challgren(at)mac.com Guest
Posted: Tue Jan 13, 2009 10:04 pm Post subject: 3300A - Full Throttle Roughness |
Don:
I believe Jon's DVD "3300 Engine Installation" video may have the answer to your problem. This was shot by Jon at one of Pete's engine installation seminars.
Pete says on the video that at wide-open-throttle if you are getting too much fuel it would result in cooler EGT's and shaking. If your EGT's are closer to 1,000F than 1300F it is running cool due to the rich mixture. He says the solution is a smaller main jet. He says about two-thirds of the Jabiru engines have had to decrease their jet size. At another point he says they are shipped with 285's and you should ask for the next lower. bingcarb .com has a good book on the carb and it helped me with carb problems on our first 3300 on a 601. Pete also said that they would be carrying the smaller jets but you can also talk to the experts at Bing which I believe is in Kansas.
For information on the 3300 installation I think Jon's DVD is a must have. Five hours of excellent information.
Stan Challgren
701/3300
Evergreen, CO
On Jan 12, 2009, at 23:03 , Don Honabach wrote:
Quote: | I'm having an issue where during cruise flight if I go full throttle either in straight and level or climb, the engine gets rough enough that it feels like it will quit. At this point, I obviously don't want to push the issue so I pull back on the throttle until the roughness goes away.
Interestingly, I have no problem with full throttle roughness on take-off/climb-out.
I also did some additional testing today and found that if I ease real slow into full throttle from cruise that I still get the roughness but not as bad and that the RPM will increase up to ~2,9xx and then start to degrade as I continue to add power along with additional roughness.
Background info:
Full Throttle Static RPM/Ground Run Up is ~2,800RPM. No issues with roughness.
On my 601HDS, I have a 3300A with the Sensenich Carbon Prop (64"? 2A0J5R64Z-N) that was purchased from Jabiru USA/Pete K. back in 2006.
Any help greatly appreciated. I've sent this same question to Jabiru USA and haven't gotten a response yet (sent last Thursday and sent another today asking for status).
Initially thought it was the SCAT intake hose which I replaced with the rubber 90 degree elbow. Same issue with either intake method.
Thanks!
Don Honabach
Tempe, AZ
| - The Matronics JabiruEngine-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
Lynn Matteson
Posted: Wed Jan 14, 2009 5:47 am Post subject: 3300A - Full Throttle Roughness |
I'll have to report on the last inch of travel the next time I fly
it...I think I do get more power, but just how much I haven't paid
that much attention to.
I just bought a Northstar F210 fuel flow indicator, which is (I've
heard) similar to the Navman, but don't have it installed yet.
Regarding the seat removal...the first time I bought a seat,
directions came with it, but not the last two times. I used a slide-
hammer style device to pull the seat after first tapping the seat
body with a 5/16 24 tap...I think the directions called for an 8mm
tap, to which the 5/16-24 is close. I used the same slide hammer
device to install it, but substituted a close-fitting smooth mandrel
to drive it home.
Lynn Matteson
Jabiru 2200, #2062, 600.2 hrs
Sensenich 62x46
New skis done and flying
On Jan 13, 2009, at 11:37 PM, Peter Harris wrote:
<peterjfharris(at)bigpond.com>
Lynn I think your 3.7mm seat should be fine with gravity feed. I found
removal of the 2.25 seat and fitting the 1.5 seat made a very big
difference
to mixture at the higher throttle settings using the mech pump.
Remove and
refit was not easy, I made a screw puller and heated the carb to about
80degC. The seat is a tight interference fit.
I am continuing with the fuel injection twin injector throttle
body. At this
stage no additional power but total control of mixture. I think the
power
output is limited by restricted flow through the Jab induction
collector,
but had problems using a tapered plenum due to the effect near WOT
when most
of the charge is delivered to the end into #1 and 2. I may spend
some time
building a bottom feed plenum later.
I get very little increase in power over the last inch of throttle,
do you
also?
I am also using a Navman fuel flow indicator and find it one of the
most
useful instruments especially for cross country when you can adjust
throttle
to get the desired fuel flow rate and also read fuel remaining
accurate to
2%.
Peter
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Peter H
Posted: Wed Jan 14, 2009 2:17 pm Post subject: 3300A - Full Throttle Roughness |
Lynn my tests were done on the ground in static runs. You could try the
throttle movement test on the ground for comparison.
