RV9- Light Sport
pdn8r(at)yahoo.com
PostPosted: Sat Jan 24, 2009 3:38 pm    Post subject: RV9- Light Sport Reply with quote
Saw an RV-9A being promoted as a Light Sport at the Sebring Light Sport Expo. The plane had a Lyc. 0-235. The numbers don't seem to add up to qualifying as an LSA. Anybody seen this? Doesn't seem to leave much room for payload.
Bill Pagan EAA Tech Counselor #4395
601XL QBK/Corvair/N565BW (RES)
 Filesize:  1.21 MB
 Viewed:  1038 Time(s)
BobCollins
PostPosted: Sat Jan 24, 2009 4:52 pm    Post subject: RV9- Light Sport Reply with quote
Bill,
I believe that Van is promoting his new RV-12 as an LSA. Certainly not
the RV-9.
Bob Collins
Sunnyvale CA USA
Bill Pagan
mcjon77
PostPosted: Sat Jan 24, 2009 4:57 pm    Post subject: Re: RV9- Light Sport Reply with quote
Yep,
There was a bit of controversy about this bird on the vansairforce.com forum. The planes stated empty weight is 903lbs, so that gives him a 417 lb useful load. He had to over-pitch the prop to keep the speed low. No wheel pants or fairings either.
With 2 FAA sized folks you can carry a little less than 13 gal of fuel for an engine that burns about 6+ gal an hour You get all of the RV costs, but none of the performance. Personally, I think he crippled a beautiful bird. Why anyone would do this is beyond me, but hey it is experimental aviation. Very Happy
Jon
P.S. I would really like to see what that plane weighs when measured with some aircraft scales Shocked
psm(at)ATT.NET
PostPosted: Sat Jan 24, 2009 5:42 pm    Post subject: RV9- Light Sport Reply with quote
Hi Bill,
I just did a quick review of the RV-9A on Van's web site. It doesn't
even seem close to an LSA.
Gross weight is around 1750,
Minimum engine 118 Hp gives 165 mph cruise (give or take)
empty weight over 1000 lbs
36 gallons of fuel.
Somebody is really stretching the point. Maybe they just were trying
to fit in at the LSA show.
Paul
XL getting close
Gig Giacona
PostPosted: Sat Jan 24, 2009 8:28 pm    Post subject: Re: RV9- Light Sport Reply with quote
The guy is really pushing the reg. If he ever is violated it will be an interesting test case.
W.R. "Gig" Giacona
601XL Under Construction
special4
PostPosted: Sun Jan 25, 2009 7:53 am    Post subject: Re: RV9- Light Sport Reply with quote
Hi Bill, Paul & Gig,
Check the website www.liteplane.com... This guy has a modified RV-9 ELSA.!
Peter
Zodiac 650
Sportsflyer
jaybannist(at)cs.com
PostPosted: Sun Jan 25, 2009 8:05 am    Post subject: RV9- Light Sport Reply with quote
Has Van's produced an LSA RV9A ? If not, there can NOT be an ELSA RV9A., website or not.
Jay Bannister
Gig Giacona
PostPosted: Sun Jan 25, 2009 9:55 am    Post subject: Re: RV9- Light Sport Reply with quote
Peter
Zodiac 650
That aircraft received its certificate 02/01/2008. Which I believe was right before the deadline for aircraft to be registered under as E-LSA without conforming to a factory built S-LSA plans.
This also allows him to train with it until some time in 2010. This guy is just begging to be violated.
W.R. "Gig" Giacona
bryanmmartin
PostPosted: Sun Jan 25, 2009 11:03 am    Post subject: RV9- Light Sport Reply with quote
If this particular RV-9 was registered under the "fat ultralight"
clause before the deadline, it very well could be an E-LSA.
Jay Bannister
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
pdn8r(at)yahoo.com
PostPosted: Sun Jan 25, 2009 2:51 pm    Post subject: RV9- Light Sport Reply with quote
That's the one that was at the Light Sport Expo that I saw. Sign on it said you can have one built ofr $125,000.00.
I'd be glad to build one for you for $120,000.00. Let me know if you want the address to send the check Smile
--- On Sun, 1/25/09, special4 <sportsflyer(at)comcast.net> wrote:
Subject: Re: RV9- Light Sport
Date: Sunday, January 25, 2009, 10:53 AM
Juan Vega Jr
PostPosted: Sun Jan 25, 2009 5:39 pm    Post subject: RV9- Light Sport Reply with quote
Gig, The guy in question is a DAR for the FAA and has been CFI for years. Its all legit.
Juan
Juan Vega Jr
PostPosted: Sun Jan 25, 2009 5:40 pm    Post subject: RV9- Light Sport Reply with quote
Actually Jay you are incorrect. Jay Kurtz, registered an 9a as ELSA. Its fully registered as such and he is selling them from SOuth LAkeland, Florida. Very little usefull load though. definietly a one moan plane. It has a 900 + lb empty weight.
Juan
Gig Giacona
PostPosted: Mon Jan 26, 2009 6:14 am    Post subject: Re: RV9- Light Sport Reply with quote
Juan
Just be cause he is a DAR doesn't make it legit. And while the one of might be there is no way any of the ones he is selling now for $125K can be. After the grace period for the "fat ultralights" passed early last year the only way a plane can be E-LSA is for the company who has built the S-LSA version to produce and identical kit.
W.R. "Gig" Giacona
BobCollins
PostPosted: Mon Jan 26, 2009 8:18 am    Post subject: RV9- Light Sport Reply with quote
Hello,
I wonder if there is some confusion about the rules here. You are right,
the non-factory ELSA period is over so, without Vans offering an ELSA
version of a LSA design, you may not register a plane as an ELSA. Van
will probably do this for the RV-12.
However, anyone can build a plane which meets the LSA specs and register
it under amateur-built: experimental. I could believe that, with
sufficient dirtying and compromised useful load that if would be
possible to make an RV-9 meet the LSA specs and then fly it with a sport
pilot license. An important issue it that it would need to be registered
with the LSA characteristics (dirty, 1320 lbs max, etc) and would
therefore not be a particularly attractive plane for someone who wanted
a standard RV-9.
Bob Collins
Sunnyvale CA USA
Gig Giacona wrote:
> Juan
W.R. &quot;Gig&quot; Giacona
http://forums.matronics.com/viewtopic.php?p 26848#226848
Juan Vega Jr
PostPosted: Mon Jan 26, 2009 8:23 am    Post subject: RV9- Light Sport Reply with quote
sounds good. sounds lie you know the rules verboten. sounds like you want to build an rv-9 or really like them.
let me know how the build goes.
Juan
mcjon77
PostPosted: Mon Jan 26, 2009 5:58 pm    Post subject: Re: RV9- Light Sport Reply with quote
Here is what I do not quite understand:
If this guy is trying to sell the RV-9 ELSA that he has already built for $120K, then that is fine.
If he is offering builders assist for an ExAB RV-9, that is OK.
HOWEVER. If he is offering to build you a NEW ELSA or ExAB RV-9, I am almost positive that is a violation of the rules.
He cannot get an ELSA RV-9 registered since the "fat ultralight" deadline has passed and there is no SLSA version of the RV-9.
He Also cannot get an ExAB RV-9 registered if he builds it for someone, unless he is doing it for free, since it is not amateur built. He isn't building these aircraft for other owners SOLELY for his own education and recreation, is he?
Jon
