503 cabin heater
ElleryWeld(at)aol.com
PostPosted: Sat Nov 08, 2008 5:22 am    Post subject: 503 cabin heater Reply with quote
That heater is a piece of crap I know two people that have bought them and they are not long lived, I made a better one for my Firestar out of Stainless steel you can see pic's of it in the Photoshare and it will fit in a small area and it works great
Ellery in Maine
In a message dated 11/8/2008 8:05:17 A.M. Eastern Standard Time, nahsikhs(at)elltel.net writes:
--> Kolb-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net>
I was down loading Relative Humidity tables right before I sent the heater question to the kolb List and didn't get the heater link copied like I thought I did. Heres the correct link to see the Aircraft Spruce heater.
http://www.aircraftspruce.com/search/search.php?query=503+heater&searchsubmit=Search&search=1
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=213007#213007
AOL Search: Your one stop for directions, recipes and all other Holiday needs.l?redir=http://searchblog.aol.com/2008/11/04/happy-holidays-from-aol-search/?ncid=emlcntussear00000001 ">Search Now.
Tom Jones
PostPosted: Sat Nov 08, 2008 6:11 am    Post subject: Re: 503 cabin heater Reply with quote
Okay you guys are giving me some good ideas. Thanks Ellery, I looked at your pictures and they helped as well as some another sent to me.
Heres what the 503 installation looks like in my kitfox. Anyone with more ideas or comments I would like to hear/see them.
 Filesize:  898.97 KB
 Viewed:  503 Time(s)
Tom Jones
Classic IV
Ellensburg, WA
Tom Jones
PostPosted: Sat Nov 15, 2008 2:57 pm    Post subject: Re: 503 cabin heater Reply with quote
Thanks to the ideas sent to me I built the heater and tested it today. I just put a restrictor plate on the hot air duct and 2" scat hose through the firewall between my feet. It's a 10 big dogs breath heater. The CHT's behaved just fine. I like things simple so there are no contrlos, just put the restrictor plate on for the winter and take it off for the summer. I could make a couple different sized restrictor plates for when it gets real cold I guess. ground adjustable only. Pictures attached.
 Filesize:  166.41 KB
 Viewed:  518 Time(s)
 Filesize:  225.93 KB
 Viewed:  463 Time(s)
 Filesize:  184.69 KB
 Viewed:  438 Time(s)
Tom Jones
Classic IV
Ellensburg, WA
lcottrell
PostPosted: Sat Nov 15, 2008 5:55 pm    Post subject: 503 cabin heater Reply with quote
Tom,
If you did it the way that I think you did then all you will have to do is make a alum fitting that goes through the firewall with a swing gate inside the fitting to either open or close the gate. Attaching your scat tubing to the new fitting.
Larry C, Oregon