I think after many hours of ground runs the last test I did with the plenum
proves that resistance in the Jab collector is affecting performance, as
follows:
1. Breakdown at WOT is caused by an unrestricted rush of fuel to the
end of the plenum to #1 and 2. In use of the tapered plenum there is only
one way to stop spectacular engine breakdown at WOT and that is by fitting a
full width baffle 35mm wide and 30mm from the entry inside the plenum.
2. The baffle neutralizes the effect of the butterfly so that the last
1" of throttle has no effect. The baffle is acting like a partly closed
butterfly downstream. Without the baffle, throttle increases power up to the
point of breakdown ie there is no dead throttle.
3. Similarly the last 1" of throttle into the Jab. collector has no
effect but because of internal losses there is normally no breakdown at WOT,
only #1 and 2 go rich.
My tests were conducted on the ground static. I am using a 55 X 72" prop. on
the Quickie which climbs at 1500FPM and cruises at 170KTS at 2950RPM WOT.
You can appreciate why I am trying to make sure the engine is doing it's
best. The engine is still very tight when hot. It has done about 50hours.
Peter
Peter H
Posted: Wed Jan 14, 2009 2:23 pm Post subject: 3300A - Full Throttle Roughness |
Stan,
The problem I have with that approach is that the selection of jets and needles is being made to compensate for a leaking float valve needle seat.
The fuel needle seats are not all going to leak at the same rate.
It seems to me that this is a poor way to tune an engine. I think the carb should first be assembled to Bing specifications for the application with pump feed.
Then select jets and needles.
Peter
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Stanley Challgren
Sent: Wednesday, 14 January 2009 3:39 PM
To: jabiruengine-list(at)matronics.com
Subject: Re: JabiruEngine-List: 3300A - Full Throttle Roughness
Don:
Stan Challgren
701/3300
Evergreen, CO
Background info:
Thanks!
Don Honabach
Tempe, AZ
href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List
Lynn Matteson
Posted: Wed Jan 14, 2009 3:59 pm Post subject: 3300A - Full Throttle Roughness |
Peter-
Just to be sure I'm understanding your prop, I assume that you are
listing the diameter (55") first, and the pitch (72") second, as is
the normal way to describe a propellor, correct? (I've seen props
described the other way around, and their performance numbers didn't
add up) That seems like the only way that you could do 170 KTS at
2950 rpm...to me at least. That must be one very light aircraft to
climb that well and go that fast. You'll have to forgive me as I know
nothing about the Quickie. I would have thought that you'd have more
hours on your engine by now Peter....a lot of research and not much
flying, eh? : ) Maybe when you have more hours on the engine it will
loosen up and the effects of the last 1" of throttle travel will change?
I'm a bit confused by your description of the rush of fuel to the end
of the plenum to #1 and 2. It seems like the fuel must be being drawn
to those cylinders by vacuum from those cylinders. Do you suppose
this is because the fuel is not being atomized enough, and is
"clumping" together and cannot break apart to go to #3 and 4? This is
hard to visualize/imagine for me. I guess I do not understand your
description of the "tapered plenum" and how it works.
Lynn Matteson
Sensenich 62x46
the
the plenum
performance, as
follows:
is only
fitting a
closed
up to the
breakdown at WOT,
prop. on
2950RPM WOT.
it's
50hours.
Peter
N369LM |
Peter H
Posted: Wed Jan 14, 2009 8:17 pm Post subject: 3300A - Full Throttle Roughness |
Lynn
The prop is 55 dia X 72 pitch.
The 500KG gross Quickie is a fast 2 seat low drag Rutan canard design and
rated at 200MPH when powered by an 0-200. Performance is similar to a
Varieze but with a shorter take off roll. The J 3300 advertises an extra
20HP and I am looking for the extra air speed but not satisfied the engine
is performing to full potential.
Feeding from a Jenvey throttle body with two injectors at WOT I am getting
much the same problem as referred when the Bing is fully open. Rough running
and according to my plugs it is caused by a surge of fuel to #1 and 2 at the
end of the plenum. With the plenum the rough running is extreme and causes
breakdown. With the Jab collector the effect is masked by losses in the
collector. As referred before I can fix the problem with the use of a large
baffle but this restricts the effect of the throttle and there is a loss of
power. There appears to me to be a similar loss in the Jab collector.
