Come to think of it I just had trouble passing the eye test on my medical exam. Hell C I usually can't take it and close my eyes when I get close to the ground anyway.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
[quote] From: lynnmatt(at)jps.net
Date: Tue C 3 Mar 2009 17:00:32 -0500
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
I don't think those are carpet.....they look like paver blocks to me C
Pat. Look closer and you'll see that where the diamond pattern is C
Lynn Matteson
Sensenich 62x46
Status: flying
> What is that?
> do not archive
> Pat Reilly
> Mod 3 582 Rebuild
> Rockford C IL
> Ron
> Sad do not archive
> Sad
> Sad Pat Reilly
> Sad Rockford C IL
> Sad
> Sad
> SadSad
> SadSad
> SadSad
> SadSad
> SadSad at zenith."
> SadSad
> 995817052/pic/l
> SadSad ist
> SadSad
> SadSad
> SadSad
> SadSad
> SadSad
> SadSad
> SadSad Hi Pat-
> SadSad
> SadSad
> SadSad
> SadSad
> SadSad
> SadSad Pat Reilly
> SadSad Rockford CIL
> SadSad ==========
> SadSad _-
> SadSad ==========
> contribution_-
> SadSad ==========
> SadSad
> SadSad
> SadSad ->
> SadSad ===
> SadSad
> SadSad
> Sad _-
> Sad -
> Sad -
> Sad Sad ==========
_==========
Lynn Matteson
PostPosted: Tue Mar 03, 2009 3:46 pm    Post subject: Ski Size Reply with quote
When I was digging into ski sizes, it *seemed* that all the skis that
I measured were built under the assumption of about 1-2 pounds of
airplane weight per square inch of ski. That's a wild --- guess, but
again, deep powdery snow requires more flotation/area, and hard-
packed snow needs less area, at least from what I've been able to
gather.
Lynn Matteson
Jabiru 2200, #2062, 610 hrs
Sensenich 62x46
Status: flying
On Mar 3, 2009, at 5:33 PM, patrick reilly wrote:
Len, We don't have knee deep powder. Never! As a matter of fact we
thanks for info.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Lynn
N369LM
PostPosted: Wed Mar 04, 2009 6:42 am    Post subject: Ski Size Reply with quote
Lynn C Don't know if you are a skier C but that applies to downhill skiing also. Powder skies are much wider than carving skies.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Subject: Re: Kitfox-List: Re: Ski Size
Date: Tue C 3 Mar 2009 18:45:33 -0500
When I was digging into ski sizes C it *seemed* that all the skis that
airplane weight per square inch of ski. That's a wild --- guess C but
again C deep powdery snow requires more flotation/area C and hard-
packed snow needs less area C at least from what I've been able to
gather.
Lynn Matteson
Jabiru 2200 C #2062 C 610 hrs
Sensenich 62x46
Status: flying
> thanks for info.
> Pat Reilly
> Mod 3 582 Rebuil= Archive Search & Download C 7-Day Browse C Chat C FAQ C
&g====
Lynn Matteson
PostPosted: Wed Mar 04, 2009 11:42 am    Post subject: Ski Size Reply with quote
I haven't skied in 20 years, and haven't kept up with that sport, but
what you say sounds right.
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 4, 2009, at 9:40 AM, patrick reilly wrote:
Lynn, Don't know if you are a skier, but that applies to downhill
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
> Subject: Re: Re: Ski Size
> Date: Tue, 3 Mar 2009 18:45:33 -0500
that
> gather.
> Lynn Matteson
> Sensenich 62x46
> Status: flying
> > thanks for info.
> > Pat Reilly
> > Mod 3 582 Rebuil= Archive Search & Download, 7-Day Browse,
Chat, FAQ,
&g====
contribution_-
Lynn
N369LM
dashwood
PostPosted: Wed Mar 04, 2009 7:13 pm    Post subject: Re: Ski Size Reply with quote
hello lynn: its odd that you guys are talking about my skis. i got some of my inspiration from looking at the picture posts of yours. The originals idea came from robert nelson in the zenair .com posts of skis. http://www.zenithair.com/stolch701/7-photo81.html library #81...His are of the blue 701 at the top and about 2/3 down the list. I emailed him for info and he supplied me with some spec and more pics. .some others on the site show a guy standing on his skies so i got some relative sizes from that. I was just winging it as to the sizes. I just now did some calculations and came up with just under 2lb /sq in at full load. The pictures are just after traversing a 6' deep snowdrift. The plane sank about 8" but was able to hold the nw higher with rpm and backstick. I walked back through the same drift and sank past my knees. My size 12'vs couldnt hold up the 200lb hulk.there is a fair amout to cheese slicing and the wheels protrude about 2". the home field is grass with many short hops to pavement so i wanted both.
yes the other pic is of the nw ski under construction detailing the machined pivot separate from the nw axle....including pavers in the hanger
ruebd(at)skymail.csus.edu
PostPosted: Thu Mar 05, 2009 8:30 am    Post subject: Ski Size Reply with quote
Everyone knows size matters!
