Extending the wing spar...
nickc(at)mtaonline.net
PostPosted: Fri Jan 02, 2009 10:16 pm    Post subject: Extending the wing spar... Reply with quote
Greetings Kolber’s new and old,
I am planning to extend the wing spars on my proto type Kolbra by 22” so that the wing will be flying to the tip. Flight testing, in the spirit of experimental aircraft, will determine whether or not the ______ _______ are the permanent wing tips.
Since I have yet to build my wings, my question for you to chew on is…should the splice be on the inboard end of the spar or the outward end? The splice will be a butt joint, with a 12” long section of spar inserted inside the spare and riveted in place. I favor putting the splice inboard , what do you think … have at it?
Thank you all, for the great education!
Nick Cassara
Palmer, Alaska -25 degree F
PS Beaufort VG drawing is at the bottom of the archived photos list
Dana
PostPosted: Sat Jan 03, 2009 5:22 am    Post subject: Extending the wing spar... Reply with quote
At 01:15 AM 1/3/2009, Nick Cassara wrote:
I am planning to extend the wing spars on my proto type Kolbra by 22 so
is&should the splice be on the inboard end of the spar or the outward end?
The splice will be a butt joint, with a 12 long section of spar inserted
, what do you think & have at it?
What do you mean, "flying to the tip"? And what is "the ______ _______"?
Why are you extending the wings? Aren't short wings the whole point of the
Kolbra?
Without looking closely at the design, I would put the splice near the
tip. Bending stresses are highest at the spar attach point and decrease as
you go towards the tip and towards the root, but torsional stresses (from
aileron forces) are highest at the root.
-Dana
New safety announcement from the Department of Homeland
Security: Securely duct tape shut any books you may own about civil
liberties or the U.S. Constitution.
ez(at)embarqmail.com
PostPosted: Sat Jan 03, 2009 5:33 am    Post subject: Extending the wing spar... Reply with quote
Nick,To me that would be a no brainer. If there is ANY chance that your modification may not be permanent, the wing tip end would be much easier to modify.
Where do birds have their strongest bones, wing tips , or wing roots?
IOW Don't mess with the wing root.
My humble opinion only.
Gene
Nick Cassara
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
slyck(at)frontiernet.net
PostPosted: Sat Jan 03, 2009 6:59 am    Post subject: Extending the wing spar... Reply with quote
Nick, that cold air is having a detrimental effect on your decision making.As others have replied, definitely don't mess with the inboard end.
That spar was meant to work as one big chunk.  It doesn't take kindly to cutting
and drilling.  Rivet holes should be kept to a minimum.  Most stress is in lift and
drag which means particularly the quarter from front to bottom is in tension.
Take a piece of that spar material, put it in a vise and bend it a couple times with
visegrips.  You will be alarmed at how readily it fails.
Since the tips have a small load you may be better off inserting an I beam at the end.
You could make a decent one from thick sheet metal in the form of a truncated U.
-Or maybe a deep V with tabbed ends.
BB
Nick Cassara
capedavis(at)yahoo.com
PostPosted: Sat Jan 03, 2009 7:03 am    Post subject: Extending the wing spar... Reply with quote
Nick, I learned to really fly in a glider and the guys that had the real state of the art sailplanes had wing tip attachments some as long as 5 feet their extensions were always on the wingtip I think there is a lot more shearing stress on the inboard end of the wing . Just my 2 cents ! Good Luck . what is wrong with wing as it comes ? do you need more lift? Chris
Sent: Saturday, January 3, 2009 1:15:09 AM
Subject: Extending the wing spar...
Nick Cassara
[quote]http://ww====================== [b]
Possums
PostPosted: Sat Jan 03, 2009 7:53 am    Post subject: Extending the wing spar... Reply with quote
I've seen the tips changed & the Leading Edge spliced, but
not the spar. At least not the inboard end.
Nick Cassara
 Filesize:  70.45 KB
 Viewed:  211 Time(s)
 Filesize:  124.57 KB
 Viewed:  191 Time(s)
Possum
Dana
PostPosted: Sat Jan 03, 2009 7:58 am    Post subject: Extending the wing spar... Reply with quote
At 09:58 AM 1/3/2009, robert bean wrote:
...Most stress is in lift and
Actually, on a strut braced high wing airplane, the inboard part of the
wing spar is primarily in compression (unless, of course, you're flying
inverted). It has to be, to balance the tension in the lift struts.