Therefore I don't think it is a Bing problem but based on the tests I have
done with a tapered plenum I think the problem is due to the design of the
plenum (also the Jab collector) by attempting to feed from the end and with
outlets along each side. By contrast if we look at the 0-200 the feed is an
updraft central between the four outlets and with equal length headers this
makes for uniform distribution over the full power range.
Near WOT when the butterfly is near level the Bing (and the Jenvey) fuel/air
charge although atomized the fuel droplets have sufficient energy to travel
to the end of the system and over richen #1 and 2.
The reason to taper the plenum is to attempt to get a uniform pressure
gradient along the axis allowing for expansion of the charge at each pair of
outlets. Take a look at a Dyson vacuum cleaner. It works well for air and it
works well when bench tested using water in a pressure paint spray gun but
apparently not for the fuel/air charge at the higher velocity under WOT.
When the butterfly is deflected further to reduce throttle the turbulence is
increased and the charge is more evenly distributed. Using the plenum
without the internal baffle I found that the butterfly position is critical
and the breakdown is sudden and complete.
I also tried with fuel pressure increased to 60PSI for better atomization
but without success.
Hope that helps, I tried to attach a pic of the plenum which does not look
very pretty but is sexy on the inside.
Re engine hours you are right I have spent too long on the ground
experimenting.
Peter
Description: |
Filesize: |
594.97 KB |
Viewed: |
763 Time(s) |
jetboy
Posted: Wed Jan 14, 2009 9:01 pm Post subject: Re: 3300A - Full Throttle Roughness |
If this is any help I recall reading on the lists about the rubber coupling from carb to intake spider having a groove or step inside where fuel droplets cavitate and sit in a pool at times of operation. some have dealt to this by fitting an 'inner' sleeve tapered to make a smooth transition with no step.
Ralph
_________________ Ralph - CH701 / 2200a |
Lynn Matteson
Posted: Thu Jan 15, 2009 3:24 am Post subject: 3300A - Full Throttle Roughness |
Andy alerted us to this problem, and when I looked at mine last year,
I found that there was a cast-in ridge that effectively bridges that
gap between the carb and the plenum. Although not a smooth
transition, it does fill the gap and thus avoids the "groove or step"
you mentioned. My 2200 serial number is 2062, delivered in August
2005, just to put it in a time perspective.
Lynn Matteson
Sensenich 62x46
On Jan 15, 2009, at 12:01 AM, jetboy wrote:
Quote: |
<sanson.r(at)xtra.co.nz>
Ralph
http://forums.matronics.com/viewtopic.php?p 24860#224860
N369LM |
andy(at)suncoastjabiru.co Guest
Posted: Thu Jan 15, 2009 7:12 am Post subject: 3300A - Full Throttle Roughness |
Lynn,
Actually, the gap between the end of the carb. and the start of the intake
adapter can be a bit of an issue; the rubber coupler which bridges this gap,
which is necessary for vibration isolation, creates a definite groove
(annulus?) into which liquid fuel floods and then exits at any angle
depending on the influence of the airstream going through. One of our OEM
customers did extensive testing using a clear plastic transition and
reported that, at the point of exit from the carb, the fuel is still very
much in liquid form, and not the homogenous fuel/air vapour we might expect
from the theory. Of course, the mixture becomes more (er) mixed as it
travels up the intake tubes but Peter is absolutely right; there is little
opportunity for the fuel / air 'mix' to divide itself 50/50 by the vertical
splitter in the induction in the short distance it travels from the jet,
especially if the air going through the carb. is at all twisting. This extra
(though small) reservoir in the coupling-gap therefore adds to the
uncertainty of how the mixture splits left-and-right, often leading to an
imbalance of mixture at the cylinders. The same OEM fitted oxygen (lambda)
sensors on the 3300's combined exhaust headers (i.e. before the current
individual pipe setup), and found that there could be a ratio of 10:1 on one
side and as high as 16:1 on the other, where Jabiru's own reported 'ideal'
ratio is about 14:1. Interestingly, the lean and rich sides would swap over
as rpm increased, more-or-less proving the view that fuel distribution was
uneven before the splitter. I saw graphs of this a couple of years ago, and
the source of the analysis is impeccable. Now that we have comprehensive
engine monitoring and EGTs on all cylinders, it's easy to see these effects
through the rev. range as you fly. Even better are monitors like the GRT
Horizon/EFIS instrument which can graph EGT in real-time so you can see the
effects of mixture distribution at different power settings.
