westexflyboy
Posted: Sat Jan 03, 2009 10:11 pm Post subject: GPS and Fiberglass |
Have any of you RV-10 builders experimented with GPS antennas installed in the overhead console? (i.e. inside the cabin but not up on the dash) I am wondering if the fiberglass cabin cover impedes the signal. I want to hide the two GPSMAP 496 antennas. Any ideas?
_________________ Chase Snodgrass
Presidio, Texas
www.flybigbend.com
Simultaneous RV-10 twins under construction |
Deems Davis
Posted: Sun Jan 04, 2009 4:43 am Post subject: GPS and Fiberglass |
Chase, here's a link to an Archive thread that deals with the same
questions you are asking.
http://www.matronics.com/searching/getmsg_script.cgi?INDEX 4874467?KEYS=antenna_&_fiberglass?LISTNAME=RV10?HITNUMBER=54?SERIAL=0428527735?SHOWBUTTONS=YES
In the end I dropped the gyro stabilized gimble approach and mounted
them to the top of the Cabin Cover
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
Dick Sipp
Posted: Sun Jan 04, 2009 8:40 am Post subject: GPS and Fiberglass |
I mounted the 496 antennas under the engine cowling; working fine so far at
90 hours.
Currently vacationing in GA on St. Simons Island with friends, off to Ft.
Meyers tomorrow for a few days.
What a magic carpet.
Dick Sipp
N110DV
Deems Davis
Posted: Sun Jan 04, 2009 7:11 pm Post subject: GPS and Fiberglass |
I just tried th elink and it seems to work, perhaps the email program
warpped it and you only got a part of it. As a back up go to the
Matronics archive and search on 'fiberglass and antenna placement' there
are a number of posts around Sep 07 that are relevant.
Deems
pascal(at)rv10builder.net Guest
Posted: Sun Jan 04, 2009 7:49 pm Post subject: GPS and Fiberglass |
try doing a search
Match: #54
Message: #12814
Date: Sep 16, 2007
Subject: Re: Fiberglass and antenna placement
Sent: Sunday, January 04, 2009 6:46 PM
Subject: Re: GPS and Fiberglass
AirMike
Posted: Sun Jan 04, 2009 11:20 pm Post subject: GPS and Fiberglass antenna |
here is one installation. The inside job seen at OSH on 2007. I was told by th avionics shop that it will reduce the life of the antenna, so I went with two on top of the dash
Description: |
Filesize: |
1.44 MB |
Viewed: |
494 Time(s) |
_________________ See you OSH '18
Q/B - sold. |
Posted: Mon Jan 05, 2009 5:42 am Post subject: GPS and Fiberglass |
I think 'maybe' should be used instead of 'will'. The heat in the
glareshield area on a sunny day can get pretty high too. I don't think
that area in the picture gets as hot as folks think (but I have no data)
because most of the engine heat goes out through the cowl exit in
flight. If baffled good. after shutdown, convection should take most of
that heat and exit through the inlets. I'm in the habit of opening up
the oil filler door after I park and really don't get much heat exiting
there (but I think any help is good!). Heat isn't kind to electronics,
especially semiconductors, but semiconductors have 'matured' over the
years and are increasingly more tolerant of heat. Someday I'll try and
measure the temps ...... but those 'somedays' seem to take forever!!!
Linn