On a fully cantilevered wing, of course, it's a different story.
-Dana
Mr. Cole's Axiom:
The sum of the intelligence on the planet is a constant; the population is
growing.
russ(at)rkiphoto.com
PostPosted: Sat Jan 03, 2009 8:05 am    Post subject: Extending the wing spar... Reply with quote
NickI applaud your spirit of  trying to  make some improvements to your Kolbra -- but have  you had any kind of engineer/designer look at it? It's a major change and could change the flying characteristics a lot. Generally not a good idea to mess with a well-proven design.
ALSOI -- consider how she'd fly if one extension came off inflight, but not the other?
I don't think you'd be very happly.
Russ Kinne
Nick Cassara
PostPosted: Sat Jan 03, 2009 9:25 am    Post subject: Extending the wing spar... Reply with quote
ya got me there pard, except for maybe in a steep dive at near zero
Gs. Things must change fast when the pullout occurs.
When I riveted the rib brackets to my left wing restoration I used
fewer rivets than the other guy did.
I didn't feel there was going to be that much twist load. So far, so
good.
BB
> in tension.
the wing spar is primarily in compression (unless, of course,
you're flying inverted). It has to be, to balance the tension in
the lift struts.
-Dana
Mr. Cole's Axiom:
population is growing.
mdnanwelch7(at)hotmail.co
PostPosted: Sat Jan 03, 2009 9:51 am    Post subject: Extending the wing spar... Reply with quote
Since I have yet to build my wings, my question for you to chew on is…should the splice be on the>inboard end of the spar or the outward end?
Nick Cassara
Nick,
As you are aware, I HAVE extended my wing spars, to accomodate droop tips. I chose to extend the outer tip of the spar by using a chrome moly truss and various alum. tubes for triangulation bracing. This method has provided a very strong 22" extension. Scott (icrashrc) used a similar method to extend the end of his spar, to also add droop tips.
Although I think is "possible" to extend the spar at the root (as you descibed), I wouldn't consider it without destructive testing and some engineering calcs. If the splice were to fail at the root, the results would be predictable...bad!!
Yes, as stated, the loads on the inner portion of the spar are in compression. Plus, the spar is also in a bending stress, which would create a shear on an inner extension. It is my opinion that if you add any length to the spar, it should be at the tip.
With regard to failure of my spar extension truss design, I doubt it!! Once it was bolted on, and reinforced, it feels rock solid. To calculate the G forces at 6 G's on just the 22" wide extension is an easy affair. A quick calculation says each extension should be able to support
around 225 lbs, for a 6 G force. 225 lbs wouldn't even get it's attention!!
I think the general concensus here is to add on to the tip. It is reasonably easy, and can provide for a strong platform for droop tips. IMHO!!
Best regards,
Mike Welch
MkIII
Send e-mail faster without improving your typing skills.
http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_speed_122008
NeilsenRM(at)comcast.net
PostPosted: Mon Jan 05, 2009 7:17 am    Post subject: Extending the wing spar... Reply with quote
Nick
I know enough aerodynamics to be dangerous but.... If you have the full airfoil to the wing tip (if that is what you are talking about) you may get very little benefit if anything. It seems like I have read that a wing with a airfoil right at the tip will loose most all the lift near the tip by allowing that air to escape off the tip. My understanding is that wingtips are designed two ways. One the most common is to taper into a non lifting shape to minimize the generation of span wise airflow (air escaping off the wing tip into to a tip vortex). The second type attempts to stop span wise flow or recover energy from the vortex. The latest New Kolb wing tips and winglets fall into the later or some variation of both.
It is great to experiment but this isn't a new idea. I'm sure there are test results available that would show wing tip performance comparisons. The last thing you want to do is create a larger draggy tip vortex that doesn't reduce stall speed.
Rick Neilsen
Redrive VW powered MKIIIC
PostPosted: Mon Jan 05, 2009 8:02 am    Post subject: Extending the wing spar... Reply with quote
Rick Neilsen
Rick N.,
It is my understanding, from Nick's emails to me directly, that he intends on installing droop tips.
