patreilly43(at)hotmail.co Guest
Posted: Mon Dec 29, 2008 4:18 pm Post subject: 582 fuel pump |
Kitfoxers, Awhile back someone posted a note to make sure the vent hole on the fuel pump was down when you mounted the pump. I often feel like I am going blind, and maybe I am. I can't find a vent hole. Anybody out there that can tell me where the vent hole on that Mikuni pump is supposed to be?
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Guy Buchanan
Posted: Mon Dec 29, 2008 6:42 pm Post subject: 582 fuel pump |
At 04:16 PM 12/29/2008, you wrote:
| Quote: | | Kitfoxers, Awhile back someone posted a note to make sure the vent hole on the fuel pump was down when you mounted the pump. I often feel like I am going blind, and maybe I am. I can't find a vent hole. Anybody out there that can tell me where the vent hole on that Mikuni pump is supposed to be? |
Pat,
Personally I think it should be on the bottom of the casting, since I mount mine vertically. However it's actually in the brass elbow where the pulse line attaches. This means the pump is supposed to be mounted flat, with the logo up. Who does that? Some day I'll mic the existing hole, replace the elbow, and drill a new one the same size in the casting. Right now I suspect my pulse chamber is constantly 1/2 full of fuel/oil/whatever.
Guy Buchanan
San Diego, CA
K-IV/1200 w/ 582 C-box & Warp 3 blade
100% and flying thanks mostly to Bob Ducar [quote][b]
Deceased K-IV 1200
A glider pilot too. |
Tom Jones
Posted: Tue Dec 30, 2008 6:47 am Post subject: Re: 582 fuel pump |
| Quote: | Kitfoxers, Awhile back someone posted a note to make sure the vent hole on the fuel pump was down when you mounted the pump. I often feel like I am going blind, and maybe I am. I can't find a vent hole. Anybody out there that can tell me where the vent hole on that Mikuni pump is supposed to be?
Pat Reilly |
Pat, attached are a couple pulse pump pictures. One with a brass pulse line fitting. The tiny vent hole is in the center of the square brass fitting.
The other is mounted horizontally on my Kitfox motor mount. The pulse line fitting is part of the pump casting. The hole is in the same place in the fitting.
The one with the brass fitting is a genuine Rotax part, I think. It came with my engine. I had it mounted on the fire wall with a 22 inch pulse line. It pumped fine but leaked oil out the vent hole. I thought the pump was faulty.
I purchased the cast fitting pump from CPS. It did the same thing. I moved the mount closer to the engine pulse port as shown in the picture with a six inch pulse line and the leaking stopped.
The first pump that I received from CPS did not have the vent hole. He said they drill the holes themselves and that one must have been missed.
The aircraft engine version of the Mukunie pulse pumps are the only ones that have the vent hole. Pumps for snowmobiles etc. do not. Some of those have found their way onto aircraft.
154.44 KB |
692 Time(s) |
156.76 KB |
742 Time(s) |
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Posted: Tue Dec 30, 2008 12:25 pm Post subject: 582 fuel pump |
Tom C Thank you very much for the photos. My brass fitting has the vent hole in it. That is a very small hole. I guess it doesn't matter how the pump is oriented on the firewall C the hole is dead center no matter how you rotate the pump. Why would there be an oil leak with a longer vacumn line?
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
| Quote: | Subject: Re: 582 fuel pump
Date: Tue C 30 Dec 2008 06:48:00 -0800
--> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net>
> Kitfoxers C Awhile back someone posted a note to make sure the vent hole on the fuel pump was down when you mounted the pump. I often feel like I am going blind C and maybe I am. I can't find a vent hole. Anybody out there that can tell me where the vent hole on that Mikuni pump is supposed to be?
> Pat Reilly
Pat C attached are a couple pulse pump pictures. One with a brass pulse line fitting. The tiny vent hole is in the center of the square brass fitting.
