jeffrey_davidson(at)earth Guest
Posted: Tue Oct 21, 2008 5:52 pm Post subject: Cobra Head/airbox connection to the carby |
JabiruUSA doesn't seem to have a source for the recommended smooth air elbow recommended from the airbox to the carby intake. Does anyone have a source? My local auto parts stores just looked at me when I told them I just wanted to look through their hose selections to find one. Seems if you can't tell them what car it goes on, you are out of luck …. It is 2 and one quarter inch inside diameter in a 90 degree elbow. This may or may not be the part they refer to as the Cobra Head. Obviously, one did not come with my FWF kit, just scat hose. Thanks ….
Jeff
| - The Matronics JabiruEngine-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
Posted: Tue Oct 21, 2008 6:04 pm Post subject: Cobra Head/airbox connection to the carby |
intakehoses dot com
rshannon
Posted: Tue Oct 21, 2008 6:56 pm Post subject: Cobra Head/airbox connection to the carby |
The hose geometry will depend on each airframe and FWF layout, of course, but FWIW, on my Murphy Rebel, with the std. mixer box mounted straight back of the engine and high, a Gates brand #20748 radiator hose fitting works well for turning the corner. The turn is a little wider than 90 deg., perhaps 105-110 deg. Another short piece of straight 2.25" hose completes the run up to a bottom exit from the mixer box.
A photo is at at http://n254mr.com/node/572 . There's a lot of stuff in the way in this photo, including Magnecor plug wires dangling about, but you can get the idea. It's an AeroCarb installation, but the Bing intake geometry would be much the same.
Ron
On Tue, Oct 21, 2008 at 6:49 PM, Jeff <jeffrey_davidson(at)earthlink.net (jeffrey_davidson(at)earthlink.net)> wrote:
Jeff
marin
Posted: Tue Oct 21, 2008 7:35 pm Post subject: Cobra Head/airbox connection to the carby |
Jeff
I placed mine right behind the engine and have a straight hose into it. I will be ordering my hose from this web site that has the hose you need.
http://vibrantperformance.com/catalog/index.php?cPath=1022_1036&osCsid=83b8c2a0e6b04cdac7cc52e4a45c0749
Marin
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
_________________ Marin |
Posted: Tue Oct 21, 2008 8:25 pm Post subject: Cobra Head/airbox connection to the carby |
This was the part number and price from intakehoses.com at the end of 2006. I got the part number from Lance Gingell’s build log:
90L225 Rubber Elbow 2.25" ID X 90 Degree $9.49
-- Craig
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of steve
Sent: Tuesday, October 21, 2008 8:02 PM
To: jabiruengine-list(at)matronics.com
Subject: Re: Cobra Head/airbox connection to the carby
intakehoses dot com
Quote: |
----- Original Message -----
To: jabiruengine-list(at)matronics.com (jabiruengine-list(at)matronics.com)
Sent: Tuesday, October 21, 2008 6:49 PM
Subject: JabiruEngine-List: Cobra Head/airbox connection to the carby
Jeff
Quote: | href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | | 0123456789 Quote: | href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List | 0 Quote: | href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List | 1 Quote: | href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List | 2 Quote: | href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List | 3 Quote: | href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List | 4
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Wed Oct 22, 2008 3:02 am Post subject: Re: Cobra Head/airbox connection to the carby |
Jeff,
The Intakehoses.com 2.25" 90 degree bend hose is what I am using too. It is not as easy to install and remove as SCAT ducting, but it is working well. Picture attached.
Good luck,
Description: |
Filesize: |
456.46 KB |
Viewed: |
670 Time(s) |
_________________ David Gallagher
Cincinnati, OH area |
Posted: Wed Oct 22, 2008 4:06 pm Post subject: Cobra Head/airbox connection to the carby |
Thank you to everyone that replied. I ordered the elbow today.
Jeff Davidson
CH601-HD
Jabiru 3300A
First engine start coming up, then its FAA Inspection time.
challgren(at)mac.com Guest
Posted: Wed Oct 22, 2008 7:24 pm Post subject: Cobra Head/airbox connection to the carby |
Craig:
It is still the same part number but the cost has escalated to $13.40. However, that is over $80 less than I paid for the Cobra head I received from Jab which was way too big to fit in the small space available.
Thanks for the info on intake hoses dot com. I was just about to google hoses when the hint showed up in my in-box. Will order one today.
Stan
701/3300
Lynn Matteson
Posted: Thu Oct 23, 2008 5:18 am Post subject: Cobra Head/airbox connection to the carby |
I built my own "air straightener/divider." It was a lot of work, and
I can't say as it gave me any benefit...maybe, but I'm not positive.
Here's a picture. I started out with the curved fiberglas tube which
I built, laying fiberglas over a section of PVC plumbing. I used it
for awhile just as a curved tube, then later cut it along the
vertical axis and added the air straightening vanes, and reassembled.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 579.1hrs
Sensenich 62x46
flying again (17 hrs) after rebuild, and new Electroair direct-fire
ignition system
space available.
today.
Stan
701/3300
> Degree $9.49
> -- Craig
> the carby
> intakehoses dot com
Quote: | ========================> ========================> ========================
Description: |
Filesize: |
370.49 KB |
Viewed: |
599 Time(s) |
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
matronics(at)rtist.nl Guest
Posted: Thu Oct 23, 2008 9:05 am Post subject: Cobra Head/airbox connection to the carby |
Hey Lynn, just curious.. With all the modifications you have made to your
engine, what changes did you make to the Jabiru serial number placard to
improve it??
Just kidding, I'm enjoying all the good ideas you share with us.
Thanks!
Rob
Lynn Matteson
Posted: Thu Oct 23, 2008 10:29 am Post subject: Cobra Head/airbox connection to the carby |
Oh, man, I never thought about that! Let's see....Jabiru 2200A dash
Super Ignitor dash Rocker Bushing Supreme...so maybe Jabiru
2200ASIRSB...something like that? : )
Or maybe you meant to the placard itself....maybe I could airfoil the
leading edge of it to help lift....that's it, I'm doin' it!
Lynn Matteson
Kitfox IV Speedster
Sensenich 62x46
ignition system
On Oct 23, 2008, at 1:04 PM, Rob Turk wrote:
<matronics(at)rtist.nl>
to your engine, what changes did you make to the Jabiru serial
number placard to improve it??
Thanks!
Rob
N369LM |