Although he didn't state that, I'm pretty sure that's his plan.
With regard to your comment about lift escaping off spanwise from the end of the wing, I definitely agree
with you. One of the biggest factors that I believe contributes to this is the high incidence angle of
the Kolb airplane's wings in flight. While this attribute may give Kolb's airplanes their fantastic flying performance, it also proves that the lift produced by the wing goes through quite a high pressure gradient difference (in other words, the air really gets squished going under the wing). The fact that the stall speed
on the factory Xtra went from 30 MPH to 26 MPH, by installing droop tips proves this.
In my opinion, all this seems intuitive! If we were able to watch a wind tunnel test of a "high incidence
wing's wingtip lift loss", I think the results would be predictable, and obviously apparent, too.
For SOME flyers, altering the original design to include thing's like droop tips or VGs, serves their flying
needs in some way. Whether it their own limitations, their landing field, or whatever they deem necessary, they seek a slower landing wing. That is NOT a bad thing. SOME pilots do NOT see any need whatsoever to alter the original design, and are quite satisfied with the performance and flying characteristics as they are, unaltered! Great!! To each his own.
Mike Welch
MkIII
It’s the same Hotmail®. If by “same” you mean up to 70% faster.
http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_broad1_122008
PostPosted: Mon Jan 05, 2009 8:53 am    Post subject: Extending the wing spar... Reply with quote
Mike W:
incidence angle of
proves this. > Mike Welch
The only thing the new Xtra wing has in common with Homer Kolb's wing is the
shape of the airfoil. The new wing is longer and was flown, initially, with
no bow tip. So...we can't compare it to the wing I am flying with, which
has Homer's bowtip that has worked since he designed it. Had we put Homer's
wing tip on the "long" wing, we probably would have reduced the stall just
as much. I don't know for sure, but it would have slowed it down more than
the squared off wing.
As far as high wing incidence in flight, that depends on airspeed. High
speed - it flattens out. Slow down and the tail rides lower increasing wing
incidence.
The reason Homer designed a lot of wing incidence into all his airplanes,
except the Sling Shot, is the design of his landing gear and the way the
aircraft sits nearly level on the ground. Homer designed them this way
because he wanted the added safety of requiring higher airspeed for lift off
and landing for low time Kolb pilots. Without the increased wing incidence,
it would take a lot of runway to get going fast enough to fly off in a level
attitude.
I have never changed Homer's wing design because what he came up with is
hard to beat. The wing tip is his design and serves to provide his aircraft
with the great performance and gentle flight characteristics that they have
always been famous for. I fly off a 750 ft airstrip and have been for 25
years. I fly in some very short, unimproved, unfriendly strips that most
pilots would not consider. My fat mkIII breaks in ground effect as the ASI
is coming through 30 mph. How accurate is that ASI? I don't know.
Probably about as accurate as the ASI in the new Factory MKIIIx I tested
last year.
Just a guess, but I think a lot of folks want to change the Kolb wing tip
because it looks cooler. Personally, I don't care if it looks like it does.
What I like about it is it works, and has worked since Homer designed it.
Remember, any time one changes one part of a proven design, it usually
affects other aspects of flight performance. For example: You may reduce
the stall speed, but lose some of the gentle stall characteristics in the
process.
VG's??? If you need them, fly with them. Up until now, I have not been
able to determine that the increase in performance and safety is worth the
effort and expense of installing them on my mkIII. Never said they do not
work. Just don't help enough to go to the effort...
My old airplane has been proven in flight for many hours and years. I never
hesitate to put up against other Kolbs, in the air, to compare "real world"
performance.
BTW: I don't have any aerodynamic engineering expertise. I am just an old
pilot that has experienced a lot of time in Kolbs in a lot of situations. I
have a great deal of respect for these airplanes, have made a lot of
mistakes, and am still learning how to fly them almost every time I go up.
PostPosted: Mon Jan 05, 2009 9:32 am    Post subject: Extending the wing spar... Reply with quote
VG's??? If you need them C fly with them. Up until now C I have not been
John H. C
Everytime I have ever mentioned VGs C I have always made the very clear point that SOME people don't see their
merit on THEIR plane. I have also made the point that these same people aren't arguing whether or not they are useful C just that THEY don't see their need for them.
