Ch650 anti oil canning on 601
K Dilks
PostPosted: Mon Oct 27, 2008 5:13 am    Post subject: Ch650 anti oil canning on 601 Reply with quote
Can any one post some pictures of the anti oil canning mods on a 650 so I can incorporate them on my 601.
I can see in the promotional stuff the fuselage ones but wonder how the wing ones go.
Do they form dummy ribs like i have seen on some European models or do they run span wise like stringers between the ribs??
Kev
Back home .................
pavel569
PostPosted: Mon Oct 27, 2008 7:35 am    Post subject: Re: Ch650 anti oil canning on 601 Reply with quote
List of changes for CH650 wing: L angles added between ribs on top skin. Minimizes skin deformation when aircraft is in the sun and provides a
nicer finish.
Pavel
CA
Zodiac 601XL
Stratus Subaru EA-81
Tail, flaps, ailerons, wings, fuselage, canopy done ...
"do not archive"
DaveG601XL
PostPosted: Mon Oct 27, 2008 8:04 am    Post subject: Re: Ch650 anti oil canning on 601 Reply with quote
Here are pictures I took, at Oshkosh, of both the outside and inside of the 650's fuselage.
I hope this helps,
 Filesize:  296.64 KB
 Viewed:  837 Time(s)
 Filesize:  267.96 KB
 Viewed:  849 Time(s)
David Gallagher
Cincinnati, OH area
Larry Hursh
PostPosted: Mon Oct 27, 2008 12:26 pm    Post subject: Re: Ch650 anti oil canning on 601 Reply with quote
I just got off the phone with Travis at Zenith, Mexico, MS. He said he thought he had a picture, showing the layout on the wing for the bracing in the rib bays, between the ribs I've ordered extra "L" angles and hopefully, Travis will be able to put that picture in my shipment to me, or in the mail. If he does send me a photo, I WILL post it here on the website for those wishing to do this upgrade.
Larry Hursh (N650LM Reserved)
"One rivet at a time......one day at a time.."
CH650 (Converted from CH601XL)
1/2 done with fuselage
will be Corvair Powered
View user's profile Send private message Send e-mail Yahoo Messenger
Gig Giacona
PostPosted: Mon Oct 27, 2008 1:23 pm    Post subject: Re: Ch650 anti oil canning on 601 Reply with quote
You can't have to many L angles on hand. You will use more than the plans show and in many places not shown on the plans even if you don't add the cross braces.
W.R. "Gig" Giacona
601XL Under Construction
craig(at)craigandjean.com
PostPosted: Mon Oct 27, 2008 1:43 pm    Post subject: Ch650 anti oil canning on 601 Reply with quote
It isn't too hard to make your own standard L's in 4 foot lengths with a
simple wooden press break. Pictures attached.
-- Craig
 Filesize:  100.51 KB
 Viewed:  756 Time(s)
 Filesize:  96.14 KB
 Viewed:  735 Time(s)
 Filesize:  89.8 KB
 Viewed:  751 Time(s)
 Filesize:  97.7 KB
 Viewed:  735 Time(s)
 Filesize:  96.78 KB
 Viewed:  812 Time(s)
pavel569
PostPosted: Mon Oct 27, 2008 4:28 pm    Post subject: Re: Ch650 anti oil canning on 601 Reply with quote
Have you guys noticed thickness of the rear fuse sides on the picture? It's .020", 601 XL has .025" maybe that's why they added those "L" profiles.
Pavel
CA
Zodiac 601XL
"do not archive"
jmaynard
PostPosted: Tue Oct 28, 2008 5:02 am    Post subject: Ch650 anti oil canning on 601 Reply with quote
A request: Please don't attach several hundred K of pictures to your emails.
Email is not the way to send pictures around. You can post to the Matronics
forum and attach them there, without flooding people's email inboxes with
them. Thanks.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC
Larry Hursh
PostPosted: Tue Oct 28, 2008 9:22 am    Post subject: Re: Ch650 anti oil canning on 601 Reply with quote
I have received the information from Travis at Zenith. (There isn't a photo - just info). According to Travis, here is what he said:
"Good morning Larry. I did a bit of checking and the 4' std. L can be cut in half for use between the ribs. They will run parallel with the main spar 425 center of rivet line to center of rivet line and are on the top skin only. So I figure you will need 6 4' L angles."
I will have two wing lockers so none is required in that bay, buy plan according if you don't have the lockers. I hope this helps everyone out.
Tailwinds and blue skies always,