The one with the brass fitting is a genuine Rotax part C I think. It came with my engine. I had it mounted on the fire wall with a 22 inch pulse line. It pumped fine but leaked oil out the vent hole. I thought the pump was faulty.
Tom Jones
Classic IV
503 Rotax C 72 inch Two blade Warp
Ellensburg C WA
http://forums.matronics.com/viewtopic.php?p=221782#221782
http://forums.matronics.com//files/pulse_pump_brass_144.jpg
http://forums.matronics.com//files/pulse_pump==================
Posted: Tue Dec 30, 2008 12:33 pm Post subject: 582 fuel pump |
Guy C Thanks for the info. I'm mounting mine on the firewall also. Tom Jones sent pictures C I have a vent hole in the brass fitting same as his. Man that hole is small.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Mon C 29 Dec 2008 18:37:05 -0800
At 04:16 PM 12/29/2008 C you wrote:
| Quote: | | Kitfoxers C Awhile back someone posted a note to make sure the vent hole on the fuel pump was down when you mounted the pump. I often feel like I am going blind C and maybe I am. I can't find a vent hole. Anybody out there that can tell me where the vent hole on that Mikuni pump is supposed to be? |
Pat C
Personally I think it should be on the bottom of the casting C since I mount mine vertically. However it's actually in the brass elbow where the pulse line attaches. This means the pump is supposed to be mounted flat C with the logo up. Who does that? Some day I'll mic the existing hole C replace the elbow C and drill a new one the same size in the casting. Right now I suspect my pulse chamber is constantly 1/2 full of fuel/oil/whatever.
Guy Buchanan
San Diego C CA
ww.matronics.com/contribution
| Quote: | http://www.matronics.com/Navigator?Kitfox-List
ronics.com
Tom Jones
Posted: Tue Dec 30, 2008 1:23 pm Post subject: Re: 582 fuel pump |
| Quote: | | Why would there be an oil leak with a longer vacumn line? |
Thats a good question. I asked a mechanic at CPS but he deflected that question. I have a theory why. The longer pulse line allows for the larger amount of air in that line to compress too easily. This allows fuel to work its way through the line.
Another Kitfox owner had the same problem with a 503 that he cured with a shorter pulse line so it is confirmed in my mind that the too long pulse line is one thing that can cause the problem of fuel working its way into the pump. Since I installed the shorter pulse line the pump has not leaked one drop in about 55 hours flight time. My original pump instillation with the 22 inch line was per the Skystar Builder's manual and sloped up hill all the way to the pump.
The Rotax directive for the fuel pump "Weep hole" in aircraft installations says the hole is to prevent a hydraulic lock in the pump in a case where the owner installs the pump incorrectly. here's a link to a CPS maintenance article that discusses the weep hole.
http://www.800-airwolf.com/pdffiles/ARTICLES/part41.pdf
I would say the long pulse line was an incorrect installation and the weep hole may have saved my bacon. I flew about 10 hours with the original installation. I fastened a catch cup under the pump and it was catching about one to two ounces per hour.
By the way, the pulse port on a 503 is under the front cylinder, thus my long pulse line with the pump mount on the fire wall. The 582 pulse port is under the rear cylinder so it is easier to find a mounting location with a shorter pulse line, I think.
Classic IV
Ellensburg, WA |
wingman
Posted: Tue Dec 30, 2008 4:19 pm Post subject: Re: 582 fuel pump |
I think that if one would use a soft fuel line as a pulse line, the tube would collapse and produce less energy to the membranes of the fuel pump.
I suggest that great care is taken when installing a pulse line.
To ensure that it will handle the vacuum pressure produced by the engine.
_________________ Kitfox IV 1200
Rotax 912 ULS
on full lotus floats |
Posted: Tue Dec 30, 2008 5:47 pm Post subject: 582 fuel pump |
I'm using 1/4" reinforced rubber gas line. It is pretty stiff stuff. That is what the previous owner had on the engine. What line is recommended C and is there a maximum length?
