barryhancock
Posted: Sun Jan 25, 2009 8:07 am Post subject: Smoke |
I have a Blackwell system in my CJ. It is a custom system with 7 gallon
capacity and works well. I like it. However, it is expensive (about
$2500 installed when I did it in 2005). Along comes Smoking Airplanes.
After talking with Blitz Fox I decided to install one of their systems in
the Yak-50 as I needed a system quick for an upcoming airshow. It is
relatively in expensive ($1500 installed), high quality, EVERYTHING you
need is provided, good installation instructions, John the owner is a
great guy and will help any way he can, and the whole system can be
installed in a day. I now put them in all our customers airplanes. I do
not get anything out of this endorsement other than knowing that I'm
recommending what I feel to be the best bang for the buck out there. If
you want higher capacity and a schmancy system, Blackwell's is the way to
go in a CJ. More dense smoke you will not find.
As for the nozzle placement, obviously many have experimented with
placement. I second Richard's placement of highest in the last
stack...near cyls 3/4 and/or 6/7. This way you avoid residue out the
joints and pressure build up inside the exhaust.
According to Blackwell, pressure seems to be an important issue in getting
good, dense smoke. Higher pressure yields a greater atomization of the
oil and a more complete burn. Again, Blackwell's system consistently
produces the densest smoke I've seen and he's now using a 90 psi pump, I
believe.
I've attached a few pics. The first one is my CJ with Blackwell's system
(dual injectors) and the other one is a formation shot. The Yak-50 (still
for sale) is in the middle. Blackwell system on the right, and another
system on the left.
Happy Smokin'!
Barry Hancock
Worldwide Warbirds, Inc.
office (909) 606-4444
cell (949) 300-5510
www.worldwidewarbirds.com
41.81 KB |
461 Time(s) |
1.82 MB |
485 Time(s) |
_________________ Barry Hancock
www.worldwidewarbirds.com |
kurt(at)scitechsys.com Guest
Posted: Sun Jan 25, 2009 12:43 pm Post subject: Smoke |
I just had a Smoking Airplanes system installed. Works great!
The only issue we have right now is smoke getting into the cockpit.
We've sealed up the holes in the wheel wells with little effect. Most of
the smoke seems to enter the rear pit. What other problem areas we
should look at?
Kurt Howerton
N923YK
http://cj6.scitechsys.com
Barry Hancock wrote:
| Quote: | I have a Blackwell system in my CJ. It is a custom system with 7 gallon
believe.
system on the left.
Happy Smokin'!
ByronMFox(at)aol.com Guest
Posted: Sun Jan 25, 2009 1:26 pm Post subject: Smoke |
Come on, Kurt. Be a man. Suck it up quite literally:) Sad to say our CJs leak air like a sieve. Negative pressure inside the cockpit. Most of it is probably coming in around the bottom of the aft canopy. ...Blitz
In a message dated 1/25/2009 12:44:55 P.M. Pacific Standard Time, kurt(at)scitechsys.com writes:
| Quote: | The only issue we have right now is smoke getting into the cockpit.
should look at? |
A Good Credit 15855013x1201028747/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=DecemailfooterNO62"> See yours in just 2 easy steps!
barryhancock
Posted: Sun Jan 25, 2009 4:36 pm Post subject: Re: Smoke |
Doug Sapp posted a nice piece on this recently. Craig Payne has done extensive work in this area. The *easiest* fixes are extensions on the exhaust and louvered panels. It's definitely a problem that should not be ignored.
Speaking of which, we have recently developed a SS slip joint system including said extensions working with Aircraft Exhaust Systems, as well as a dual heat muff system for the M14P....pretty slick. Dual heat muffs allow independent operation and distribution of heat in the individual cockpits.
Posted: Sun Jan 25, 2009 4:48 pm Post subject: Smoke |
I guess I'll have to get used to my gib going: "cough, cough, cough,
cough, cough, cough, cough"
:0)
K
ByronMFox(at)aol.com wrote:
| Quote: | Come on, Kurt. Be a man. Suck it up quite literally:) Sad to say our
Most of
should look at?
yakplt(at)yahoo.com Guest
Posted: Sun Jan 25, 2009 4:52 pm Post subject: Smoke |
Remember... if you are choking on smoke, you are also sucking in carbon-monoxide all the time just as well. Doc Kemp has a ton to say regarding this, and it is worth listening to. Carbon-monoxide poisoning is insidious and can really do a number on judgment and reaction time.
Mark Bitterlich
N50YK
From: "ByronMFox(at)aol.com" <ByronMFox(at)aol.com>
To: yak-list(at)matronics.com
Sent: Sunday, January 25, 2009 4:21:17 PM
Subject: Re: Smoke
should look at? |
barryhancock
Posted: Sun Jan 25, 2009 4:59 pm Post subject: Re: Smoke |
Actually, louvered panels are easy and inexpensive. And it's not only your GIB, but you as well. And like Mark says...all the smoke is doing is coloring what is there ALL THE TIME!
B
alikatz(at)mbay.net Guest
Posted: Sun Jan 25, 2009 5:38 pm Post subject: Smoke |
Kurt,
When it gets silent from your GIB in the back, that's when you worry!!!!
coughings good... ; )))
byronmfox(at)aol.com Guest
Posted: Mon Jan 26, 2009 12:22 pm Post subject: Smoke |
On Jan 25, 2009, at 4:36:23 PM, barryhancock <bhancock(at)worldwidewarbirds.com> wrote:
| Quote: | | Speaking of which, we have recently developed a SS slip joint system including said extensions working with Aircraft Exhaust Systems, as well as a dual heat muff system for the M14P....pretty slick. Dual heat muffs allow independent operation and distribution of heat in the individual cockpits. | Doubtless, the elegant modifications available from Worldwide Warbirds will soon include a rear cockpit mounted cappuccino machine not unlike the ones in Craig Ekberg's and Ron Lee's CJs. ...Blitz
barryhancock
Posted: Mon Jan 26, 2009 12:51 pm Post subject: Re: Smoke |
Hmmmm.....