As a general rule C I try and make a clear point of being tolerant of other's views and experiences (as opposed to others). I realize there are hundreds of flyers C and everyone of them has his or her own talents C or lack thereof. What works for one C does NOT always work for someone else. Nor should it. No one should be criticized for NOT following the choices of someone else.
One of the wonderful advantages we enjoy here in the USA is the freedom to build our planes in the Experimental catagory. It affords us the ability to build our planes as we see fit. In my opinion C I think that is a good thing. Otherwise C we might as all build our planes exactly identical to each other C and never deviate a rivet.
Mike Welch
MkIII Classic
 Filesize:  39.72 KB
 Viewed:  164 Time(s)
PostPosted: Mon Jan 05, 2009 9:59 am    Post subject: Extending the wing spar... Reply with quote
Mike W:
No argument, criticism intended. Simply stating my experience and opinion
on the subject of changing the design of a product that I am familiar with.
Does disagreeing with someone on the Kolb List make me a bad guy?
I will continue share my experience, good and bad, hoping others on the Kolb
List will "read" and try to "understand" what I am saying, rather than take
personal offense to it.
PostPosted: Mon Jan 05, 2009 10:38 am    Post subject: Extending the wing spar... Reply with quote
John H.,
Just to make things clear, I certainly wasn't offended by anything you said, nor was I arguing with you, I was agreeing with you. I greatly agree that we should "read and understand" what a person writes, and not read any more into whatsomeone says than what they actually state.
Without question you are probably the most experienced Kolb driver out there. Of course, your experience/opinion
on all things Kolb should be taken seriously by those that build or fly Kolbs.
Mike Welch
MkIII
pj.ladd(at)btinternet.com
PostPosted: Mon Jan 05, 2009 11:07 am    Post subject: Extending the wing spar... Reply with quote
Otherwise, we might as all build our planes exactly identical to each other,
and never deviate a rivet.>>
Hi Mike,
you say that as if it was necessarily a `bad thing` It aint. The advantages
being that you know, even if yours is the first model of a new type, that it
won`t kill you.
You know if you buy secondhand that the plane is as described in the
manufacturers blurb, or at least it was at its last annual check.
You know that if a modification has been introduced it will not impair the
performance or its engineering integrity.
You know that if the span has been increased it will not have been achieved
by scarfing something unsuitable onto the wing root.
You know that your machine is legally what it is supposed to be.
You know that the plane will not be `fat` and invalidate your insurance if
you have a crunch.
You know if you buy a manufacturers kit you will finish up with a machine
not much different to one from the factory.
That is not to say that your Mark3 is the same as mine. Different builders
have different ideas. It will rig differently, your instrument package will
be different to mine. The weight and the C of G will vary, but within
limits.
You will also know that if you are unfortunate enough to have a crunch you
have a proven engineering train to fall back on in court and you will never
have to cut up a plane because you cannot take the chance of someone suing
you in the event of a crunch.
I dont have the engineering expertise to build a safe plane, but I know a
man who does.
Mind you if you can get the weight down below 115kg even in hide bound old
England you can build what you like.
Cheers
Pat
dcreech3(at)hotmail.com
PostPosted: Mon Jan 05, 2009 1:21 pm    Post subject: Extending the wing spar... Reply with quote
Subject: Re: Extending the wing spar...
Date: Mon C 5 Jan 2009 10:52:35 -0600
--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com>
As far as high wing incidence in flight C that depends on airspeed. High
incidence.
This amounts to a quibble C but I think that "wing incidence" properly refers to the angle of the wing as attached to the airframe.  The thing that changes with airspeed is "angle of attack" C the angle of the wing relative to airflow.
If you assume that the tail boom represents the horizontal line of the fuselage C a Kolb sitting on the ground looks like it would have an unusually large angle of attack in level flight.  I think this is visually misleading C though.  I've never seen myself in the air C but I have the general impression that the plane trims itself for level cruise flight with the tail boom canted upward C making the bottom surface of the wing more horizontal.
I share your opinion about the inherent "goodness" of the basic Kolb design.  It's a real "sweet spot" considering the various tradeoffs involved C hard to improve on for its purpose.
Regards C
Lee
Firestar II
It’s the same Hotmail®. If by “same” you mean up to 70% faster. Get your account now. [quote][b]