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Tue C 30 Dec 2008 16:19:34 -0800
--> Kitfox-List message posted by: "wingman" <wingman5507(at)gmail.com>
I think that if one would use a soft fuel line as a pulse line C the tube would collapse and produce less energy to the membranes of the fuel pump.
Kitfox IV 1200
Rotax 912 ULS
Rigging full lotus floats at the moment
http://forums.matronics.com/viewtopic.php?p=221842#221842
&g========================>
wingman
Posted: Wed Dec 31, 2008 4:48 am Post subject: Re: 582 fuel pump |
I think some of the rotax mechanics on the forum could answer this better.
But it is obvious that the longer the line is, the stiffer it must be.
The best thing is to keep it as short as possible with a hose dedicated to withstand internal negative pressures.
I am sure your local hose supplier would be able to recommend you a good soultion.
Rotax 912 ULS
Tom Jones
Posted: Wed Dec 31, 2008 4:26 pm Post subject: Re: 582 fuel pump |
| Code: | I'm using 1/4" reinforced rubber gas line. It is pretty stiff stuff. That is what the previous owner had on the engine.�What line is recommended C and is there a maximum length?
Pat Reilly
Mod 3 582 Rebuild |
Pat, the Rotax installation manual says the fuel pump pulse line should be no longer than 20 inches. As you know from my previous post, I had serious fuel pump weeping problems with a 22 inch pulse line. My opinion is: try to keep the line shorter than 12 inches.
I use the "Pulse line from aircraft spruce.
http://www.aircraftspruce.com/catalog/appages/pulseline.php
Fuel system is in section 15 in the Rotax installation manual.
http://www.rotax-owner.com/manuals/d00287.pdf
Classic IV
Ellensburg, WA |
Fox5flyer Guest
Posted: Thu Jan 01, 2009 6:16 am Post subject: 582 fuel pump |
What you're using will probably work fine. I read somewhere that it should
be kept to 12" or less, if possible and it's inadvisable to use any sort of
soft line, like polyurethane as it will flex (in/out) with the piston pulses
and can inhibit the pumping action of the diaphragm. My suggestion would be
to use fuel injection line. That stuff is built to handle high pressure and
won't flex at all. It's about $5 a foot, but worth it for something like
this. Once it's on there, it should last the life of the engine.
Happy 2009 everybody.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Posted: Thu Jan 01, 2009 7:49 am Post subject: 582 fuel pump |
Deke C Tom C Guy C Noel and all other contributors C Thanks for the info. The fuel pump mounting location requires about 20" of hose. I am going to use hard tube to shorten the run. Hose requires me to loop around 180 degrees. I don't think I can twist the square brass inlet port to allow access from the other side. It doesn't look like it is threaded. It appears to be cast in place in the aluminum body of the pump. Hard tube tight bends should allow me to keep the run under 12". Deke C CPS catalog says keep the run under 12". Now here is another question. I want to rebuild the pump. The rebuild kits I see are for the Mikuni pump with the straight access port tubes. Are those two pumps identical inside C and use the same rebuild kit? I have the bent tube pump. The rebuild kit supplier will know. But C just thought I'd ask you guys.
In addition C Noel thanks for the Tiny Tak info. I ordered one and it sure looks slick for $50. I will leave the dial one in and mount the Tiny Tak also. Instructions call for 3 to 4 wraps on the spark plug lead. When you wrap both leads of the 2 plugs to one cylinder to get reading durning mag check C how many wraps per plug lead are you using?
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
> From: fox5flyer(at)idealwifi.net
[quote] To: kitfox-list(at)matronics.com
Subject: Re: Re: 582 fuel pump
Date: Thu C 1 Jan 2009 09:16:12 -0500
--> Kitfox-List message posted by: "fox5flyer" <fox5flyer(at)idealwifi.net>
be kept to 12" or less C if possible and it's inadvisable to use any sort of
soft line C like polyurethane as it will flex (in/out) with the piston pulses
won't flex at all. It's about $5 a foot C but worth it for something like
this. Once it's on there C it should last the life of the engine.