As I suggested in the post a while back, we found some success by inserting
a filler-ring made of rigid plastic (about the same consistency as the
coupler) which would fill said gap and provide a smoother bore. It wasn't a
complete fix, but definitely improved mixture distribution. Ideally, the
carb delivering into a plenum about 30% of the engine's cubic capacity
should give a better opportunity for fuel and air to mix, but space and
neatness of design precludes this. Jabiru's original plenum on the 2200 and
very few 3300s wasn't a success as the fuel in liquid state would tend to be
thrown to the front of the plenum and then run along the walls and up the
front two intake tubes, so the front cylinders were richer than the back.
Now, if the intake tubes protruded into the plenum by a few mm, the liquid
fuel wouldn't run up 'em, would it?
The experts at Jabiru were fed all this information at the time, but no
doubt had better reasons than me for keeping the design, and why not? It's
theirs!
Andy
Peter H
Posted: Thu Jan 15, 2009 3:02 pm Post subject: 3300A - Full Throttle Roughness |
Andy,
That is a very informative post.
I have been testing with a twin injector throttle body feeding an
unobstructed plenum, then for comparison feeding the Jab collector. My
fuel/air mix should be better, in fact I tried 60PSI for greater
atomization, but the charge entered the plenum and too much of the fuel
carried through to over richen #1 and 2 near WOT.
This is an issue independent of the splitter or the type of turbulence.
I think it is happening because near WOT a proportion of the fuel droplets
have enough energy to accelerate through the plenum (or the collector) until
they reach the end.
This is similar to the principle used by Dyson when dust is separated from
the air stream by using it's kinetic energy in a cyclone.
After endless tests I think the problem is due to the fact that we have an
end fed plenum (or collector).
I plan to reconfigure my plenum for bottom feed similar to the 0-200, but
headers will still be unequal and it will not be easy to target the charge
for uniform distribution between the 6 outlets.
Peter
jd(at)lawsonimaging.ca Guest
Posted: Thu Jan 15, 2009 4:47 pm Post subject: 3300A - Full Throttle Roughness |
Peter Harris wrote:
Quote: |
Andy,
they reach the end.
Peter
Just wondering... there seems to be a preponderance of posting on this
list that has to do with Bing carb
tuning/jetting/adjusting/modifying/etc. Has anyone considered an
alternative? AeroConversion's AeroCarb comes to mind :') I'm quite happy
with mine (Sonex/3300/AeroCarb), and I know that there are many other
Sonex/3300 drivers that are, also.
Regards, J.
J. Davis, M.Sc. (computer science)
*NIX consulting, SysAdmin
The day Microsoft makes a product that doesn't suck, is the day they
make a vacuum cleaner.
don(at)pcperfect.com Guest
Posted: Thu Jan 15, 2009 8:06 pm Post subject: 3300A - Full Throttle Roughness |
I'd love to hear any real world results of the AeroCarb on Zenith 601s.
I also personally would love a fuel ejected fully computerized control
setup for the 3300 as well!!!!!
Don
Peter H
Posted: Thu Jan 15, 2009 8:46 pm Post subject: 3300A - Full Throttle Roughness |
J
I would recommend against using Aerocarb especially on the J3300 based on
personal experience. I was supplied with an Aerocarb with no Teflon liner.
The slide worked on anodized metal to metal and jammed hard.
The slide is pulled and pushed by an outrigged lever which causes the slide
to twist and jam whenever pressure is applied. The attachment to cable is
off centre and not even co planar with the slide.
A Teflon liner is offered on the website but my several requests were
ignored.
I packed it with grease but it still jammed under the vacuum at low throttle
settings and any attempt to quickly open throttle for a missed approach
makes it jam harder because of the offset cable attachment.
I attempted to discuss changes to the design but was abused. I have a copy
of the correspondence.
When I asked for a refund I was told to sell it on eBay.
I would not have the conscience to give it away .