Deke Morisse
Mikado Michigan
"The aim of an argument or discussion should not be victory C but progress."
- Joseph Joubert
Guy Buchanan
Posted: Thu Jan 01, 2009 8:50 am Post subject: 582 fuel pump |
At 07:48 AM 1/1/2009, you wrote:
| Quote: | The rebuild kits I see are for the Mikuni pump with the straight
access port tubes. Are those two pumps identical inside, and use the
supplier will know. But, just thought I'd ask you guys.
An aside, Pat. Last September, when I rebuilt my fuel pump, CPS sold
me an aftermarket rebuild kit that I felt was junk. Beware. I will
insist on Mikuni parts in the future.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
Fox5flyer Guest
Posted: Thu Jan 01, 2009 9:08 am Post subject: 582 fuel pump |
If it were me, I would just mount the pump in a suitable spot that makes everything easy with short runs. Any snowmobile dealer should have a rebuild kit for it, or even a new pump for that matter. What makes you think it needs one?
Deke Morisse
Mikado Michigan
- Joseph Joubert
Tom Jones
Posted: Thu Jan 01, 2009 12:31 pm Post subject: Re: 582 fuel pump |
| Quote: | | The fuel pump�mounting location requires about 20" of hose. I am going to use hard tube to shorten the run. Hose requires me to loop around 180 degrees. I don't think I can twist the square brass inlet port to allow access from the other side. |
Pat, you can rotate the plates that make up the fuel pump. Take it apart and you will see that you can put it back together with the pulse port fitting pointing where you want it to. It is pretty simple inside, you can't put the plates back together wrong. If you take out the diaphrams and rubber parts place them on your work table in an order so you can tell where they came from and you can put them back in where they belong.
Classic IV
Ellensburg, WA |
Posted: Thu Jan 01, 2009 2:54 pm Post subject: 582 fuel pump |
Tom C Thanks for the tip. I won't have to spend time trying to figure that out now. I am going to rebuild that pump. It has been laying around for awhile. I will rotate the top plate when I rebuild it and be able to shorten that run from 12" to around 8".
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Thu C 1 Jan 2009 12:31:36 -0800
Pat C you can rotate the plates that make up the fuel pump. Take it apart and you will see that you can put it back together with the pulse port fitting pointing where you want it to. It is pretty simple inside C you can't put the plates back together wrong. If you take out the diaphrams and rubber parts place them on your work table in an order so you can tell where they came from and you can put them back in where they belong.
Tom Jones
Classic IV
Ellensburg C WA
http://forums.matronics.com/viewtopic.php?p=222231#222231
| Quote: | _=======================
&g===
Posted: Thu Jan 01, 2009 3:02 pm Post subject: 582 fuel pump |
Deke C The pump has been laying around for a couple of years. A rebuild kit is $15. For $15 and a 1/2 hours time C I will feel cofident that the pump is operable. And Tom says I can rotate the top plate 180 degrees. That will give me a vacumn line run ao about 8" that should be short enough.
Pat Reilly
Date: Thu C 1 Jan 2009 12:07:33 -0500
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Verdana;} If it were me C I would just mount the pump in a suitable spot that makes everything easy with short runs. Any snowmobile dealer should have a rebuild kit for it C or even a new pump for that matter. What makes you think it needs one?
Deke Morisse
Mikado Michigan
- Joseph Joubert
Posted: Thu Jan 01, 2009 3:04 pm Post subject: 582 fuel pump |
Guy C Thanks for the heads up. I will insist on a genuine Mikuni rebuild kit. I thought CPS was a top drawer supplier?
Pat Reilly
| Quote: | Date: Thu C 1 Jan 2009 08:49:31 -0800
Subject: RE: Re: 582 fuel pump
--> Kitfox-List message posted by: Guy Buchanan <bnn(at)nethere.com>
An aside C Pat. Last September C when I rebuilt my fuel pump C CPS sold
Guy Buchanan
San Diego C CA
100% and flying than==============