Peter
Lynn Matteson
Posted: Fri Jan 16, 2009 3:12 am Post subject: 3300A - Full Throttle Roughness |
But do you remember, Andy, when I reported back in about April of
last year that my rubber coupler had a built-up ridge that filled
this gap? I mentioned this and you said that the coupler supplier
must have made this change in the later models. Here is picture of
that ridge. It is the square-ish ridge between the two humps that fit
into the grooves of the carb and the intake adapter.
It is a bit hard to visualize because of the coupler being all black,
but it's there. I show this to let folks know that maybe by changing
to this style coupler that maybe some of the imbalance might be
modified in their engines if they presently have the coupler which
doesn't have this "gap-filling" ridge. What do you think?
Lynn Matteson
Sensenich 62x46
On Jan 15, 2009, at 10:10 AM, Andy Silvester wrote:
<andy(at)suncoastjabiru.com>
Lynn,
intake
this gap,
our OEM
still very
might expect
little
vertical
jet,
This extra
to an
(lambda)
current
10:1 on one
'ideal'
swap over
distribution was
ago, and
comprehensive
effects
the GRT
see the
inserting
wasn't a
Ideally, the
and
2200 and
tend to be
up the
back.
liquid
but no
not? It's
theirs!
Andy
Description: |
Filesize: |
388 KB |
Viewed: |
776 Time(s) |
N369LM |
Posted: Fri Jan 16, 2009 6:24 am Post subject: 3300A - Full Throttle Roughness |
You're right, Lynn, apologies. Must be advancing years or British beer for
the last couple of months that have taken their toll. Back in Brazil very
soon with a healthier diet and more brain exercise, no doubt. There may
well be others with the older couplers and the 'gap' who might be interested
though. Unfortunately, the only way to find out is to remove it and look
inside.
Cheers, Andy
Posted: Fri Jan 16, 2009 6:25 am Post subject: 3300A - Full Throttle Roughness |
Peter Harris wrote:
J
ignored.
Peter
JOE RONCO
Joined: 04 Aug 2007 Posts: 31 Location: CENTENNIAL COLORADO
Posted: Fri Jan 16, 2009 8:22 am Post subject: 3300A - Full Throttle Roughness |
Or you could trade it in for a new UL Power (www.ulpower.com) Model UL350i (same or better performance as the 3300) and get EFI/FADEC as standard. No messing with carburetors, carb heat or carb ice, fuel distribution etc. ULP has also introduced redundancy options for the ECU.
See: http://www.ulpower.com/ul260i-qa-ecu.htm. Click on link at bottom of page for schematics of optional ECU arrangements.
See attachments for preliminary UL350i specifications and performance. ULP is fine tuning/optimizing the UL350i design with release to the market expected 2Q/3Q 2009.
Joe R
Description: |
 Download |
Filename: |
UL_350i_Preliminary_Specifications.doc |
Filesize: |
59 KB |
Downloaded: |
465 Time(s) |
Description: |
 Download |
Filename: |
UL350i_Preliminary_Performance.doc |
Filesize: |
34 KB |
Downloaded: |
496 Time(s) |
Lynn Matteson
Posted: Fri Jan 16, 2009 9:57 am Post subject: 3300A - Full Throttle Roughness |
"Back in Brazil"? R U UK'ing it now?
Lynn Matteson
Sensenich 62x46
beer for
Brazil very
There may
interested
look
inside.
Cheers, Andy
N369LM |
Peter H
Posted: Fri Jan 16, 2009 12:47 pm Post subject: 3300A - Full Throttle Roughness |
J
The throttle quadrant does nothing to solve the basic design fault which is
due to the cable attachment off centre and not co planar causing the slide
to twist when moved, and the increased load due to friction on the slide
when it is moved at low throttle settings.
But it is not only the design issues but also the attitude of the CEO as he
was not prepared to supply me with the Teflon insert listed on his web site
and resorted to personal abuse when I suggested some design changes that
would solve the problem.
There have been engine failures and a forced landing due to jammed slides.
Peter
sonex229(at)windstream.ne Guest
Posted: Fri Jan 16, 2009 3:24 pm Post subject: 3300A - Full Throttle Roughness |
BALONEY TO your failed engine statement due to the Aero-Vee carb. Verify one
that can be proven to be caused by the carb,,..Regards Wayne
